Member postings for Stuart McPherson
Here is a list of all the postings Stuart McPherson has made in our forums. Click on a thread name to jump to the thread.
Thread: Who is Right?
14/11/2020 20:17:14
I have recently resurrected a 6v Lantern battery. I gave it short bursts of 12v during the charging process which some schools of thought suggest and it appears to have done the trick What are members thoughts and/or experiences in a) using this method OR b) suggest an alternative method?
Thread: By Crook or by Fluke
11/08/2020 21:13:02
Hi John
My display looked as if it was leaking and the digits were blurring and merging. The new display fixed it.
11/08/2020 19:13:10
I suppose like me some of you possess a bench top multi-meter in my case it was a second hand Fluke 8010A which I purchased a number of years ago. Its a very versatile tool and whilst they are somewhat long in the tooth they stand the test of time. Apart that is for the LCD display. Even when I bought mine the display was less than crisp and over time it got more blurred and was getting to the stage where I was thinking of replacing it. But like we all do it time of need I started trolling the Internet and came across a site which among other things addressed my problem completely and provided a step by step guide to sourcing and fitting a replacement LCD So after spending just over £5 and some judicious soldering I now have a bench top meter with a crisp clear display and hopefully will endure for a good number of years. I cannot speak to highly of the web site for the assistance and support that I received.Give it a look there are other repair types mostly related to Radio Amateurs at billingtonrepairs.wordpress.com
Edited By Stuart McPherson on 11/08/2020 19:16:15
Thread: Dewhirst forward reverse switch
20/07/2020 11:46:00
Many thanks to all who were interested in my switch. However it is SOLD.
Thread: Neil Hemingway Kits
02/07/2020 23:04:43
Thanks for that it is just the information I was hoping for.
02/07/2020 19:54:43
Going back to the early nineties I purchased a fair number of kits from Neil Hemingway and spent many an hour with him putting the world to rights. During lock down I have got round to making some of these. One of them H86 has got me stumped. I had thought it was the bending roll kit but checking it against the parts list I am not so sure although there may be some other parts in another box. I wonder if anyone has an original kit list from Neil which may throw some light on the issue and save me searching numerous boxes for end plates and gears. I have spoken to Hemingways Kits but alas they do not have an original list and have re numbered their kits.
Thread: Bench Mounted Engraving Machine
12/06/2020 21:59:41
Hi Bizibilder
The article I am working from is the one you refer to and the machine does have the two part rod you mention. My confusion arises as when I bought the part built machine the motor pillar was not quite tight and being a purist I tightened it and now I am not sure I did the right thing.
12/06/2020 20:29:37
Has anyone built the Bench Mounting engraving Machine described in Model Engineer May 1955 Vol 175.
I am confused as to whether the motor pillar should be tight or allow the motor to pivot in unison with the cutter head/pantograph. If it is swivelling I am not sure how the tension stays on the drive belt. Any thoughts?
Thread: New Yorkshireman member
05/05/2020 20:04:48
Hi Olly
Welcome from another adopted Yorkshireman, as you can see I hale from Scotland initially. You will have a host of help on this site and I hope you enjoy making what ever.
Stuart
05/05/2020 20:01:21
Hi Olly
Stuart
Thread: Dremel 395 brushes
01/05/2020 20:08:23
Hi Allen
I was looking back over some early MEWs and there was an article on a spring loaded centre locator for the drilling machine. The spring used was from a retractable ball point pen. These are about the correct diameter and I have used them in the past on projects and the pressure is quite strong. May be worth a try.
Stuart
Thread: Return to the workshop
01/05/2020 19:54:48
Hi Howard I am located in Horbury West Yorkshire
27/04/2020 19:13:12
Hi Steviegtr and IanT
Ill get the hang of this computer thing, pity I can't go to the night school. The reason I say this is I responded to Chris,s welcome and query and thought it would appear here but it must have gone to him only. Anyway thank you both for your welcome and I will try and make something interesting. I mainly do workshop bits and I was telling Chris I am a great devotee of Hemingways Kits. Indeed I used to call on Neil on my way back so inevitably there are some castings to be sorted and worked on.
26/04/2020 21:32:56
Hi Everyone From the 60 s I started to gather my workshop I bought an ML7 which was dismantled and came in a number of boxes for starters and eventually managed over the ensuing years to get quite a comprehensive set up. Attending evening classes was a great benefit alas there are very few colleges offering them now. I subscribed to Model Engineer and subsequently MEW up until late 80 s but from then until 2004 I was commuting from Monday to Friday and the workshop was a no go. When I eventually retired I had a few bursts of enthusiasm but the fact that my workshop is in the rear of a double garage with only the up and over door I got to the stage that I could not open the door from the inside. This was solved recently when a motorised door was fitted and here I am back and what with Lock down the machines have been dusted down and I am cutting metal again.
Thread: Macc Models
25/04/2020 20:03:22
Hi order some BA nuts on their web site and they arrived within five days. Not bad considering everything else.
Thread: Back issues
17/04/2020 20:34:00
Anyone interested I have several volumes of Model Engineer (complete when last checked) from Vol 156 to 181
