Member postings for Phil Meaken
Here is a list of all the postings Phil Meaken has made in our forums. Click on a thread name to jump to the thread.
Thread: New car - or is it a wheeled computer?
08/04/2021 09:51:34
Posted by Howi on 08/04/2021 09:24:21:
Posted by Phil Meaken on 26/03/2021 15:26:33:
Posted by Journeyman on 26/03/2021 14:21:42:
A digital toaster simply makes toast either uncooked or charcoal ie. 0 or 1
I always thought that it either toasts or does nothing; if nothing, you throw it away and buy another.
I'll stick to our Dualit; 1947 to present design and completely free of electronics.
Mike.
You might just be surprised if you look inside one............
I have done a few times over the years, Howi, but only found a switch, elements, leads and a spring-driven timer surprise
07/04/2021 15:22:46
Posted by Howard Lewis on 26/03/2021 09:31:08:My wife and I each run probably some of the smallest and cheapest cars on the market.
One of the features is a speed limiter.
My wife has one of the smallest and cheapest cars - it can easily be repaired, parts will always be available, does 50 mpg, speed limited to 75 mph and will never depreciate.
What is it? A Citroen Dyane. face 1
26/03/2021 15:26:33
Mike.
26/03/2021 11:45:03
I sorted this out years ago by never getting a newish car. I have a Citroen ZX diesel from the 1990's, my wife has a Dyane made in 1981. These will last as long as we do, they are easy to service, don't depreciate in value and new spares will always be around.
We've had a Dyane from the 1970's and have travelled all around Europe with complete reliability and comfort, packed full of camping gear!
New cars are scrap after about twenty years and cannot be repaired properly.
Thread: Pictures in posts and font sizes.
20/03/2021 11:25:47
Posted by Anthony Knights on 20/03/2021 09:24:41:
Posted by Phil Meaken on 19/03/2021 10:04:50:
Thanks to all, but most ways seem to need too much of a long-winded faff or need extra packages to be installed, so I'll just not bother with graphics until the ME software is updated.
As for text, indeed I do most in LibreOffice and Copy and Paste into here
The code to download imagemajick is 10 words. The code to change the image format is 5 words. The OP's post above is 50 words. What long winded faff?
Actually getting a JPEG image off your computer and into a post on this site is currently a much bigger "Faff"
As I said, Anthony, I'll leave it until the software on here is updated. I did briefly try imagemagick as I said earlier, but got nowhere - one reason is that using images with Linux on this laptop has problems, other is there are reasons due to how my brain works which I won't go into.
19/03/2021 11:45:19
Posted by Russell Eberhardt on 19/03/2021 10:35:21:
"Nonetheless, provided you know what you're doing, command line methods often faster to invoke and more efficient in operation."
Agreed Dave. When I first started using Linux (in the mid 1990s with Red Hat Linux) I spent many happy hours with the manuals and still occasionally refer to Blum's 800 page "Linux Command Line and Shell Scripting Bible".
Russell
Russell, that book looks like just what I need, so I've ordered it via Amazon.
The LibreOffice "Getting Started Guide" which I got a few years ago I found wasn't that good, albeit being quite long. If only it had an index ...
19/03/2021 10:04:50
As for text, indeed I do most in LibreOffice and Copy and Paste into here.
Thread: Making hexagon nuts on a rotary table & mill.
19/03/2021 09:55:51
I've ordered one (for my 3-slot rotary lable).
18/03/2021 16:15:38
Posted by Phil Meaken on 18/03/2021 16:08:45:
Posted by Nick Clarke 3 on 18/03/2021 15:05:37:
Regarding small fonts there is an icon 4th from the right in the upper toolbar of the post editing window that looks like a rectangular bar in perspective or, if you have that kind of imagination, a pencil eraser.
Selecting your text and clicking on this will publish your text in the standard size and font.
Trying that now, Nick.
It just says :Remove format" sad
18/03/2021 16:14:02
Posted by Peter Greene on 18/03/2021 15:54:44:
Posted by Fowlers Fury on 18/03/2021 15:46:02:
If you're one of the myopic dinosaurs like me using Windows and a wheeled mouse, then hold down the Ctrl key and rotate the mouse wheel.
Is it just me or does anyone else find the operation of this counter-intuitive? When I rotate the mouse wheel towards me I expect the text etc to "come towards me" i.e. get bigger. Instead it gets smaller. .... and vice-versa.
I'm certainly one of those, but as my laptop is probably just as ancient, I use Linux and a floaty mouse!
18/03/2021 16:08:45
18/03/2021 14:57:13
Posted by Thor on 18/03/2021 12:47:32:
Hi Phil,
Your pictures must be in .JPG format (you should be able to convert your .BMP to JPG using for instance GIMP), posting pictures is explained here.
Thor
PS This was written in LibreOffice Writer and pasted into this post using Ctrl V on the keyboard
LibreOffice Writer
Text imported into ME forum post using the Word paste icon
Edited By Thor on 18/03/2021 13:00:13
Thanks, Thor - I've kept the link and indeed I've always used (copy] and [paste] and composed text in LibreOffice.
Mike.
18/03/2021 10:33:09
Just to clarify, I use a laptop with Linux – no Windoze here!
Probably a couple of daft questions here, but I cannot see how to add a picture into a post I’ve done.
My pics are usually from text with .odt from LibreOffice but I can convert them to .docx or .bmp easily.
Or .bmp from a scanner.
The other question is, can the font size in a post I’m writing be changed? I find it far too tiny to see write and read and have to [copy] and [paste] with Arial 13pt using LibreOffice, as I've done here.
Mike.
18/03/2021 09:46:49
Thanks, Jason, that's exactly what I want! Will be ordering it soon. You see, apart from hex and square, I will need to drill trundles of lantern pinions of all sorts of different hole sizes and numbers.
Thanks yet again,
Mike.
18/03/2021 09:37:54
Posted by JasonB on 17/03/2021 15:15:32:
Looks like I forgot the link in my previous post. This will allow you to mount the lathe chuck onto the R/T
You can then have the table horizontal to do a longish length of hex or vertical for short lengths
Edited By JasonB on 17/03/2021 15:17:47
17/03/2021 14:46:26
Thanks to all who've replied, but I think that the various answers weren't what I was really looking for; to clarify I'm going to start a new thread so this one can be closed.
I need to be able to get something that will clamp different sizes of brass bar and easily mill hexagons, squares or other different things (torx?) easily by just rotating the milling table.
As a newbie on here, is it possible for the Mods to lock this thread?
Thanks
Mike.
Edited By Phil Meaken on 17/03/2021 14:47:24
16/03/2021 15:31:26
Posted by John Haine on 16/03/2021 10:46:30:
Surely that's your answer then - use an endmill rather than a single point cutter and a plate that gives 6 divisions.
John,
Unimat which I use to cut wheels isn't beefy enough to use milling cutters, and even it it was, it would take forever doing that.
16/03/2021 15:28:14
Posted by JasonB on 16/03/2021 15:06:01:
What is your lathe's chuck fixing?
1 1/8 12 tpi, Jason. It's a 1947 Myford ML7. The morse taper shank can be removed from the headstock.
Mike.
16/03/2021 14:22:38
Posted by JasonB on 16/03/2021 13:06:02:
Phil, did you miss the bit where I said mount your 3-jaw chuck to the rotary table, work then held in chuck
I saw it, Jason, but the problem would be how to hold the 3-jaw chuck onto the rotary table (the RT doesn't have a morse taper, BTW,)
Mike.
Edited By Phil Meaken on 16/03/2021 14:24:17
16/03/2021 10:17:30
Dave,
I’ve looked at these Stevenson thingies on ARC and they seem to be the better idea.
Old mart,
I’m sure I can get hex brass but i’d prefer to make my own from the existing bits of material with any size I wanted
Howard,
I’ve PM’d you but I don’t have an ER collet and I cannot understand how the Stevenson gadgets work – how are they gripped solid?
John,
Yes, I do, but very occasionally. I use a dividing plate on my Unimat lathe and move the motor to vertical with a home-made single point cutter.
Jason,
The problem is how to hold the stock in the rotary table, irrespective on how the is held.
Mike.
Edited By Phil Meaken on 16/03/2021 10:18:12
