Member postings for Steve M
Here is a list of all the postings Steve M has made in our forums. Click on a thread name to jump to the thread.
Thread: Er32 3mt Collet Holder
14/03/2021 10:31:55
Thanks a lot everyone
14/03/2021 10:05:50
Morning Folks.
I was lucky enough to get a 3 mt er32 collet holder for christmas and have just got round to using it. Inside the holder is this offset flange than prevents you tighening up the threaded nut that tightens the collet. I had a chat with my neighbour a few doors up and we put it down poor craftmanship and you get what you pay for. I bored the flange away and it works perfectly in my mill.
Anyway. The chap a couple of doors up decided to also buy the same holder and by chance it has the same offset flange inside. Its making us wonder whether it actually has a purpuse?
Any ideas?
Thread: SouthBend 9 Model A (NAR10) - Instruction Manual
05/03/2021 11:32:08
Posted by Hopper on 05/03/2021 10:40:26:
Posted by Steve M on 05/03/2021 10:34:08:
Hi, sorry one more question. Would the spindle thread size be the the same as on a 1940's SB 9 C as a 1945 SB 9 A ?
Thanks.
Steve
Thanks a lot. I've put a post in that Forum
The best source for those kind of very specific queries is probably the Practical Machinist forum's South Bend sub-forum here **LINK**
Plenty of South Bend experts there, being a US forum South Bends are as common as Myfords are in the UK so the collective knowledge is expansive.
And you may be able, in a pinch, to "convert" a Boxford chuck to fit a South Bend by running a South Bend UNF profile tap down the Boxford BSW profile thread. Such taps are available from Tracy Tools etc.
Edited By Hopper on 05/03/2021 10:42:37
05/03/2021 10:34:08
Thanks.
Steve
04/03/2021 09:31:27
Posted by Jeff Dayman on 03/03/2021 16:01:48:
I also have a SB 9" lathe built in 1949. I would recommend the book "how to run a lathe" published for many years by South Bend themselves. You can find hard copies on different auction sites but there are also various sites that have accessible PDF files for you to read it. This book is generic to all sizes of SB lathe , not specifically the 9" but the essential info is all there.
One such PDF is at the link below.
http://vintagemachinery.org/pubs/1617/5795.pdf
thanks. do you happen to know if Boxford chucks would fit onto the lathe?
04/03/2021 09:30:55
Posted by Thor on 03/03/2021 16:52:38:
There is a Parts List here, this document is from US Army and covers both 9 and 10 lathes.
Thor
thanks
04/03/2021 09:30:37
Posted by Clive Brown 1 on 03/03/2021 15:33:49:
Is your particular lathe the model from which the 9" Boxford is cloned?
If so, the Boxford handbook "Know your Lathe" might help. here
thanks a lot.
04/03/2021 09:30:37
thanks a lot.
03/03/2021 14:56:05
Hi Chaps,
Hope everyone is well.
I've just treated myself to a new used lathe which is the SouthBend 9 Model A (NAR10) post 1945 model.
I was wondering if anyone had an instruction manual for the lathe they could either email me or send me the link to. I've had a quick look on google but can't find anything.
It's the long bed version with the quick change gear box.
Thanks
Steve
Thread: Warco VM 15 Mill - Instruction Manual / Vice Advice
24/01/2021 18:04:09
Posted by DiogenesII on 24/01/2021 13:36:47:
..if you can't download the Grizzly manual ( 'now discontinued' ), in Nick's link above, an internet search for 'RF-25 mill manual' might bear fruit.
Also the Grizzly manual for it's bigger brother, the G0705, is still available to download - notwithstanding slight differences in capacity and maybe detail variations, the layout of the controls and the manner of operation is pretty much the same, I think.
Looks a useful machine, I like the stop on the Y axis, it shows some previous owner was thoughtful..
Edited By DiogenesII on 24/01/2021 13:37:28
Thanks a lot. This worked a treat. It states in the manual that it's weights circa 200 kilos. I can now reflect on how much fun it was (or rather not) getting it out of a first floor workshop without a lift!
24/01/2021 18:01:57
Posted by Nicholas Farr on 24/01/2021 11:28:23:
hi Steve, I think you actually have an early Warco Economy mill/drill Warco Economy
Regards Nick.
Edited By Nicholas Farr on 24/01/2021 11:28:39
Thanks Nick
24/01/2021 18:01:09
Posted by Pete. on 24/01/2021 17:42:37:
Posted by BC Prof on 24/01/2021 13:28:16:
Be careful where you install the mill. My version came with the warning
"Please not to be installing complex machine in the sunshine place "
I heeded the warning and the machine worked very well . Very solid and easy to adjust .
This is England, so not much chance of that.
Thanks Brian.
24/01/2021 18:00:07
Posted by Mike Hurley on 24/01/2021 11:57:37:
Certainly looks like the Economy mill - I think it was 'badged' by a number of companies years ago. Good and solid assuming its not been abused, not much to go wrong otherwise (i.e. no Iffy electronics)
I'v got a similar sized more modern machine (but dovetail column etc) and generally find that I use my ARC Precision Tool Vice Type 3 most of the time for a lot of things. I've 3 or 4 other vices of varying types but rarely use them, I do have an 'economy' tilting one that I bought when first starting out but don't think I've ever had call to use it.
I would consider getting a couple of assorted slotted angle plates though if you don't already have any. So many clamping options avaiable with a bit of ingenuity!
Enjoy your new toy. Regards
Thanks a lot Mike that's really helpful.
24/01/2021 10:39:03
Posted by David George 1 on 23/01/2021 22:09:38:
I have the 100mm vice swivel base from ARC and it is solid. I have removed the swivel base as it gives you more height cutter to table and it is more solid but I use it when I have multiple angles to mill.
130-040-00800* Radial Milling Vice 100mm
David
thanks David.
24/01/2021 10:38:43
Posted by Ian Johnson 1 on 24/01/2021 00:49:09:
I've got the 70mm type 2 precision vice from Arc Euro and it is excellent, well made, very accurate and sturdy. You could fit the bigger 90mm on your table and have plenty of room to spare.
I've not found the need to get a tilting vice so can't really comment, I've always tilted the job in some sort of fixture, or with a clamping arrangement on a face plate, or in the vice itself.
IanJ
Cheers Ian.
24/01/2021 10:38:22
Posted by not done it yet on 24/01/2021 08:15:39:
Just a heads up re the type ll vise, particularly if bought second hand. Check that the tightening screw/bolt cannot foul the bed when fully screwed in. There was a problem with some of them, but easily sorted by removing a small amount of metal from the screw/bolt to avoid any possibility of marking the machine bed.
Thanks a lot.
24/01/2021 10:37:52
Posted by Michael Gilligan on 23/01/2021 21:10:39:
It’s a wild guess, but ... try this thread: **LINK**
https://www.model-engineer.co.uk/forums/postings.asp?th=162074
Thanks Michael
24/01/2021 10:36:29
Posted by not done it yet on 23/01/2021 20:34:21:
I just wondered if anyone has brought and used their Precision vices? I’m looking for a normal milling vice
I have ‘normal’ milling vises and also a couple of type ll - a 70mm and a 90mm.
They are now my ‘go to’ vises, if appropriate for the job. The others are used when it suits or the type lls are not big enough.
Type ll might be considered as ‘marmite’ vises - some like them and some definitely don’t (it’s how I got my second) but not a lot come up second hand.
You may have noted that Arc do more expensive tilting vises - but good tilting vises take up a lot of table vertical space and are not needed so very often. I have an Abwood which, while it doesn’t eat anything, is not used much!
Abwood vises are good quality, if buying second hand - as long as not damaged or worn out.
How big is a VM15?
Ok thanks a lot. The table size is 55cm x 16cm
Cheers
Steve
24/01/2021 10:35:35
Posted by Pete. on 23/01/2021 20:55:59:
How big is a VM15?
Got a photo of this mill, a Google search doesn't reveal one of these machines?
Hi Pete,
Yes, I did have a google about but it didn’t bring anything up.
Please see attached the photos. Apologies for the quality I took them quickly when I brought it but then had to dissemble the mill into manageable pieces to get it out of a first floor flat workshop..
23/01/2021 19:58:22
Hi All,
Today I finally took the plunge and brought myself my first mill. It's a second hand old Warco and I got it for a really good price. The model number VM 15 model and is driven by belts to adjust the speed.
I was wondering if anyone has the same model and if so do you happen to have the instruction manual? If so, would you be able to email me a copy?
The mill came with a box of end mills, face mills, drills, collet chuck etc but doesnt have a vice.
I've ordered a few bits and pieces from ARC and have to say that their service has been exceptional. I just wondered if anyone has brought and used their Precision vices? I’m looking for a normal milling vice and also one that tilts. Or am I better off to look for a second hand one on ebay? If so, what brand is good.
Sorry if I’m covering off old ground.
Kind Regards
Steve
