Member postings for Michael Meszaros
Here is a list of all the postings Michael Meszaros has made in our forums. Click on a thread name to jump to the thread.
Thread: North West UK Newbie
10/06/2020 22:49:56
Hi Neil, Thank's for getting back to me, the problem I have is that i don't have the machinery to do this kind of work & my eyesight isn't as good as it should be that is why I am hoping to find somebody who could do the work for me there isn't a fantastic amount of work to be done and I am more than happy to pay £20 per hour, the work is mainly to the cylinder head, the rocker arms & shaft need to be made, the spark plug holes need to be bored out or drilled, recessed & threaded, the camshaft bushes need making & fitting the camshaft needs slotting & keying, the valves need further turning & facing,the seats need cutting the cam gear needs slotting & tapering. the pistons need turning (blank castings supplied) the crankshaft & drive gear needs slotting & keying, the timing gear pedestals need making & fitting,the oil & water pumps need mounting to the front cover after the driveshaft hole has been drilled out & the oil feed pipes need making & fitting to the relevant flanges which need to be drilled & tapped, the crankshaft center bearing halve shell needs an oil hole drilling and the distributor needs making. I have the original plans/blueprints for the engine in imperial measurements. if you know anybody who would be willing to do this work for me please let me know. kind regards Mick M.
06/06/2020 21:40:16
Hello Brian W & Brian H & Thank you both for your welcoming message, I was going to give you both a message of thank's at the end of my response to John but my tablet battery died! it doesn't last very long so most of the time I have to write as quick as I can, the reply I sent to John applies to both of you as well as anybody that might be able to help me, I look forward to any feedback on this matter, kind regards Mick M .
06/06/2020 14:32:39
Hello John, I live in east Lancashire a little one horse town in Rossendale where nothing much ever happens, I am currently trying to finish a project that was started by someone else but I think I am out of my depths on this one, I have a westbury sealion engine that needs to be completed but I don't posses the equipment to do the task so I need to enlist the services of a skilled model engineer to help me with this quest, do you know anyone who would be willing to assist me with this quest? perhaps a retired engineer looking for a challenge as well as earning some extra money, if you do please let me know thanks Mick
06/06/2020 08:56:44
Hi All
I am new to this forum, currently undertaking a project of trying to finish a Westbury Sealion engine...
Im a retired motor mechanic who has been building model cars and tinkering with pre built model engines for some time but have undertaken a project that has been left to me but seems to be a little above my skill set.
Im here looking for guidance and advice whilst also learning more about the model engineering.
Mick
