Here is a list of all the postings Matthew White 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: Harrison lathe clutch |
02/01/2020 18:15:37 |
Hi I'm new to the site and i apologize for not introducing myself on the other forum but need some help on this topic. I have acquired a Harrison L6 12" x 24" MK2 lathe over the Christmas period and the clutch lever didn't work there was permanent drive through the gear box. I have found the issue in that even with the clutch removed the clutch pulley is really stiff and still turns the gearbox input shaft when it should be freely rotating/disconnected from the shaft. I have tried as far as i dare to remove the clutch pulley to inspect/clean it but i cannot free it from the input shaft. Are there any hidden circlips or pins that stop this pulley being pulled off. the whole unit will rock and pull push a couple of mm but that is it. I haven't been able to source a manual for mine or any videos etc to show how this pulley is removed any help will be appreciated. |
