Here is a list of all the postings Roy James 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: Operators manual |
15/05/2022 13:32:06 |
Hi all, can anyone help me please after many hours of searching I found an online PDF of the manual for my MX-600A mini lathe and I saved it into ‘notes’ but, somehow I deleted it. I have spent hours and hours searching for it online with no success, does anyone have an online copy and can send it to me or a link where I must have found it originally. Many thanks in anticipation. Roy |
Thread: QC tool posts |
01/02/2022 15:45:09 |
Hello again guys, I have now modified things so I now have the QC post from my original lathe and all works well I have 10mm bits that I use in it but when I have to replace them I will upgrade to 12mm, my old QC will allow this. I can also easily change back to the larger QC if I want to very easily. I only bought the 16mm tools because I was (and still am) ignorant of what I needed, and as the new toolholder that is original to the new lathe and as it was a 10mm toolpost I thought it dictated using the larger tools. On my old lathe I bought 8mm then 10mm tool bits but of course I kept having to shim up with both sizes and was pleased when I found out about QC and why I thought it would be good to do the same on this new lathe because I still have to shim up the 16mm tools only a thin amount but still annoying. I do agree I like the bigger tools because as Vic says the small sizes are not very strong and with the 8mm I was ever knocking the cutting edge off, I know it’s because of too fast feed but as I said at the beginning this is all very knew to all this and had no-one to turn to for help, I am learning slowly. thanks everyone. Roy |
01/02/2022 09:41:19 |
Thanks JohnC, much appreciated for your reply, and the pointer to Arc EuroI know where I am going now. regards Roy |
01/02/2022 09:36:52 |
Good morning Thor, good morning JasonB thank you both for your replies it is appreciated. its not so much the size of the tool as much as wether I can use the QC 250-200, the current fixed toolpost which came with the lathe is a 16mm holder and a 5” chuck so I bought 16mm tools for it and since they were not cheap I do not want to discard them. However having revisited the situation and reading your comment about why do I need 16mm tools on a hobby lathe, I think I will modify the toolpost site and use my original 250-000 which I have a full set of QC for, thank you, your comments did definitely help.h What I save on the new toolpost will buy new tools, and I can use the 16mm if needed in the old holder It’s good to have friends. Warmest regards. Roy |
31/01/2022 21:10:21 |
Hi guys, I am an old newbie in need of some help. I don’t have a history in turning but a year ago I bought a small secondhand metal turning lathe, I found it very interesting to use and I have started to understand what I could do on it. But I soon outgrew it and bought a new bigger one, I bought a “Crenex 220 x 600mm” (yes I know) I already knew that it would come with problems, probably more than I expected but I have spent quite a bit of time resolving most of them. What I need advise about is buying a QC toolpost, I equipped my old lathe with one and found it excellent, now I want one on the new one I want one which takes 16mm (5/8&rdquo Any help please would be appreciated, Roy |
