Here is a list of all the postings Matt Reid has made in our forums. Click on a thread name to jump to the thread.
Thread: Oil |
14/05/2020 18:25:42 |
Guys a lot of different options on oil think will go for fully sync and set oilers 2 drops per miniute for head stock and oil ways with same could use some new oil wick whare can I get it from thanks matt |
11/05/2020 22:46:42 |
Hi looking for information on oil for ways I am in UK Scotland so need be able to buy here need recommendations as to what I should use on ways and main shaft also how much do you need when running drops per miniute from drip oiler thanks hope yous can help |
Thread: Quick change tool post |
29/04/2020 20:10:27 |
Guys information and help is appreciated I haven't long got lathe and it only came with one holder and cutter so can't really do much as never sharpened bits that's why the qctp I could buy carbide and then go for it rather than get angry because I could not sharpen hss so time in setting up is not important whare can I buy hss holders and which hss again thanks |
29/04/2020 13:20:13 |
Guys thanks for all reply think I will try get a cheapish qrtp so problem now is how to measure up for tool post if poss could a picture be put up as I am new to lathes you have gave me a lot to think about on subject as I can't sharpen hss if I get new tool post it might give me the chance to try other cutters again thanks |
28/04/2020 10:36:49 |
I want a easy set up would need to keep trying to set wedge it's not easy and can't sharpen hss that's why I would like a descent cheap holder |
28/04/2020 09:16:31 |
Thanks for all your help looking at the link I can confirm it is a b4 dalton I am new to lathes with this information can you recommend quick change tool post would fit even a used one thanks again |
27/04/2020 16:43:19 |
Hi first post need help in finding a quick change tool post for a dalton lathe which has lantern post if anyone can help with information please get in touch thanks great site |
