Here is a list of all the postings Jurrian Mulder has made in our forums. Click on a thread name to jump to the thread.
Thread: Hello from the Netherlands |
27/10/2019 13:25:13 |
Judt found out how to post pictures directly, so here they are. Some more information about the lathe: So as i said there is no type plate or anyting on the in or outside of the machine. It has a bison 160mm chuck on there, which I think isn't original. The lathe has autofeed in both directions, with 6 different feeding speeds. There is a 2 step 3 phase motor in there, 700 and 1400 rpm. 4 different sizes pully at the motor and 4 at the main shaft. Rpm range is 250rpm until 3100 rpm. It has a clutch and brake in the drivetrain, and a lock to lock the main shaft in 6 positions, each 60 degree. Oilpump is there aslo, but not working at the moment. All text is italian. I have looked the list at lathes.co.uk, but couldn't find anything. Edited By Jurrian Mulder on 27/10/2019 13:33:27 |
27/10/2019 10:45:04 |
Hello, thank you for the reactions, here some pictures of the lathe. There's no type plate, only some text about the type of oil and about a lock. Hope the images work https://ibb.co/TH8yGX1 Edited By Jurrian Mulder on 27/10/2019 10:51:26 Edited By Jurrian Mulder on 27/10/2019 10:54:29 |
23/10/2019 20:38:18 |
good evening, I am Jurrian Mulder, an engineering student from Holland. I work a lot with machining and Cad for my study, but in my free time I like to tune 2 stroke engines. I have my own bridgeport milling machine, and a hobby lathe. just bought a second lathe, an Italian one. I don't know the brand yet, hoping you guys could help. greetings,
