Here is a list of all the postings sorceror has made in our forums. Click on a thread name to jump to the thread.
Thread: drivetrain ratios |
10/10/2020 17:57:33 |
Thanks for all the reply's, just needed to confirmation of my thinking. |
10/10/2020 14:08:30 |
FDR is final drive ratio. The gears would not be run together. i,m trying to change to a 20DP geartrain from 24DP as 24DP gears are unobtainable, but want to keep the same ratio's to the leadscrew. Edited By sorceror on 10/10/2020 14:09:13 |
10/10/2020 13:58:28 |
If 2 gears are the same diameter and number of teeth, but one is 20DP and the other is 24DP would the FDR be the same ? |
Thread: Pools Special Lathe |
09/10/2020 09:50:21 |
Thanks for the reply's guys. |
08/10/2020 19:52:27 |
Had a think, and swapped the 36 for the 24 on the tumbler output. So 24-127, then buddy a myford 20T 20DP gear to the 127, driving a 20DP gear on the leadscrew, sorted. Just need to work out the ratio for the lead screw gear. Any ideas for the leadscrew gear size ?
08/10/2020 09:07:55 |
Hi, i recently bought a Pools Special Lathe, with just 2 change wheels 127T and 24T, pin drive type. Calculating the DP, gives a 24DP result. Can anyone confirm this is correct for the Pools, as Tony at lathes.co.uk hasn't come across anything similar in the archives. Randa and Myford ml1-4 of that period use 20Dp gears, so 24DP is a bit strange. If anyone has a Pools i'd like to hear from you.
