Here is a list of all the postings Martin Dare has made in our forums. Click on a thread name to jump to the thread.
Thread: Rust, CI, Localised corrosion - gaskets ? |
27/08/2022 09:55:59 |
Hi It was stored in the same drawer next to the flywheel which is waiting for final bore and keyway. The flywheel surface is highly polished, and though very slightly tanished shows no sign of rust or corrosion. Its a bit of a puzzle really .. . Many thanks for your interest and suggestions. Best Regards picclock |
26/08/2022 18:43:21 |
There was no obvious dampness in the gaskets, which were used straight from the kit box. I intend to replace them with Flexoid gasket material, which I have used before, unless anyone can think of a reason not to. I have never had rusting like this on such a short timescale with such severity. Bit of a puzzle really Best Regards picclock Edited By Martin Dare on 26/08/2022 18:44:38 |
26/08/2022 10:55:35 |
I am building a Stuart Victoria Stationary engine. Having completed the cylinder and steam chest about 3 months ago these were stored in a draw. I have just taken them out for final fitting to find that everywhere which has gaskets is rusted, chest and cylinder endplates, but only where the gasket touches. The bore and all outer surfaces are all rust free. Its as though a chemical in the gaskets is causing the rusting. Any ideas on what this problem is? I can't believe Stuart would knowingly supply incompatible gasket materials. Any Advice much appreciated. Would post pictures but I can't seem to do it .. . Best regards picclock |
