Here is a list of all the postings Adam Hebbard has made in our forums. Click on a thread name to jump to the thread.
Thread: New chinese lathe or old Myford lathe |
12/03/2020 13:56:26 |
All I have learned is that chinese lathes are very poorly made. I had 2 Clarke CL500Ms that were both faulty with bad bearings right out of the box. Had an Amadeal that worked fine for a year and then died. I'm in the process of switching out again now. Think I'm gonna get a second hand myford from somewhere. |
Thread: Amadeal Lathe failed - customer service appalling! |
09/03/2020 14:08:16 |
Posted by Paul H 1 on 09/03/2020 13:53:06:
Adam, I took at the link to the nearest current Amadeal lathe. Providing your lathe is using a DC motor, which I strongly suspect it is, the KB Electronics board should be fine. I have seen posts elsewhere (I can't remember where) that some owners of similar Warco lathes also had the KB board. Thanks Paul, appreciate the help. I don't even know what parts of my machine are working or not at the moment. At first it powered up again and the motor spun very weakly, so he said I should tighten the belt. I did so, then it wouldn't start at all. Then they sent me a new speed board, wouldn't power up at all. New filter board, wouldn't power up at all. The initial problem caused some of the block connectors in the back to totally melt, so I really have no idea what went wrong. I'm going to have to see if I can find a third party to advise. Though I'm pretty sure the sale of goods act is on my side here. Thanks again, A |
09/03/2020 13:27:04 |
Posted by JasonB on 09/03/2020 13:09:23:
Those same T&Cs also say "Electrical Components are covered by a 6-month guarantee whilst mechanical parts are guanteed for 12-months provided items are not subjected to excessive wear and use". As It's more than likely an electrical issue they seem to have done more than needed. Except a qualified repair engineer hasn't even looked at this case, because they've all left apparently. So the guy has just guessed at what sort of thing to say. Also, over the phone, he said that this shouldn't have failed and that they would fix it. They are now doing nothing. When I bought it, they said it was guaranteed to last years, and was touted as a 'work-horse'. It clearly isn't. I wouldn't mind being at this point if they'd genuinely tried to give pro-active support. Now they've just cleared off and aren't responding to anything. |
09/03/2020 13:25:16 |
Posted by Paul H 1 on 09/03/2020 13:22:56:
Posted by Russ B on 09/03/2020 11:11:29:
These come with a 5 year warranty. If I'm going to buy a Chinese lathe, I'd rather buy a one without the speed controller board for a discount and fit one of these. This is the type of board I fitted to my lathe from the same supplier. These are first class, well put together speed controllers with an excellent reputation. What sort of lathe would you attach this to? |
09/03/2020 11:01:01 |
Posted by Robert Atkinson 2 on 09/03/2020 10:53:20:
From the Amadeal website for mini lathes " Ideal for the professional engineer or model maker " So thier bench lathes should be OK for professional use. Intrestingly thay sell "customer returns" for repair which seems to confirm their lack of technical back-up Thanks Robert. Yes I was never under the impression it could only be used for certain things. Again, it's really not been used 24/7 365 or anything. |
09/03/2020 10:42:24 |
Posted by not done it yet on 09/03/2020 10:20:33:
Thanks, I hope it gets solved too. I use the lathe for my hobby and as side income. The issue is I haven't been able to build anything for more than 2 months now, and it's grating on that part of my life. I'm also losing income and have several unhappy and impatient customers of my own. THAT may well sum up your position and sink any chance of retribution. IF that lathe, as many others are, was sold as ‘hobby use only‘, you have just cooked your goose by clearly stating it has been used for purposes other than hobby use! Beware, too, that nobody quietly reports this to inland revenue/income tax if you are not already reporting your side income..... I use it for my hobby, and I also sell the things I make. Using it for the same thing whether I sell the end result or not. It has not been constantly used and abused. It was used for a few hours a week, if even that. So it has not been worked to death in the slightest. I also report all my income (though very little) to HMRC, so I'm all perfectly legal. The current model I have is no longer on their site, the closest match is this... ... and nowhere does it specify what you can use them for. You use them for machining metal... |
09/03/2020 10:05:18 |
Posted by Ian Johnson 1 on 07/03/2020 23:44:08:
Just had a look at Amadeal's website and noticed they are selling the new Syil X5+ 4 axis CNC milling machine for £11.000+. One thing sets my alarm bells ringing is that the machine is fitted with Mach3 operating system, which as far as I know is no longer supported or updated by Newfangled Solutions. I would expect a new hobby CNC to come equipped with Mach4. Makes me wonder what sort of back up and after sales service this company can offer for a machine like this, let alone a Mini lathe? Ian Hi Ian, Thanks for responding. Yeah, interesting point to be made! Again, I'm not trying to just stir up trouble. I've desperately tried to get this issue fixed but they keep messing me around and claiming they don't even have an engineer to fix it. So even if they do come and collect it, what's going to happen then? |
09/03/2020 09:53:20 |
Posted by Howi on 09/03/2020 09:31:19:
a faulty machine will always raise someones ire, unfortunately ALL uk lathe (chinese) suppliers have had bad publicity due to faulty machines/poor service at some time. Amadeal are no different in this respect, unfortunately one bad review can spoil an otherwise blemish free existance. my experience of Amadeal has been nothing but positive, i bought a AMA210 about 8 years ago, with other accesories being added over time. ALL chinese machines are built to a price and are only classified as amateur use. yes! it is frustrating when it happens to you, but can you say hand on heart YOU are not part of the problem? i am sure there are a lot more satisfied customers of Amadeal out there. yes! there customer service may suck on this occasion, but that again may be down to you. look at it from their point of view, there is not a lot of profit to start with, after 11 months someone complains his machine broke, all the profit suddenly vanishes trying to clear it up. i am not saying you are wrong, after all the customer is always right ?. there has been a large amount of feedback on this forum about all the uk chinese machine sellers, only one seems to stand out head and shoulders above the rest and that is Arceurotrade, but even they have had some bad press. it is all part of the business. i do hope you get your lathe sorted out soon without any more hassle. bad reviews always get the limelight, good reviews less so. Hi, thanks for your response. Of course I'm upset it's faulty. And my first thoughts were to check and see if it was something I had been doing. I checked with some friends and fellow machinists on techniques, usage and maintenance, and have also been extremely careful with the machine. I even discussed this with Amadeal over the phone, and they agreed this is not a fault that should have occurred. Melted connectors in the back of the machine isn't a good sign. I don't see any way I could have caused that, and they agreed. But as time has gone on, they've just become less and less helpful and ended up being rude over the phone after spending time messing me about. I understand things break, and things go wrong. But to use a car analogy, if your car failed within the warranty period, the garage sent you parts to replace yourself, said that they had no engineers to help fix the issue, and then became very hard to contact, you would be pleased would you? Also, if you buy a cheaper car, do you expect it to be faulty? Just because it's cheaper, doesn't mean it shouldn't work. Of course I would buy a high end machine if I could afford one, but as many people will relate to, it just isn't possible. I don't understand how it would be down to ME that their service is bad? They've not been getting back to me, or pro-actively helping me solve the issue. They all but ignore me until I chase them hard, and then they're defensive and verging on rude on the phone. I would normally agree with the bad reviews outshining the good, but I have a lot of experiencing in weighing up different companies in the light of reviews. The area I do machining in has several small companies and it is abundantly clear which have the bad reviews, and which have the good. There are also some much larger companies in the field, some of which I know are dodgy, provide very bad service and have questionable practices, but most of their reviews are good. I wasn't posting here in order to stir up trouble for Amadeal, I don't see the point in that. I wanted to know if anyone else has had a similar experience with a lathe of this type, or the company, and how it was resolved. Seeing the bulk of responses on this thread, I'm not alone. Doesn't mean the overwhelming amount of their customers have had this experience, but it's clear it's not just me. Thanks, I hope it gets solved too. I use the lathe for my hobby and as side income. The issue is I haven't been able to build anything for more than 2 months now, and it's grating on that part of my life. I'm also losing income and have several unhappy and impatient customers of my own Thank you for your insight, and also thanks to everyone for responding |
09/03/2020 08:36:44 |
Posted by Stuart Smith 5 on 08/03/2020 12:30:59:
I have had a different experience with Amadeal. From the original post, it is obvious that Adam Hebbard is not happy with Amadeal, but this is his first post on this forum. As far as I can see, there are two reasons to post on here with the sort of title he has used - one is to let others know of his experience, the other is to damage the reputation of the company. There have been other posts where people have had issues with other companies supplying lathes and accessories, including the well known ones who advertise on this site. If you look at the warranties for other companies, they either have 'back to base' where you have to pay for returns or parts only after 6 months etc, so the fact that Amadeal have offered to pick the lathe up at their expense actually seems better. Obviously it wasn't picked up when arranged, but I did not see that they had refused to rearrange this, just that they wouldn't do this on a Saturday because of the extra expense. I don't think this is unusual, even for big companies. I bought a mini lathe from Amadeal about 2 years ago. I decided to buy from them because it seemed to have the best spec at the best price compared to other companies. I guess that the OP did the same. I realised that it was a small company and that there may be a trade off between price and customer service if I had any issues. The lathe was delivered quickly by courier on the day specified. A few days later the plastic carriage handwheel broke. I rang Amadeal about 4pm, they said they would send a replacement which came the next day, which I thought was excellent customer service. Since then I have bought a few small items from them which all arrived next day. I have never had any problems contacting them. I did have an issue with a lathe collet chuck I bought. The runout was more than I expected and when I looked at it, the bore had not been machined correctly. I rang Amadeal and got through straight away. I was asked to send them an email with a photo of the problem. They emailed back saying they would send me another together with a prepaid envelope to return the faulty one. This arrived next day, but had the same problem. I rang them again (got through again straight away) and said I wanted to return them both for a refund. They agreed to this and said they would arrange for their courier to pick them up. I offered to post them back instead and they agreed to refund the cost of the item plus postage costs. I had paid via paypal, so they refunded to my paypal account the day they received the items back. My point is that it is easy for one persons experience (which does not meet their expectations) can possibly give a distorted view of a company. Happy customers do not tend to volunteer there experiences in the same way.. I have no connection to Amadeal, other than as a customer. Stuart
Thanks Stuart for sharing. My aim is not just to kick off for no reason. My machine failed, and they have become very hard to get any answers or support out of, and have taken to becoming rather rude over the phone. I understand the point about saturday. But they had originally agreed to collect the previous saturday, with no mention about the issue of cost. To confirm, I then had to be out that saturday so I asked to delay it to wednesday. To then bring up the cost issue on that next wednesday seemed odd. Especially after asking me to pay for it. Considering they have sent me all these parts saying 'I'm sure this will fix the problem', and then saying 'Oh, we don't have a service engineer', is not inspiring any confidence. A few weeks I could understand. But this has gone on for well over 2 months now, for a problem that a company with more pro-active support could have solved much more efficiently. I'm glad you haven't had the same trouble, I guess it's each to their own, no argument there. But looking at this overall thread, it's clear this issue does run a bit deeper than just me, I'm not an isolated case. |
09/03/2020 08:31:16 |
Posted by Paul H 1 on 08/03/2020 11:42:17:
Sorry to hear about your story and abysmal service. Note by the way that Amadeal are linked as a shopping partner on this site. If you don't get a result from Amadeal there is always a solution. Several years ago when I was looking round to buy my lathe I too took a good look at the Amadeal site, however I bought mine and my mill from SPG Tools as it was much better tooled. The products as far as I could tell from the photos came from the same factory. In the many discussions I had on the phone with SPG it was emphasised that when starting the lathe always make sure the speed was turned down to minimum before switching on to avoid damaging the electronic controller card and make a habit of turning the speed to minimum before switching off in normal use. This seemed to be to avoid a big inrush current, I believe, on the SCRs of the controller card. Despite doing this and the lathe serving me well it went wrong after the guarantee period. My problem was it went at full rpm with no control from the pot. Being in France, so remote to SPG in the UK I took matters into my own hands and investigated. The DC motor was OK, no probs, the pot tested OK so it was the motor controller card. Investigations on the net revealed that the factory fitted a Chinese copy of a KB Electronics card, the KB original being noted for its reliability. So I found a UK distributor who sold online and ordered one and its heat sink. I did have to make some mods in the housing at the back of the lathe and in fact fitted the controller to the door so making future maintenance easier. Since then I am a happy bunny with the lathe. I have also done component testing on the card and confirmed the 2 thyristors are shorted, so that will be a repair to do which will then give me a spare speed controller for other DC motors. Thank you for pointing that out, can always go via here if needed too then, thanks. I also didn't know about the motor speed thing, starting at low and turning it up. This was never mentioned to me anywhere. Nor did it even occur. |
09/03/2020 08:29:13 |
Posted by Robert Atkinson 2 on 08/03/2020 11:23:05:
If they do not respond properly to your email, opem a small claims court claim on line. This is easy and often brings a prompt resolution. You can do it online: Claim the item is not fit for purpose, they have not responded properly and you want a full refund.Make sure your claim includes them paying for the cost of returning the lathe. Robert G8RPI. Thanks for this link, may find it very useful. |
08/03/2020 09:25:49 |
Posted by Bob Stevenson on 07/03/2020 21:10:19:
Amadeal is only 20 minutes run from home for me and I went to have a look in 2017 before aquiring my Warco WM180 as Amadeal do the same basic machine. Their 'showroom' turned out to be an unmarked railway arch and there was initially no answer until I had one foot back in the car, when the main man finally peered outside to see what I looked like.
The place is not very big and is basically a small warehouse operation where crates arrive from China and are sent on to the buyers. Approx. on third of the space was taken up with a pile of mini-lathes in various states of disassembly, presumably warranty returns. The man was apparently friendly when he learned that I was genuinely interested in one of the machines and levered the top off of the crate to let me take a look. As far as I can recall there appeared to be no engineering on site and if there was a bench present it was a very small one.....
The main mental and emotional activity of 'the man' was selling.......his strategy was to slag off the likes of Warco & Chester as being very expensive compared to him. However, it was fairly easy to tot up the price and work out that, actually, Warco's price was considerably better since they threw in two chucks, two steadies and a faceplate etc...the Amadeal machine only came with a 3 jaw, although it did have a pot of touch up paint which Warco don't include!
A couple of days later I went around the M25 to Chidingfold to give Warco the once over. Within minutes of getting out of the car I liked what I saw and realised that they are the opposite of Amadeal in that they are offering a sorted out set of products for a carefully sorted out price.... There's nothing wrong with Chinese machines and, frankly, they are the only game in town for people like me, but it's ESSENTIAL that you buy from a reputable concern who are prepared to open the boxes BEFORE they pass it on to you. Thanks for posting this story, wish I'd known about this before. All this suffering! I sent them an ultimatum email. If they don't either repair, replace or refund it, I'm gonna kick off as much as possible basically. Citizens advice, trading standards and what now. It's just very very lazy service. I did some digging beforehand, but apparently not enough to realise how terrible their after sales support is. |
08/03/2020 09:23:06 |
Posted by Falco on 07/03/2020 20:34:43:
Posted by Adam Hebbard on 07/03/2020 06:55:24:
Posted by Falco on 06/03/2020 21:51:45:
Similar problem here! Time they got their act together.
Oh really, may I ask what's happened to you? I had an electrical problem and did get a response from Amadeal at the second time of asking. A further query remains unanswered . These companies sell their machines largely to an amateur market and the very least a supplier should do is provide some technical assistance and a clear and comprehensive wiring diagram for the particular machines that he sells. Providing a Chinese/ English manual with a minimalist wiring diagram is a sloppy and couldn't-care-less way of treating customers shelling out over a thousand pounds for their machinery. American companies generally do better on this. The emphasis is on selling on this side of the pond and customer service comes a poor second.
Yeah looks like I should have done a bit more digging. The manual is very hard to read and understand and is full of grammatical errors also. |
07/03/2020 14:16:57 |
Posted by larry phelan 1 on 07/03/2020 11:31:00:
Buy British ???? I thought I was, Anadeal being a small london based company. I know the machines I still from china, but I can't really afford anything made over here, it costs a bomb. Worth it I know, I just don't have the funds. |
07/03/2020 14:15:48 |
Posted by Lathejack on 07/03/2020 09:44:51:
I have seen the same problem with a new Clarke CL500 combo machine at a Machine Mart showroom in Mansfield. The headstock spindle was stiff when rotated and very notchy, so possibly the taper roller spindle bearings were full of muck or more likely way over tightened with preload. It certainly wouldn't have worked well at all, or for very long, in the state it was in. Yeah sounds like it was as dodgy as the one I had, though that isn't even the issue I have now, lol |
07/03/2020 14:15:14 |
Posted by John MC on 07/03/2020 07:56:35:
Posted by Adam Hebbard on 07/03/2020 06:50:36:
Posted by Alan Waddington 2 on 07/03/2020 00:06:00:
Posted by Hollowpoint on 06/03/2020 22:53:07:
Im sorry but you've gone through 3 lathes in 12 months? Sounds like user error to me.
“2 faulty out of the box”........what did he do, unpack them incorrectly?
I had 2 clarke latches that were faulty. They were cl500m lathe mill combos. The first one had knackered lathe bearings and didnt cut smoothly, rattled and ran like a locomotive. Second they replaced came with no key in the mill so it didnt turn, then eventually fixed that and then it turned out the mill bearing were shot. Same rattling and deafness of the first lathe bearings. So no, that wasnt user error. And I've been extremely careful with this machine also. I consider this very bad luck Im afraid. Still? Their service has been awful. Worn out bearings straight out of the box? A friend bought one of those Clarke combo machines, same sort of problem. Not worn, it was brand new! Problem was adjustment, soon sorted, much easier than the hassle of returning it. The worse thing about this machine was the gearing to get the drive up in to the milling head, noisy, but my friend soon learned to live with it. John They weren't worn, they were just defective. It sounded like there was a spanner rattling around inside! |
07/03/2020 06:55:24 |
Oh really, may I ask what's happened to you? |
07/03/2020 06:53:59 |
Posted by Ady1 on 07/03/2020 00:10:45:
Sounds like dodgy electrics to me If there is one weakness on modern units, especially if they are built to a price point, it's the electricals No problems with the old stuff, a mains switch and a whirry motor Motor blows up etc, fix it or get another and b backe up and running in 7 days or less Yeah its definitely some sort of electrical fault aa there were melted connectors inside the unit when I took the back off. |
07/03/2020 06:52:55 |
Posted by Ron Laden on 07/03/2020 03:47:59:
Hi Adam, Your Amadeal lathe is not a CJ18 mini lathe by any chance..? If so I had one and I had problems with the speed control pot on the front panel. It became a problem to set the speed it was up and down all over the place and eventually stopped working. I was waiting for a response from Amadeal but wanting to get the lathe running in desperation I gave the pot a big dose of contact cleaner and it cured the problem. Of course yours may not be the CJ18 and you may not want to play with it plus my problem came on gradual where yours just suddenly stopped so it may have nothing to do with the pot but just thought I would mention it. What contact you did have with Amadeal did they not consider it could be the motor that is the problem. Ron HI Ron, No it's a bigger AMA240V. It did something similar and he got me to test the motor but it seemed fine. When I first took the back off a set of the block connectors were totally melted. Hugh just kept getting me to change it parts saying 'Oh that'll probably work'. Gave them the benefit of the doubt at first but this machine has clearly just keeled over. I'm in disbelief they dont gave a service engineer. |
07/03/2020 06:50:36 |
I had 2 clarke latches that were faulty. They were cl500m lathe mill combos. The first one had knackered lathe bearings and didnt cut smoothly, rattled and ran like a locomotive. Second they replaced came with no key in the mill so it didnt turn, then eventually fixed that and then it turned out the mill bearing were shot. Same rattling and deafness of the first lathe bearings. So no, that wasnt user error. And I've been extremely careful with this machine also. I consider this very bad luck Im afraid. Still? Their service has been awful. |
