Member postings for Julian Newstead
Here is a list of all the postings Julian Newstead has made in our forums. Click on a thread name to jump to the thread.
Thread: BSW
11/04/2021 13:18:15
Thanks for all your working out for my lathe , the conversations got to complicated for me so I bought a BSW die problem solved. But thanks for all your replies it has helped me immensely to understand the Chinese lathe. Cheers Julian
02/04/2021 15:50:28
Hi all i am trying to cut a 5/8 BSW thread on lathe, it is a chinese cd 210v lathe i have changed gear wheel to suit 11 tpi but when i cut thread it comes out at 2.5 on the thread gauge any idea what i am doing wrong please
Thread: Hi from Suffolk
14/03/2021 08:02:26
Hi I'm Julian from Snape I'm fairly new to machining done a little at college when I was 16 but that was 53yrs ago.
Do a bit of woodworking but have always wanted a small lathe, my project at the present is refining the Chinese lathe I have obtained.
Thanks for the support I have already received
Thread: chinese lathe
14/03/2021 07:50:38
The reason for asking question is I have adjusted the plates on saddle there good but I can twist saddle from left to right it is a bit hard to explain. Hope you can understand
14/03/2021 07:42:18
Thanks for all the help people
13/03/2021 16:59:12
is this how the apron should sit on bed. the right one looks ok but left seems in wrong place. any help please
Thread: Help please
13/03/2021 11:54:14
How to you put a picture on forum for some advice please
Thread: Chinese lathe
25/02/2021 14:17:22
Hi I am new to machine work have bought a 7x12 lathe CD 210V and need help, I am trying to find out what the original gear set up is for the power feed . Got in a bit of a muddle with the gears.🤔
