Here is a list of all the postings Vagulus has made in our forums. Click on a thread name to jump to the thread.
Thread: Controlling air |
10/10/2020 23:13:15 |
My thanks to all of you. Your input has crystalised my thinking - and I have been barking up the wrong tree. I have been confusing where I am now (at the experimental stage) with where I want to be (the testing stage). I should be able to use the TIG flow valve to measure the flow needed to make the thing work. Then I can get into designing the double-acting bellows pump I have in mind to give me the right amount of air. Clive is right - I'll let the pressure sort itself out. I think I know where I am going now. Much appreciated. |
10/10/2020 09:09:09 |
More good thinking. Thanks |
10/10/2020 08:47:44 |
I can't really tell you what the beasty I am prototyping is or does. All I can say is that the air has to blow bubbles at the bottom of a water tank one metre deep. That actually means an operating pressure of 0.1 Bar. I have been saying 0.5 Bar to be on the safe side. |
10/10/2020 07:46:22 |
Does XD 351 hint at another Australian? Good thinking. I actually tried a TIG flow meter but they require minimum OP of 0.35 MPa (3.5 Bar) and I want to work below that. I'll try my art supply shop. They should know something about airbrushing.
Thanks |
10/10/2020 00:11:34 |
My project is driven by low pressure air (about 0.5 Bar). In fact its supply is from an air pump rather than a compressor. Does anyone know where I can obtain a flow meter (0 - 30 l/min) and a relief valve which will operate at that pressure? Thanks
