Member postings for Gareth Hanson
Here is a list of all the postings Gareth Hanson has made in our forums. Click on a thread name to jump to the thread.
Thread: Warco WM 16 VS woes
09/10/2022 12:44:11
Posted by Hugh Stewart-Smith 1 on 09/10/2022 12:33:16:
Posted by Gareth Hanson on 09/10/2022 12:18:59:
Posted by Hugh Stewart-Smith 1 on 09/10/2022 11:07:21:
Gareth
You should find a small hole on the righthand side of the head where you access a grub screw which prevents the head coming off. It engages with the boss that the head swivels on. Sometimes there are 2 grub screws!
Hugh
Amadeal Ltd
Thanks Hugh,
I did spot the small lug with what looks like a fine rotation adjustment screw. Do I just need to remove that part completely? Pic here: https://drive.google.com/file/d/1kaHnW7fSzF-_j4ATn6nqzqtKp06ijsLb/view?usp=sharing
I can't see any others. There's a thread at the bottom as you can see in the pic but it looks unused.
Cheers, Gareth
It's the small whole at the bottom with the grub screw deep within - not visible from the outside and requires the right size Allen key to remove (trial and error!)
Hugh
Amadeal Ltd
Ahh, brill. I'll go and give that a go. Thanks Hugh.
09/10/2022 12:18:59
Gareth
Hugh
Amadeal Ltd
Thanks Hugh,
Cheers, Gareth
08/10/2022 17:33:05
Hi,
I've just bought the Chester version of this mill. The Champion 20VS. I'm trying to do an initial strip and clean. I'm struggling to get the head off. I've undone the 2 bolts that hold it in place and stop it rotating. I can fully rotate the head but I can't seem to actually pull it off. I don't want to just apply brute force in case I damage something. Any advice?
Cheers, Gareth
