Member postings for Richard Griffiths 1
Here is a list of all the postings Richard Griffiths 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: VFD Motor combo for lathe
02/05/2020 23:14:43
Thank you for the replies, I will get a slightly bigger motor and a cheaper VFD. I created an album of the headstock it in pieces at the moment and still needs to be cleaned up. I also need to make a gasket for the front. Seems to have two tapered bearings at the front and a bearing at the back.
I was thinking of replacing the v pulleys for a wide toothed pulley, and replacing the rear bearing for a sealed bearing any ideas if this seems a reasonable idea.
02/05/2020 20:21:59
Hi,
I have purchased a Drummond M type lathe, it came with a custom made headstock. I am looking to eventually convert it to a CNC lathe is my ultimate goal. I have completely stripped it down and I am currently cleaning all parts. It is missing a load of bits, due to the headstock alone I am not looking to restore it.
I have been looking at an English made 0.55kW VFD and motor.
I am a complete noob, so any advice on the following would be kindly appreciated.
1. Would the motor and VFD combo be adequate?
2. The VFD is a lot more expensive than Chinese models but does come with a 5yr warranty any recommendations?
