Here is a list of all the postings Mike Penwolf has made in our forums. Click on a thread name to jump to the thread.
Thread: Bantam wormdrive pinion |
30/12/2022 10:24:04 |
Thanks guys , but all credit to Colin who had the idea of the slot |
30/12/2022 09:12:17 |
Here's an update on repair progress I bored out some nylon to hold the pinion while i carefully bored out original brass bushes , stopping when wafer thin and peeling out last bit , then hammered in some 24mm nylon66 and bored that to match the cleaned up support bushes. Then slotted pinion 3/16 to match spline in drive shaft , shaped and hammered in new key . I have ordered oilite bushes to replace nylon and will put tiny TIG welds to replace retaining bolts at that point the drive shaft needed minimal filing in a few spots to clean up , and its all running really well now when that key wears out I can extract and replace thanks again for all advice
21/12/2022 17:24:34 |
21/12/2022 17:23:49 |
Yep , I think mystery solved , I think you guys are right . the key has worn away completly , and not shown in the drawing because of the angle , but can see in the forward /reverse handle diagram a key in the sleeve
20/12/2022 16:18:22 |
Hi I have just aquired a Bantam 1600 (AA 3061) and am trying to fix the lack of carrige drive and cross feed . I have removed the apron and the gearbox ,although showing its age, does work. Everything engages as it should except for the wormdrive pinion (labeled A in photo, and part 201-141 in diagram ). I cannot see how it was supposed to engage with the drive shaft (labeled B) inside it is smooth with no sign of a missing key , and the diagram does not show a key so if anyone knows how this was supposed to work I would be really grateful for some help . thanks , mike
