Member postings for Steven Francis
Here is a list of all the postings Steven Francis has made in our forums. Click on a thread name to jump to the thread.
Thread: Spindle bearing grease?
09/04/2023 09:13:45
Should a Chinese mini-lathe have grease in its spindle bearings??
Perhaps a lttle tongue in cheek, maybe along the lines of ...where can I buy a rag impregnated with grit and swarf or is that something special used before leaving the factory cheeky
Thanks for the replies, I used plain lithium grease, didn't over load- less is more.
02/04/2023 18:09:08
Posted by not done it yet on 02/04/2023 14:36:13:
I expect all chinese mini-lathes are not the same. Some indications of machine make might help a bit?
Its an Amadeal 210... so basically a generic brushless belt-drive 8x16.
02/04/2023 13:49:09
Had the front plate off mine to replace the speed pot and had a peek at the bearings...dryer than the proverbial dry thing.
There is nothing in the manual, there are no grease or oil points and the only way of checking is to remove the switch plate.
Believe it has roller rear, tapered roller front. not sealed.....surely there should have been some lubricant?
Thread: Chinese lathe error code(s) list and test procedures
08/10/2022 18:52:22
Posted by JasonB on 08/10/2022 13:02:20:
I would have thought that a depressed emergency switch was wrong, they usually need a twist so they stay up and can then be depressed when you hit them in a hurry. They should also only be uses as an E/S nor for general on/off)
I haven't used the big red-(ish) button besides checking that it worked, finding out that its not a dead stop switch and thats it. I've always turned the speed control to zero and used the on/off buttons.
If the BRB is down- same with the guard and side-panel breakers there's no power and the display doesn't light. up...which in this case it does.
The manual..pah. I'll l live in hope that there's actually a troubleshooter with more detail than ..make sure plugged in and power is switched on laugh
08/10/2022 11:41:44
Hi,
my Amadeal has packed up, powers on but won't turn.
There has been a single error code on the speed display E-04 but otherwise just 0000
There's nothing in the bare bones manual..
spindle wont turn- emergency switch depressed
I've contacted the supplier who initially thought it was the emergency cut off switch.
I checked operation and connections for all of the safetys, main power on-off and emergency.
I received an email - after consultation with his tech guy a new board has been ordered and is winging it's way from China.
Does anyone know what the error codes are for these generic lathes?
There is nothing on the internet, based on the only references I could to simple devices find I feel that it's a switching relay- physical or board issue - damned if I know.
After removing the control board to take a picture so that the correct replacement could be ordered- I reconnected it and the lathe ran once...until I switched off and on again. One E-04 code then 0000 again.
Unplugged all of the connections board, power, emergencies and reconnected.
Again would only run once and this time with direction switch set to reverse.
Worked through the switches, wires, connectors and plugs individually ...nada nichts.
Thread: chuck problems ? maybe others
07/07/2022 12:37:14
Thanks for the replies, at the very least kept me from stewing on my own.
Called the supplier and a replacement is on its way.
06/07/2022 22:18:24
Posted by Robert Butler on 06/07/2022 22:01:45:
Steve
Did you start the jaws correctly and in sequence when replacing after your clean up?
Robert Butler
Edited By Robert Butler on 06/07/2022 22:02:54
no and yes... wrong sequence is one land out, but yes re-assembled correctly.
jaw #3 was out of alignment before the stripdown and clean-up, expected to find swarf, delrin...just grey oil.
06/07/2022 21:50:21
Posted by SillyOldDuffer on 06/07/2022 19:01:24:
Are the jaws in the right slots? They should be marked 1,2,3 possibly as part of a mysterious code, and one of slots will be stamped 1, or perhaps have a dot or other indicator. If the chuck body isn't marked, try the jaws in other slots - it matters!
Otherwise I can't think of a reason for a chuck to suddenly misbehave short of physical damage. The bad chatter may be a clue: check everything - does the spindle move when the chuck is heaved on by hand, or when spun by the motor? Any sign of damage to the scroll, jaws or slot. Was the chuck overtightened, especially with an extender (don't) in hope of reducing chatter?
There are always three suspects when a machining operation goes wrong:
  • the machine or an accessories has developed a mechanical fault (rare but possible)
  • operator error - the list is endless. (Most of the trouble in my workshop is caused by me)
  • difficult material. Possibly the airgun barrel is made from a steel that doesn't machine well. Gun barrels, which might be hardened for longevity, are sometimes rifled by drop forging them onto a mandrel which toughens the steel even more. Gun barrels may not be easy to machine. Should be OK if it filed and sawed without major bother.
don't believe that I've overtightened the chuck and certainly wouldn't use an extension to crank it round. Didn't hand-crank it until my knckle popped either.
Chatter if I'm correct is vibttation- run-out, endfloat, tooling & set-up.
The scroll looked ok, did I measure the whole spiral? No- but there didn't appear to be any stress or binding marks. The key gear retaining pins were loose, one scratched. pretty sure that was #2- might have been when it got sticky winding the jaws out.
The jaws are marked and went back in their respective keyways.
buggered if I know, Murphy's law
not impossible by any means although I am at a loss to how
hmm... no idea of the maker but it wasn't Lothar Walther ( which is harder to cut and file) nor was it cold hammer forged BSA. Roughing was rough and so was finishing., don't believe I got it hot enough to work-harden.
06/07/2022 21:04:11
Posted by John Haine on 06/07/2022 18:20:06:
Have you had the jaws out?
Yes, chuck off stripped and rinsed out. Only noteable thing besides the corrosion on the scroll plate gears- the key/pinion retainers were loose and one was scratched.
No improvement.
06/07/2022 17:28:07
Posted by Baz on 06/07/2022 17:07:37:
If you have only had the machine a few months you should be telling this story to the bloke who sold it to you and asking for a replacement chuck.
Cheers Baz, was feeling a tad frustrated and was hoping for advice- agreement on possible reason for failure before I got on the phone and tried to be politely miffed.
06/07/2022 16:16:44
Had my Amadeal 210 lathe about 10 weeks, turned a couple of small pieces of stainless (30mm x 14o/d) and an airgun barrel last week, besides those .. its been mostly used for turning plastics and facing up repairs.
Accuracy has been pretty good for a 3 jaw self-centreing? 0.02-0.03 mm runout at the spindle plate and chuck body, similar on the ER16 straight shank holder. And reversing the workpeice wasn't far off either..
Until the weekend when I did the barrel and entered chatter city. I used the offcut as a test piece , tried speeds, feed rates, tool overhang, Wasn't pretty in the early stages but I got the job done.
Chatter is work in progress. However I'm getting a tap when parting off 30mm delrin that disappears as the tool gets further in.
But for some reason the chuck jaws are out, #3 jaw is loose and about 0.3mm further out when loosely wound together, test rod run-out can be anywhere between 0.04 and 0.25mm by loosening and re-tightening the chuck.
I've stripped the chuck, washed and blown it out, bit crud, no lumps of swarf just grimy. And 'factory spec rust' on the back of the scroll gears.
Reassembled, 0.02-0.03 run-out on the spind;le /chuck body again but the #3 jaw is still slow and workpeice run-out still suffers random centering.
Was waiting for a new tool to arrive in order to finish off a couple of bits and I had to dial them in but repeatability has gone right out of the window
Thread: Button / ball oilers
23/05/2022 18:34:19
I've been using the supplied oil can which bypasses the seal and puts more oil through the trigger/pump pin than the tip and a plastic syringe with a 90 degree tip to get to two that are rendered otherwise inaccessible by the Y axis DRO scale.
TBH with a 20% OE fail in three weeks (not thirty years) I was looking for alternatives at least for the ones that don't need to be flush
23/05/2022 13:24:13
Obviously searched and found press button / ball etc. Easy to remove and retrieve the bb with a magnet.
Two have dropped the ball (boom boom) on my Amadeal , one on the lead screw bearing and one on the cross slide.
Besides replacing them with more of the same (box 6mm -100 £20) can the easily accessible ones be replaced with small oil cups?
I was looking to replace two blocked by the DRO scale with 90* grease nipples but the supplier wanted £9 odd postage for a £4 purchase.
Thread: Oil can (again)
19/05/2022 21:42:30
Posted by Gavlar on 19/05/2022 20:59:48:
I've got two reilangs. I bought them because everything else forced itself apart under the hydraulic pressure they encountered when used on the numerouse ball oilers dotted around my machines. They haven't forced themselves apart, which is something but they leak as much as the next can and the pumps constantly jam, needing to be jiggled about (I think that is the correct technical term) to get them to function. Not worth the money I paid for them, in my humble opinion.
Interesting,,not infallible but unlikely to self destruct,
19/05/2022 18:29:24
Posted by Mike Poole on 19/05/2022 16:55:34:
My Wesco must be close to 50 years old now and I used to keep it full of 20/50 motor oil as it could pump oil through the rocker shafts of my Trident when reassembling the head and give a good squirt to everything that was going to wait for the oil to arrive on first startup. A Reilang is filled with 32 weight hydraulic oil for Myford general oiling but a Tecalimit oil gun does all the nipples. None of these could be claimed to be oil tight but the Reilang returns the oil that dribbles down the outside of the spout to the tank so the outside of the tank stays relatively clean to handle. My hands seem very tolerant of oils but many people are vulnerable to dermatitis and the thin membrane gloves offer protection and may be the only solution, a dusty oil can I am sure does not exist.
I have gloves but honestly can't say that I reach for them first, I have suffered from mild dermatitis but thats dry cardboard related- years of working in warehouses.
As such not a problem with oily hands, motor, oil, gun oil (hmm Ballistol) the slides run a lot smoother on iso 32 hopefully that won't cause any longer term issues.
Looks like I may hit the button on a Reilang, I think there's an old Wesco in the shed ..somewhere behind the chainsaws.
19/05/2022 15:21:46
Not Done it Yet
yes, an annoying design / installation oversight
SillyOldDuffer / Nick Wheeler / Samsaranda
It's oil and oil cans are well...oily laugh
A 'drip' would be heavenly compared to a handful.
something to consider with your sons install - I haven't taken the oportunity to see if the scale can be moved.
I've looked for 45* / 90" drive fit nipples for the beds, choice is limited guess I can modify some threaded ones ...I have a lathe now.
Jon / Clive
Probably won't be chasing vintage cans or making new/repros. Humbly ..a good working oil can 'a' drip after use will be fine (for now)
19/05/2022 09:39:44
The oil can supplied with my Amadeal is utter rubbish, I've adjusted the seal several times and its impossible to stop oil coming out through the trigger pin.
I have had more oil on my hand, the bench and floor than the in machine and it's only through bare necessity that I haven't thrown it out the door.
Would purchase one of the £8-10 cans on the bay-of-evils ..there are many sellers to choose from but having purchased various items feel quality can be bit of a lottery.
I've searched the threads and Reilang appears to be a popular choice, are they 'that' good?
Are there various tips available? the cross-slide DRO scale covers the saddles r/h/s s ball oilers and I would really need a short 90 degree bend at the tip.
Guess the answer would be adapt or make one ?
I've initially overcome the can and access issue buy using a 20ml syringe and blunt #10 - cheap as chips and effective but longer term (if not a suitable can & tip) would be some low profile 90* nipples.
Thread: threading delrin - alternative method
18/05/2022 15:46:27
Posted by not done it yet on 18/05/2022 10:56:22:
Posted by Steven Francis on 17/05/2022 23:21:03:
Posted by not done it yet on 17/05/2022 22:44:07:
To make perfect-fitting feed screw nuts, the “heat’’n’squeeze” method works well.
Might this method be suitable for this application?
Searched ...ah yes backlash.all round.appears to be part of the 210s specs.wink
I have some aluminium -
Yesterday I turned the shed upside down looking for a bag od 50x75x1.5 mm aluminium strips, unable to find those ..I cut and ground flat some 3mm & 5mm plate.
Today I found the aluminium ...it wasn't in the shed.
Sorry. Don’t see any connection to my suggestion.🙁. Please explain….
apologies, new forum- different format, should have been a multi-quote, aluminium waffle was directed at Clive.
Not allowed to right click copy and paste.to start with
I guessed you meant something to do with half-nuts ( I'm learning quickly) but otherwise had no idea of what you were on about,until I searched the forum.
I honestly don't believe there is part of this machine without some level of backlash..that wouldn't need some kind of skills and experience currently beyond me or perhaps even warranty voiding modifications.
.I'm very doubtful of the boxes ticked and tolerances quoted by QC although with time and patience I will get closer to them.
17/05/2022 23:21:03
17/05/2022 17:38:09
Came up with a technical issue - with the 8mm (min 11m i/d) indexable boring bar and for that matter the screw cutting tool.
The tool-post is too low to put the tools in the centre of the workpice, messed about making shims to get the tool to the top of the post and was still about a mil out.
Shims under the tool post?
