Here is a list of all the postings Philip Coupland 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: (Another) Mini Lathe Speed Controller Problem |
07/03/2022 18:53:11 |
Posted by Ian P on 07/03/2022 17:13:31:
Philip, I'm thinking that one of the industrial sewing machine motors would be ideal to put on my X1 mill. Please could you say which actual model you bought as there seem to be two or three different versions.? I wonder if any have adjustable accel/decel times like a VFD..... Ian P
It’s a Jack 563A - available in the UK for around £150. I don’t know the answer to the question about the adjustability but there are a few videos on YouTube. |
04/03/2022 19:36:11 |
![]() With regard to keeping swarf out of the control board, there should be a "rubber" grommet to fit in the slot around the Leadscrew. Arc Euro list it as C3-256 priced at £3 (plus postage ) If you have not got one, it would be worth fitting one to reduce the risk of expensive failures. Howard Hi Howard, I’ve no longer got the control board installed. Although I intend to do a little more work to protect the workings from swarf, the Jack sewing machine motor and ancillaries are all well sealed, much better than the original lathe set up. Edited By Philip Coupland 3 on 04/03/2022 19:36:47 |
03/03/2022 18:58:23 |
An epilogue… It turned out that the motor was damaged too, so I decided to adopt a suggestion made on the forum to fit a sewing machine servo type motor instead. This was cheap and not hard to do and has permitted me to upgrade from the feeble 400W motor to a 750W unit. The speed controller supplied for the sewing machine works well too. I haven’t finished the installation yet, there being some bodywork and other things to do but testing it today I found it worked very well. In fact, together with the new roller bearings for the headstock spindle the lathe is transformed. For example, parting off, which was usually a horrible experience, was done very nicely. |
17/02/2022 09:50:11 |
Posted by John Haine on 17/02/2022 09:37:23:
Motor controllers don't necessarily react happily to the circuit to the motor being interrupted whilst running, your fuse could be a bad move... Hello John and thank you for your comment. The manufacturers of the board say that: 'It is recommended that both AC line and armature fuses be installed'. I interpreted the latter as meaning a fuse in-line with the positive power wire to the motor - is that incorrect? |
17/02/2022 07:44:39 |
Posted by oldvelo on 17/02/2022 06:11:21:
Hi There is a correct way to tune the circuit to match the motor but not for the faint hearted or inexperienced. It involves locking the motor rotor and setting the Amperage output to be LESS than the maximum of the motor rating by adjusting the correct Potentiometer. I have the manual for adjusting a KB circuit on file. PM me for a copy if you want use it. I Strongly suggest the you have the setup performed by a qualified Electrician with the proper equipment to do the job safely. One modification to a DC motor drive I keep on banging on about is to fit an Amp Meter to the motor leads to measure the motor amps under load. Use this to set the power feed speed to be able to read that the power used is less than the motor output to prevent overloading. A photo in my album will explain it better. The motor leads also have fuses on both motor leads Edited By oldvelo on 17/02/2022 06:27:57 Edited By oldvelo on 17/02/2022 06:28:21 Thank you again OldVelo. I think the manual you mention is one that I've found on the manufacturers site (https://acim.nidec.com/drives/kbelectronics/-/media/kbelectronics/documents/dc-drives/manuals/kbic_manual.ashx?la=en). I expect that I'll have a go, after I've marked the starting positions on the 'trimpots'. My comment about my electronics education having stalled at the batteries and bulbs stage is the literal truth - I remember struggling and failing to understand the working of resistors in the Ladybird Book of the Radio. However, despite not having a brain that likes maths, I can follow a recipe (although perhaps not if translated from Chinese). I'll have a look at your photos. I have already fitted one fuse to the + power lead to the motor. |
16/02/2022 20:54:06 |
Posted by Les Jones 1 on 16/02/2022 20:07:51:
I would NOT advise adjusting any of the potentiometers. Have you got the correct horsepower resistor to match the power rating of the motor on your lathe ? If the value of this resistor is too high it will limit the current (And hence the torque.) to too low a value. I am surprised the board works as well as it does after such a fault. Les. Thanks Les. Yes, the resistor is identical to the one that was blown. I was surprised too that everything seemed fine until I put load on the motor. The bearings aren’t tight in the headstock - they turn easily but I found that when released the locknut in the spindle the speed certainly increased although still not within the normal range. |
16/02/2022 18:12:07 |
An update. The replacement KB Electronics horsepower resistor that I ordered yesterday from the helpful and efficient Axis Controls of Southport arrived this morning and I fitted it this evening. I’d checked the motor for any more shorts and tested the board first just connected to a voltmeter. When powered up, turning the potentiometer caused the voltage to increase and then when I connected the motor (detached from the lathe) that also speeded up to a high rate in response to the control. However, we are not quite there yet. When the motor was reinstalled and the drive belt fitted, I found that it would not speed up more than a little. It will certainly be encountering some more resistance than previously because of the new roller bearings fitted and perhaps the new metal high-low gears that I’ve replaced the plastic ones with. But the bearings haven’t been over loaded. What I’m wondering is whether this is something that can be resolved by an adjustment on the circuit board or does it indicate that there are further electronic components that require replacement? Once again, thanks to all who’ve contributed to this thread.
15/02/2022 19:40:00 |
The suspected culprit - next to the bearing
15/02/2022 19:34:37 |
I’m very grateful for all the helpful contributions made - thank you gentlemen. I made further investigations this evening and found a possible cause - a curly piece of swarf, which had got in the back of the motor and was making a contact between one of the brushes and the casing of the motor. Happily the motor seems to be still in working order and spins happily with a 12V DC supply. Once this electrical problem is resolved I’m going to ensure that the motor is properly separated from such nasties. Incidentally, I wonder if there is any benefit from adding a fuse in-line with the positive supply wire to the motor - would that prevent this happening again? The plan at them moment will be to try out the replacement resistor when it arrives. If that doesn’t work I shall probably have to buy either a replacement board or I may buy a complete control box (Amadeal) as its not a huge amount more and will avoid any problems with wiring in a board that may have different connections to mine.
15/02/2022 09:29:39 |
For future reference, a full range of horsepower resistors is available from Axis Controls in the UK (https://www.axiscontrols.co.uk/). I've ordered one and we'll see if it brings my lathe back to life. Its a plug-in so I won't even need to get the soldering iron out. |
15/02/2022 09:18:04 |
Posted by oldvelo on 15/02/2022 03:51:29:
Hi The control board looks like a KB Electronics AC to DC motor variable speed control. The white rectangular block is a horse power restrictor The component that was damaged was probably fitted for some reason piggy back in parallel to the hp resistor. Spares and an extensive range of information is available from KB Electronics. Another source is available from Surplus Center Click on the link Surplus Center have spares available to match the motor horsepower. I have used Their Minarik control on DC motors and found the satisfactory once setup to match the motor power Edited By oldvelo on 15/02/2022 04:00:16 Thank you OldVelo. With your information, I've identified the blown part as a 'plug-in horsepower resistor (9838)' from KB Electronics. These are available in the US although the cost of shipping and import tax seems excessive. I'll see if I can find them in the UK. |
15/02/2022 09:00:42 |
Posted by Ian Parkin on 15/02/2022 06:55:01:
On the photo is that a piece of curly swarf just under the resister framed by the red wires? Hello Ian, well spotted! Despite my efforts to keep the workshop tidy all manner of swarf, splinters, chippings gets everywhere. It's a very small space and bits go everywhere. Later today, I'm going to thoroughly check the output to the motor for shorts - it would be a relief to find one and know the cause of the problem. |
15/02/2022 03:23:35 |
Thanks. Yes, I must find that fault - the scenario of another blown board is something I’d prefer to avoid. I’ve been tempted by the idea of a new machine but will persevere with this one for now. I’ve put quite a lot of work into it, to make it work properly. I’d really like to get a secondhand Myford but there’s no space for it. Philip
Posted by Huub on 14/02/2022 23:03:58: Posted by MikeK on 14/02/2022 22:50:31 […] this can be an expansive repair. If you can't find the cause the new board will probably also be gone in seconds. You could change te motor and control by an AC motor and VFD or an AC Servo motor and AC servo controller. I know it is not the cheapest option but it has to be considered if you can't find the cause. I do not know how old and worn the lathe is, but maybe is replacing the lathe also an option.
15/02/2022 03:15:12 |
Thank you Mike I agree, definitely a symptom, most likely of some fault introduced by moving things around while I was working on the headstock. I’m a careful worker but something must have been compressed or detached. Yes, a new board looks likely. I’ve had the machine a long time and it was secondhand - Id guess its probably 20 years old. I’ve only been using it intensively for the last two years but still this pretty good service from a cheap lathe. Philip
Posted by MikeK on 14/02/2022 22:50:31: That blown component is likely a symptom, not the problem...Something else failing would have caused that component to fry. I just looked at the control board for my own mini-lathe and it also has one power resistor like yours (which is probably what yours is). Diagnosing and fixing this is going to require someone with electronics experience, and equipment, though. I'd help you out if you were near me, but...you're not. Looking at the back of the board may give clues for other fried components. Also, looking at the top side carefully. Capacitors are common culprits in switching circuits, as cheap Chinese ones eventually fail (although mine haven't) and this causes further components down the line to fail. But, again, this would require testing. You might get lucky posting on the groups.io minilathe group...Perhaps someone had the same thing happen and found the bad component. But my guess is that you're going to wind up buying a new control board. -Mike
15/02/2022 03:04:57 |
Thank you Les, that is very helpful information. I shall look carefully for the source of the short in the output to the motor. Everything was working fine before I removed the controller box from the side of the lathe and, as I mentioned before, I just unscrewed the box but left all the wiring untouched while I worked on the mechanicals. This suggests that either some wiring has become physically damaged or a perhaps a piece of swarf has caused a short. That’s a very good website that you linked to. Philip
Posted by Les Jones 1 on 14/02/2022 22:41:32: I think the component WAS a ceramic resistor that is used to sense the motor current. I think the output connections to the motor must have been shorted out putting the full rectified mains voltage across it to cause it to fail in the way it has. I think the board is a KBLC speed controller board and the resistor that has failed is R21. This is a link to information on the board. Les. Edited By Les Jones 1 on 14/02/2022 22:50:45
14/02/2022 22:01:32 |
Posted by Andrew Johnston on 14/02/2022 21:42:28:
There is a picture of the board in the OPs album. It's a rather odd component, apparently on its own PCB. It's definitely flipped its lid. Looks a bit like a power resistor, but why 120V? Alternatively it could be a MOV. It would help to know if the OP is in the UK or the US? Andrew I’m in England.
14/02/2022 21:41:41 |
Thank you for the guidance on posting pics. Here is the smoking wreckage below - the broken off piece came off the back of the rectangular white component. One question occurs to me to ask is why is so much electronics necessary to control the speed of an electric motor? For example, an electric drill usually has the facility to control its speed without all this. |
14/02/2022 19:51:11 |
To briefly introduce myself, I’m hobbyist whose metal work interests are mainly related to motorcycles. My tiny workshop is crammed with many machine tools, including the lathe that is the cause of this request for help. I have recently added roller bearings to the headstock and wanted to test the running of the drive belt so plugged it in but on turning the machine on there was a flash and a pop and that was that. On closer inspection inside the control box it was found that a large rectangular component marked 120V had the back blown off. I don’t know what this component is, my knowledge of electronics having stalled at the battery and bulb stage. I hadn’t touched the electronics at all, merely unscrewed the control box and moved it to one side, leaving everything connected apart from the two earth wires going to the headstock, which I had reconnected. I’m wondering if I could replace blown component (assuming I can identify it and find one) or is it likely that a whole lot of other stuff is gone. I’m also concerned to find out what’s caused the problem - if I end up spending a fail amount of cash on a new circuit board I don’t want to ruin it as well. With thanks, Philip C PS If I can figure out how, I’ll post a pic
