Member postings for Noel Muirhead 2
Here is a list of all the postings Noel Muirhead 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Electrical calculations
09/03/2022 08:06:12
Thanks again I am scratching my head as to why I didn’t see it how ever the problem is solved I have ordered a 24 volt AC relay and a Block transformer from RS Components the transformer is coming from overseas I also have to import the KB DC drive as the 230 volt DC model is not stocked in NZ. When completed I will report how successful the modification is it will still be cheaper than purchasing a new power feeder and I will be able to get parts.
Noel
08/03/2022 02:25:28
I have this link to article it is very similar to what I intend to do, if you take a look at the circuit diagram or page 10 I wonder how he operates the 24 volt DC relay with 110 volt AC transformer.
Noel
06/03/2022 05:26:18
Something else I was trying to size AC transformers I hadn’t twiged the relay coils were DC thanks for jolting my memory.
Noel
05/03/2022 08:56:53
Thank you all so much for all the help, my workings were on the right track you all have sorted it for me I am sorry I didn’t say that the 24 volt coil is DC and is going to be PCB mount I can buy a 240volt AC 24 volt DC regulated PCB mount transformer up to 5 watts from RS components or incorporate a rectifier in the circuit board that’s the cheapest option only problem is not to much space to work with.
Noel
04/03/2022 07:17:07
I’m stumped perhaps it is age related,l am modifying a Seig sx3 dc power feed and can’t work out the size of of the 240v 24v transformer to operate a 24 v 550 mW coil on a relay. Ask me to make or fix something no problem just cant get my head around this.
