Here is a list of all the postings Roy Kavanagh has made in our forums. Click on a thread name to jump to the thread.
Thread: Winson 14xx loco |
10/05/2021 15:12:31 |
Hi all. Im a 7/14 steam man but recently a local neighbour approached me about a Winson 14xx kit he had aquired which was performing very badly. It was unable to start by itself and when it did there was no power in the pistons. There are no adjustments on the eccentric lead and lag so that was fixed, Following a suggested strip down of the cylinder blocks and the steam chest it was found that the slide valves were A to big and B to far away from the cylinder block face. This in the case of A wasnt allowing the steam to get into the port slots to drive the pistons and in the case of B as the valves sit verticle theywere allowing the steam to escape past the face of them as there was a 1/16 of an inch gap between the valve base and the cylinder face. To save any problems with the original slide valves a new set was made 1/16th of an inch narrower on both sides and the face was made 1/32 thicker facing the cylinder face . THis ment that as soom as steam was applied the valve flipped against the cylinder face and also allowed far more steam to enter the ports The result was a total change in the performance giving instant starting and full power. Hope this helps anybody. cheers Roy |
