Member postings for Tim Gosling
Here is a list of all the postings Tim Gosling has made in our forums. Click on a thread name to jump to the thread.
Thread: Replacing a bushing
06/09/2021 12:04:31
Thanks pgk, I completely missed that when I searched before. I'll contact them.
05/09/2021 11:40:55
>Have you tried looking for a manual/parts diagram on the web?
I don't think it's a very well known brand. It's called a Sprint Elite XZ1 and when I google that all I get is someone in Dundee selling one for £50 back in 2014
Edited By Tim Gosling on 05/09/2021 11:41:13
03/09/2021 10:21:41
All measurements were made with a digital caliper. It's an inexpensive one but I think it's accurate. The OD measurement is the bush not the flange, the flange OD is 28mm.
Not sure what they're made of, I agree that does look like rust.
5/8" x 15/16" sounds close enough to me. It's a cross trainer not a nuclear reactor so I can live with a bit of play. Worst case scenario is I fall off it.
Googling 5/8" x 15/16" Bushing comes back with quite a few suppliers, mostly in the US. I'll email some of the UK suppliers first but if I have no luck I'll buy from abroad.
Paul I like the way your mind works, suppliers balancing cost of production Vs being the only source of spares Vs deliberately making their old products unrepairable. It has a ring of truth. Or maybe spending time reading internet forums has made me a conspiracy theorist
02/09/2021 12:04:41
Hi all,
I'm trying to fix my trusty 10 year old cross trainer. There are some bearings that are quite worn which I think are called bushings. They push fit into a steel tube and a steel shaft runs through them. Because they are so worn on the inside I have measured the shaft diameter instead to get an inside diameter for them. The measurements I've taken are:
Internal diameter (diameter of the shaft) 15.4mm
Outside diameter 24mm
Length 17mm
There's also a flange on one end and a notch cut into the side.
I've googled bushings and found a few websites like BearingShopUK, SimplyBearings, BearingBoys etc. but none of the bushings they sell quite match what I need.
So my questions are, is this a non-standard size or possibly an imperial size or perhaps this isn't called a bushing and I'm googling the wrong thing?
