Member postings for Martin Wood 1
Here is a list of all the postings Martin Wood 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Understanding Digital Subscriptions
31/05/2020 16:45:21
I have had a subscription for 3 months now digital and hard copy. For some reason can never find the extra content as advertised.
Thread: Warco GH600
08/02/2020 11:23:22
Hello Jed,
I would make new out of mild steel flat stock. With regards to counter bored holes pre drill with diameter required.
Grind drill with flat bottom then finish pre drilled hole to depth. You could mill a relief on clamp end and fix nylon or brass strip. I ordered the GH600 and its due to be delivered on Monday. I will strip my machine down before using as from your pictures looks like sharp areas everywhere .
Martin
02/02/2020 00:51:37
I ordered GH600 on 31/01/20, should be delivered next week. Then problem of moving to workshop.
With regards to question on federate according to chart picture the slowest feed for carriage with 32 tooth gear is 0.044 mm per rev, with cross slide being half that number 0.022. If you want slower you have to change 32 tooth gear. depending on your requirements.
