Here is a list of all the postings dave batcheler has made in our forums. Click on a thread name to jump to the thread.
Thread: help with limiter switches and vfd |
09/06/2022 06:44:23 |
thanks dc31k for the info. yes i need it to stop but im happy to move the blocks that pick up switches to allow more distance before running out as i would never mill anything that long i hope.. lol.. there is the wired to stop setting in the options which i will try to as well as yours . cheers dave |
08/06/2022 21:19:27 |
hi all Im after some advice please. i have a tos olomouc f2v running a vfd straight to motor. the problem is now i have another vfd xsy-at1 to run the xyz motor for bed. which works fine. but i want to use the limiter switches which are normally closed. I've daisy chained them to make a circuit and was going to wire into com port and x1 on inverter and then program for the port as stop.but the problem is the ports are a switch ie button to stop or start. is there any way i can keep limiters and still use ports with a relay or and thing else. sorry its long winded cheers dave |
Thread: hi from durham |
23/03/2022 21:41:06 |
hi all. into my dragbike racing have a couple of lathes. ml7 and a boxford recently brought a big mill tos f2v and will be asking loads. cheers dave |
