Here is a list of all the postings Richard Kent 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Proxxon Micromot 60 Drill Went BANG!!!! |
08/06/2022 00:01:26 |
peak4 - Bill, I have seen that review before.
07/06/2022 22:00:43 |
@peak4 - Bill, The middle 'polarising' pin simply fits into a hole in the plastic casing of the PSU and is not electrically connected, nor does it operate any kind of switch. See photo below..............
Edited By Richard Kent 1 on 07/06/2022 22:14:13 |
07/06/2022 19:48:04 |
07/06/2022 19:15:03 |
Maurice Taylor - Great observation - never considered that until you said it - Perhaps you should put that suggestion to Proxxon. By the way these tools run at between approximately 12V-18V depending on the speed setting. Disclaimer: This is NOT engineering advice so do not UNDER ANY CIRCUMSTANCES follow what I do!
Edited By Richard Kent 1 on 07/06/2022 19:18:08 |
07/06/2022 18:49:27 |
Maurice Taylor - You're welcome. I hope that helps. Edited By Richard Kent 1 on 07/06/2022 18:50:01 |
07/06/2022 18:30:10 |
SillyOldDuffer - You quoted ............"Only Proxxon know why they fitted a 1uF electrolytic, and they are therefore are more likely to get it right than Richard's suck it and see method or my guesswork."
I've heard WORSE from BETTER
Disclaimer: This is NOT engineering advice so do not UNDER ANY CIRCUMSTANCES follow what I do! Edited By Richard Kent 1 on 07/06/2022 18:57:12 |
07/06/2022 18:12:34 |
@Maurice Taylor - Maurice, see below. You also have the option of swapping out the collet system for a 3 jaw chuck.
See photos below of the connector..............
Edited By Richard Kent 1 on 07/06/2022 18:23:10 |
07/06/2022 17:45:46 |
Posted by Jon Lawes on 07/06/2022 17:43:07:
That connector does seem a bit of a silly design.
07/06/2022 16:06:35 |
Russell Eberhardt - Russell, thanks for your input. I thought the same as you --- "However, Proxon must have a good reason for using a 1 uF capacitor in the first place" As for the voltage rating. The higher the better within reason.
Edited By Richard Kent 1 on 07/06/2022 16:34:18 Edited By Richard Kent 1 on 07/06/2022 16:36:30 |
07/06/2022 14:54:27 |
Emgee - If I was YOUNG and CLEVER like you I would never have put that connector in the wrong way
Edited By Richard Kent 1 on 07/06/2022 15:00:31 |
07/06/2022 14:20:50 |
My Proxxon Micromot 60 Drill Drill Went BANG!!! As you can see from the photos below, it is easy to insert the power connector in reverse which causes the original 1uF Electrolytic Capacitor to go BANG! Not only does this scare the life out of you is also means there is no suppression capacitor on the motor which results in a less smooth and noisy motor. Simply replace the original capacitor with a high quality 100nf Polyester film or Ceramic Capacitor which are non-polarised (Also know as a 104 capacitor) I found a 100nf capacitor to work best and this is a standard value for small DC motors. Choosing a non-polarised capacitor will ensure that if you make the same mistake in future your Proxxon drill/grinder will simply rotate in reverse Photo below shows the 1uf Original Electrolytic Capacitor next to the New 100nf Polyester Film Capacitor. Disclaimer: This is NOT engineering advice so do not UNDER ANY CIRCUMSTANCES follow what I do!
Edited By Richard Kent 1 on 07/06/2022 14:26:15 |
Thread: A Quick & Easy Way To Sharpen Your Tig Electrodes Using A Proxxon Micromot 60 Grinder |
04/06/2022 16:24:41 |
Colin Heseltine - That looks great I was going to purchase something similar on ebay made from solid aluminium but I wanted something with a larger 40mm disc due to the extra lifespan better m/s rating. I also had some 40mm discs in stock. But once again, your device looks great
Disclaimer: This is not engineering advice so do not UNDER ANY CIRCUMSTANCES follow what I do or say
Edited By Richard Kent 1 on 04/06/2022 16:45:58 |
04/06/2022 13:57:27 |
Posted by Mark Rand on 04/06/2022 13:54:17:
I use my Lidl 'Parkside' tool in preference to my dremel. Half the price and twice the quality!
I'll have to get The Moderator in on this one!
Edited By Richard Kent 1 on 04/06/2022 13:58:37 |
04/06/2022 12:53:27 |
Posted by Hopper on 04/06/2022 12:28:45:
Bolle goggles and diamond wheels. Swish crowd here tonight. Edited By Hopper on 04/06/2022 12:47:29 Proxxon Mini Grinder too! Only the best here! Don't even talk to me if you own a Dremel!
Edited By Richard Kent 1 on 04/06/2022 13:09:05 |
04/06/2022 10:27:52 |
Hopper - See disclaimer below and I recommend you do your own research................ Disclaimer: This is not engineering advice so do not UNDER ANY CIRCUMSTANCES follow what I do or say
Edited By Richard Kent 1 on 04/06/2022 10:55:12 |
04/06/2022 10:23:42 |
Joseph Noci 1 - Try sharpening at different angles and see what works best for you. I use this tip angle for welding up to 160A with a water cooled setup and the results are excellent. If you are using a non-water cooled setup then the electrode, collet and collet holder will suffer heat degradation issues. My overriding advice is to try different options and see what works best for you.
Edited By Richard Kent 1 on 04/06/2022 10:24:21 |
04/06/2022 10:15:57 |
Posted by Mark Rand on 04/06/2022 09:48:23:
Big advantage is that you don't end up with a wheel on the bench grinder that's got grooves all over it. You're right Mark. I used a bench grinder for years and that was exactly what happened. When using these small diamond discs ensure you set your mini-grinder speed to 20,000 rpm or above as it tends to grind more efficiently.
Disclaimer: This is not engineering advice so do not UNDER ANY CIRCUMSTANCES follow what I do or say Edited By Richard Kent 1 on 04/06/2022 10:30:23 |
03/06/2022 22:33:06 |
@Baz - He (moderator) has a rule book and a big stick if you do that Edited By Richard Kent 1 on 03/06/2022 22:39:58 |
03/06/2022 21:29:50 |
@Andrew Johnston - I've heard worse from better Edited By Richard Kent 1 on 03/06/2022 21:39:48 |
03/06/2022 20:37:03 |
A post which might be of some use to Tig enthusiasts...............
Edited By Richard Kent 1 on 03/06/2022 20:38:20 |
