Member postings for Russell Allsop
Here is a list of all the postings Russell Allsop has made in our forums. Click on a thread name to jump to the thread.
Thread: Mini Lathe Ways Lapping
03/07/2023 10:52:13
Thanks for the comments, in order to improve the rigidity of my mini lathe I'm trying to eliminate any play while still having free movement, based on your feedback I have slackened off the bolts holding the plates a tad, there is a small amount of play on the carriage now but the carriage moves freely across the ways.
30/06/2023 11:55:51
Stripped the carriage of my VM210 mini lathe, re-assembled and shimmed the plates holding the carriage onto the ways. The carriage hits a high spot in the center of the ways, would lapping the ways with grinding paste be an option to level the ways to the carriage and is there a specific technique involved?
Many thanks for your advise.
Russell
Thread: Bench Grinder Bush
06/06/2023 07:44:02
The bush is 70mm diameter and appears to be a plated casting, based on the advise received I will make a identical bush out of aluminium (easier to machine on my mini lathe) and proceed with caution for the first run, many thanks for the advise.
05/06/2023 12:17:40
img20230605090004 (1).jpgThe bush/clamping plate on my bench grinder broke when trying to remove one of the wheels as pet the attached pics.
I'm thinking of machining a new one can someone advise me as to the following;
1. Can the part be made out of aluminiun or brass
2. Do I need to replace the part on the other side in order to balance the grinder
3. How tight should the nuts be holding the wheels on the grinder shaft.
Your advise would be appreciated.
Thread: Multifix Tool System
16/02/2022 07:09:43
I have recently bought a VM210 mini lathe, 210 mm swing. Looking to buy a QCTP would the multifix system be a better option than a wedge type?
