Here is a list of all the postings David Herrington has made in our forums. Click on a thread name to jump to the thread.
Thread: Ml2 |
06/05/2021 21:44:41 |
Hi it looks like the same thing has happed here, the pointed grub screw has damaged the shaft. I will have to remove the damage before proceeding, can you tell me is the small gear part of the pulley assembly |
06/05/2021 21:01:52 |
Roy i have checked and there are no more grub screws in the holes, the large gear wheel spins freely but the pulley and small gear does not spin |
06/05/2021 19:22:00 |
Hi I have just bought a ml2 for a restoration project and I want to strip down the headstock, I have removed the grub screws from the pulley and bull gear and removed the threaded collar on the left hand side and undone the top clamp screws, with a soft mallet I tapped the left hand end to drive out the spindle , it moved about 5 mm that’s all, any ideas please |
