Member postings for Shaun Belcher
Here is a list of all the postings Shaun Belcher has made in our forums. Click on a thread name to jump to the thread.
Thread: Acme thread
24/11/2019 00:17:30
Posted by Hopper on 04/08/2016 04:13:15:
You have a lathe. Make one. Lock the cross slide in position and set the topslide at 90 degrees to the lathe axis and use it to feed the cut in. A moving steady will probably be required, but is easy enough to make up too.
I am needing to machine some new feed screws and nuts on my ML7 too.
Just stumbled across this thread so thought that I would ask a question.
Myford claim its 10TPI for the imperial feedscrews, but only say the metric ones are 3/8" 2mm pitch.
I'm assuming that they are 8TPI?
Either way, I thought that it would be a good time to convert the lathe to metric when replacing the feedscrews, just need to get the dials from myford.
What changewheel do I need for cutting such threads?
I don't have any that came with my lathe but I've got a friend who is an engineer and can probably machine me one on his lathe if I know the right specs. I also have no idea what type of tap to get for cutting out the feedscrew nuts.
Thread: Just bought an ML7, what should i do first?
18/11/2019 10:20:13
Thanks, ill check those books out.
I was assuming there would be a lever. Completley overlooked that bolt.
It seems pretty tight when I put a spanner to it.
Will leave some CRC soaking on it to see if it helps free it up.
I see there is a mod available with a lever, I think thats a good idea rather than needing to use a spanner every time.
18/11/2019 01:21:26
Posted by Pete Rimmer on 18/11/2019 00:29:53:
Posted by Shaun Belcher on 17/11/2019 23:49:58:
One other question, is with the apron assembly, are you supposed to lock down the power feed lever to stop it moving when making cuts?
I find the saddle will move across the bed if making an end cut with the top slide as I move the cutting tool into the stock. I found locking down the powerfeed lever would help, although i question whether or not it might need tightening up?
I take it you are disengaging the tumbler and locking the half-nuts? That's very poor practice. Use the saddle lock if you need to keep it from creeping during facing cuts, though you should be able to face without the saddle moving.
I did not know these had a saddle lock. I dont see any other levers on the saddle to lock it, I assumed that was the function of the power feed lever to lock it on the leadscrew.
The tumbler would be disengaged with the selector lever would it not?
I am not sure what you mean about locking the half nuts sorry, i just make sure leadscrew is disengaged and I engaged the powerfeed lever, which I assumed was how you locked it.
The topslide also creeps a bit when cutting, this is probably a worse issue TBH. I was not able to face off a part square without holding the topslide handle firm either, hence why this is the main area of attention for me currently.
The saddle seems to creep more if i was cutting directly on the face rather than facing off a part using the crossside.
17/11/2019 23:49:58
Posted by Hopper on 16/11/2019 10:44:24:
YOu hold the dial with a spanner on the two flats. Then turn the ball handle anti clockwise so it loosens off. Then you hold the feedscrew still and tighten the dial until end float is taken up. Then you screw the ball handle clockwise until it locks the dial in position.
Given your beginner level of mechanical experience, you should hold off from disassembling your lathe any more than is absolutely necessary to get it running. It is not a beginner project to put it back together correctly from scratch.
Yes you can get lengths of feed screw blank. It is an Acme thread. 10 TPI. Diameter, I forget but you can measure that.
If you want to convert to metric, you will need instead to buy lengths of metric trapezoidal threaded bar. Pitch I THINK wouild be 1mm But check that with someone who has a metric Myford lathe. So long since I worked in metric I don't remember.
You might find some metric trapezoidal threaded rod on eBay, Aliexpress etc. Otherwise there are several suppliers in the UK who have been mentioned on the forum before so a bit of searching around past threads should find them. But you will need to be able to use a lathe to turn the ends down and thread them to suit the dials and handles etc.
Another old trick is to cut the threaded section off the feedsrew and turn it around and reattach using a spigot etc so the unworn section of the feedscrew is now in the high-use zone. Probably more effort than it is worth these days.
Oil splatter from these lathes is not a problem. It's normal. That's the way they did things back then. It does not indicate anything wrong with the bearings. OIl will come out of a brand new bearing because there is always clearance between shaft and bearing -- to let oil flow through! A strip of rag tied around the gap between chuck backplate and the headstock bearing will stop most of the "fling". And don't stand in front of the chuck. Work standing in front of the carriage or even a bit further toward the tailstock. Keeps you out of the hot swarf zone somewhat too.
To test the bearings, hold a length of solid bar or pipe in the chuck, about a foot (30cm for you metric types) long. Grip the end of the bar and try to move it up and down and side to side. Measure the amount of movement of the spindle right at the headstock with a dial indicator. Or if you have no dial indicator you might get a rough idea by holding a finger on the spindle and bearing and feeling for movement. Should be about one thou (two or three hundredths of a mm) of movement. IE only just discernible by feel and that's all.
Edited By Hopper on 16/11/2019 10:51:29
Its all good, I think I was just being overly cautious. The handle was just on too tight. I managed to unscrew it easily enough and take a better look.
Just as i guessed, the washers were added to pull back more thread to catch all the way down since half the thread on the nut is missing and the unthreaded part at the end of the feedscrew would not catch.
Im going to have to rebuild both slides as a minimum.
It seems to be the most need of attention to make the lathe usable.
Good news is that I think the rest of the lathe is in fairly good condition for its age, does not seem to be heavy wear on the bed and minimal wear on the bearing from what I can tell.
Oil splatter, thats good to know its normal, yes where i stand it does not hit me, but it leaves a trail on the walls and floor so I want to address this if possible.
Have made a few cuts on bronze stock and even in the poor state of the lathe, currently things seem to measure up OK.
Right now the lathe is not very usable until i sort out the slides anyway.
Will do the test with a dial indicator to check the bearing wear as you suggest.
Was looking on myford site and yes the imperial leadscrew is 10TPI 3/8 diameter.
the metric feedscrew is quoted as Threaed 3/8" x 2mm pitch
I may just ordering everything from myford, but ive got a friend who can probably machine these easily enough for me which would be useful.
16/11/2019 08:11:50
Just pulled off the topslide.
Surprisingly the feedscrew looks OK, compared to the one on the crossslide which has significant wear to the threads.
The threaded nut on the topslide looks badly worn though.
I believe these are made from an alloy that is designed to wear out before the feedscrew does.
Anyway, I cant figure out how the handle and dial is removed.
Ive tried putting the spanner on it and it locks up no matter what direction i turn.
I think the last owner must have added the washers so that it has thread to catch on the feedscrew nut when its wound in all the way, as part of the thread on the outside is missing entirely.
Will probably leave it for now until i get the spare parts.
Does anyone know if this leadscrew threaded rod is available to fabricate your own leadscrew rods?
Would not be too difficult to make myself a set if i can get the rod.
I know ive seen this kind of stuff available for building CNC mills and 3D printers, but have no idea what specification the thread is for these.
16/11/2019 00:55:10
Posted by KWIL on 15/11/2019 11:45:11:
Shaun,
To reduce/eliminate the oil fling, apart from reducing drip rate, place a suitable sized O ring on the mandrel end and touching the headstock, oil then only exits on the inside of the bearing.
K
OK, ill take a look at that when i disassemble it.
I think it was the drip rate that was most of the problem, but looks like some oil is still getting past.
Would a worn bearing be a cause of this problem?
Im still trying to work out how much if any wear there is on the bearings, will probably need a dial indicator to check this.
Thanks for that drawing, I never realised the stock dials were not resettable.
Im assuming someone may have made a similar mod to mine, but ill take a good look when i strip all this down.
15/11/2019 10:50:55
Posted by Hopper on 15/11/2019 10:35:17:
Posted by Shaun Belcher on 15/11/2019 09:38:46:
Regards the dials, yup they dont work, when I turn the handle the dials will not often turn with the handle, either way, they are completley useless to me as imperial anyway.
If they are the standard ML7 type dials, the diecast ones with the angled face where the numbers and lines are cast on, they should not be loose. They screw on to the end of the feed screw. This is probably the source of most of your slop.
To adjust, you hold the feedscrew still and screw the dial on using a spanner on the two flats on it. When it snugs up against the slide, you back it off just a fraction so there is a thou or two clearance between dial and slide. Then holding all that still, the crank handle is screwed on against the dial to lock it all into position.
I'd suggest you get a couple of the old books on these lathes that have all this kind of lore in them. LH Sparey's The Amateurs Lathe and Ian Bradleys book on the Myford 7 Series are both still in print and an excellent source of info.
OK, ill take a look, I thought they just went round and round freely but were designed to slip when you want to set it to zero.
15/11/2019 09:38:46
Posted by Hopper on 15/11/2019 09:10:11:
Yes they are a total loss lubrication system. Oil just runs out of the bearings and down into the drip tray below.They are as messy as teh British motorcycles of the same era (1940s).
I try to set my drip lubricators to one drop a minute. Its hard to get them to run that slow though. I only ever fill the glass a quarter full, which is enough to last all day of constant use. Anything left seems to drain out over following days. I use 20/50 engine oil as I find the recommended ISO 32 hydraulic oil is too thin and runs out too quickly. Been using 20/50 on my old Drummond for 50 years or so with no damage done.
A folded newspaper page or two under the lathe headstock helps soak up the oil.
Cross slide screws: A lot of the slop can be the way the end float adjustment is set by the graduated dials and nuts and handles etc. Or by worn brass feedscrew nuts that are replaceable.
I dont know how the dials coould "not work". They have nothing to malfunction. Sounds like they and the retainiung nuts for the handles etc need setting and tightening , which will also remove excess end float.
You could spend the considerable money and fit metric screws and nuts and dials if it suits your needs better. But you will still have an imperial leadscrew, which is no big drama. You can cut metric threads with it without needing anything but the standard gear set by referring to Martin Cleeves' book Screwcutting in the Lathe. There is some small error in the resulting thread, - but so stupidly small that it is irrelevant to normal home workshop use. (Pedants will arrive at the gate with pitchforks and torches in 5, 4, 3, 2, 1 ...)
Ok, thats helpful thanks.
My rate is probably higher than that, will count how long it takes to drip, I thought it would be close to that but my oilers went almost empty after about an hour of use.
Interesting to know 20/50 engine oil is OK to use.
I thought it was quite cruical to have the thin machine oil like the rest of the lathe uses. I got a bottle of the stuff and i agree its quite thin.
The whole leadscrews are worn out from what I can tell from looking at them, I will see if I can grab a photo.
Basically there is a good half a turn of slop before the slide will move and the slide does not seem to stay still if making a cut and i cant even get a straight cut if i want to cut a part off flush, the resulting cut is almost dome or pointy rather than flat.
It looks like someone has tried tightening up the cross slide as its very hard to turn the handle when winding the slide in about 3 quarters of the way in. On the top slide, it looks like there is a big gap between the dial and the slide (see the second photo down on the first page) It appears someone has tried to pack up the slack with washers or something.
Im not doing any screwcutting anytime soon so i am not worried about converting the whole lathe to metric yet. But the only real cost is to get the extra metric dials, since the metric feedscrews and nuts are the same price as imperial ones.
15/11/2019 08:44:23
OK, quick update here.
I finally had my oilers, oil gun and some tooling arrive from overseas and have got the lathe working and made some cuts.
First thing ive noticed after a bit of use is the lathe is flinging oil everywhere from between the headstock bearing and the chuck.
Does this mean that the drip rate is too high? I thought i had it rather low myself. How long should a full oiler last before refilling?
I also assumed that the headstock would have had a drain plug to drain the old oil collected from the oilers, but it looks like its running out and on to the work bench and leaving oil everywhere. Is this typical?
Right now the main issue is the leadscrews for the top and cross slides.
I think Im going to need to strip these down and rebuild them.
Should I convert these to metric while im on the job? Imperial is not much use to me and im just measuring each cut with calipers as I go, and besides the dials dont work properly anyway.
17/09/2019 09:48:43
Posted by not done it yet on 16/09/2019 13:44:34:
I actually just looked at the product as shown in the above link. It says it is supplied with two nozzles. That means the nozzles will simply be screwed in place? So it would seem an extension would incur a simple threading operation.
I have no idea of the quality by just looking at the pic, whether good or bad or average. Your latest post, however, seems rather ambivalent - in one part you say you have not yet looked but you then say it looks a decent product.
it looks decent, but without physically looking at it and seeing how it works/fits, i dont have much idea.
I hate having to work on photos.
16/09/2019 12:47:01
Posted by not done it yet on 16/09/2019 07:53:57:
IF it is not, one can always extend the part by a simple threading or soldering operation?
Quite possible, just have no idea on its construction without looking at it, either way, it looks a decent product.
16/09/2019 07:02:59
Posted by JohnF on 15/09/2019 11:33:58:
Shaun, for an oil gun have a look here **LINK** I have two of these and they work very well, not 100% leakproof but very close, i also have the Myford "leakproof" model and mine leaks far worse then the cheapo listed here !
Regarding the bed re-grind by an engine re-builder a pal of mind did that for the surface then sorted the sides of the ways by hand with a bit out of the box thinking and it worked very well.
See your messages Cheers John
Good luck with the rebuild
Thanks for that info.
Ill take a look at that gun. Is the nozzle long enough to reach the nipple inside the gearbox?
Will check your message.
16/09/2019 07:01:36
Posted by Thor on 15/09/2019 05:43:21:
Posted by Shaun Belcher on 14/09/2019 23:44:22:
As far as i can tell with my lathe, all the nipples require H32 grade, and K68 is just applied directly to the leadscrews and gears? Is that correct?
Yes, and K68 also on the slideways, as said here.
Thor
Edited By Thor on 15/09/2019 05:58:53
Thanks, thats what I thought. Looks straightforward enough.
14/09/2019 23:44:22
Posted by Don Cox on 14/09/2019 14:27:12:
Shaun
A couple of years back I was lucky enough to inherit a couple of Valvespout oilers. These have small, on/off controllable, nozzles which will fit into the original Myford "flush ball" type oilers ball apertures and those in he grease nipple types too. The balls are then pushed off of their seats to allow oil in, I have one with H32 and the other with k68 grade oil in, they both easily deliver controlled amounts into all of the oilers on my two Myford 7s and an ML8 . Have a look at one on: www.longs.co.uk/acatalog/Longs_Shopping_Site_Oilers_83htm
Don
Thanks, Ill take a look at those.
14/09/2019 23:40:24
Posted by Howard Lewis on 14/09/2019 11:13:31:
Hi Shaun,
Yes it looks like the Reilang that I have. I removed the nipple at the end,mounted it on a mandrel (The thread is M5 or M6 ) and turned it to a slower taper, so that the slightly smaller nose would fit into small ball oilers more easily.
I can only recommend it. It very rarely leaks oil, but can generate enough pressure to force oil through the ball oilers on the saddle of my lathe until it appears under the wipers on the bed.
OK, thats helpful to know, I think I will grab one and give it a shot.
I guess i need two oil cans, since these lathes require 2 different grades of oil?
14/09/2019 00:11:25
Posted by Howard Lewis on 13/09/2019 22:21:02:
Firstly Welcome!
Have not read through all the foregoing, so my comments may already have been covered.
The gears with missing teeth suggest that the machine has been misused (abused was my original word)
Lets hope that it is not to badly worn or damaged to be not worth restoring.
Don't worry about the Japanese chuck. Chucks to fit the 1 1/8 x 12 tpi thread are available from a variety of countries, certainly India and China. the important thing is not where it came from, but how well it and accurately it functions. Assuming that it is a 3 jaw if it holds work concentric within 0.005" it should not be too bad, unless it has been strained and the jaws are belmouthed. If this is the case, the solution is either to regrind, in situ, or to buy a chuck in better condition.
Replacement gears should be available from the RDG Tools who now own the Myford trade mark and supply spares. Home and Workshop Machinery of 144 Maidstone Road, Foots Cray, Sidcup, Kent, DA14 5HS U K may well have second hand gears, as well as other suppliers.
Don't waste money on buying a Myford oil gun. Scatter gun would be a better description; it oiled just about everything, including me, except the parts that I wanted oiled.
Buying a Reilang will be money well spent. They are good, and put the oil where you want it.
For oilers, take a look at the Arc EuroTrade website, for Oil Cups, (although these are Metric thread, not Imperial so may need to have adaptors made. Chicken and egg!) and Drip Feed Oilers which are 1/8 BSP.
There will be other sources to be found on the web, I am sure.
HTH
Hi howard
Im not too worried about the chuck, although its been suggested to me it might be too heavy for it and cause excessive wear on the spindle bearings.
From what I gather, the broken teeth are common to see on these as it appears many people try locking the chuck with the backgear engaged in order to remove it.
Not too worried about the backgear right now. Plenty of used ones on ebay from myford stuff.
Regarding oilers, the ones RDG and Myford sell look identical to the ones from china on ebay at a fraction of the price. Am considering getting a pair for the time being.
Is this the right Reilang oil can? Its all i can find but does not look like it has the right fitting for the oil nipples. https://www.ebay.com/c/524999975
Some of the oil nipples are damaged and will replace them, are grease nipples usable? It looks like thats all they are that myford sell.
As far as oil guns go, this seems to be more popular than myfords (swiss) one they sell, its made in germany.
Any ideas how good this type is? https://www.lathespares.co.uk/myford-oil-lubrication/oil-gun-myford-lathe-1
Other than that, im going to hopefully test everything out next week. My main concern is how worn the bed is and if any wear is observed on the spindle.
12/09/2019 22:57:34
counted its teeth last night, and its a 21/56T backgear
12/09/2019 02:09:22
Posted by John Olsen on 11/09/2019 06:17:59:
Ok, just been out to check what my one has. The spindle has a 65 tooth bull wheel, that's the one with the little dog to engage and disengage it. The other one on the spindle has 30 teeth. The ones on the back gear shaft seem to be the 21 and 56 combination, assuming I counted correctly which is a bit harder with that one. It is a bit oily under there! My ML7 is early fifties vintage.
Is it the one on the spindle that is broken, or the back one? Mine has one tooth missing on the spindle one. I have the spare but have not yet got around to putting it in, and it actually works fine for the odd time I have needed back gear. NDIY is right that you can do a fix in a number of ways that will be quite satisfactory, they are not all that heavily loaded.
The usual cause of broken teeth on these gears is using the back gear to stop the spindle rotating so you can get a stuck chuck off. This is not what you should do!
The 65 tooth gear means that you cannot use a simple detent on the bullgear to do simple dividing, unless all you ever need is either 13 or 5 divisions.
Its my backgear thats missing teeth, the one on the spindle is OK.
yes i hear the same thing about teeth being broken when people try and remove the chuck.
11/09/2019 02:54:58
Posted by not done it yet on 10/09/2019 12:46:01:
Posted by Shaun Belcher on 10/09/2019 12:10:49:
Ive got to count the teeth on my broken one.
If there is only one tooth broken, it needs no more than 3 or 4 grub screws, a drill and tap(s), some loctite (or solder) and a little time spent with a suitable file. They are easily repaired.
That would be just one way to replace a broken tooth.
Ive just discovered its got another broken tooth on the other side after turning it around.
Pretty sure its 2 teeth broken.
10/09/2019 12:10:49
Posted by John Olsen on 10/09/2019 06:44:06:
You can get a new back gear easy enough from RDG, mine was about NZ$60 if I recall correctly. Change wheels are not a problem until you want to cut threads, so long as you have enough to give you a useful fine feed. The price sounds pretty good considering the prices sometimes asked for Myfords here in NZ, even if you do have to do a bit of work. Don't rush into doing any major work. until you have had a bit of a play with it.
So whereabouts in NZ are you? I'm in Cambridge (NZ) myself.
Hi John,
Yes been looking on RDG, also see a dealer on Ebay with used myford parts at reasonable prices.
Seems there are different ratios you can choose for back gears.
What one is typical for the ML7? Ive got to count the teeth on my broken one.
I see 21/56T and 20/55T available, not sure what ive got on mine yet.
Your right, myfords seem to go for a bit in NZ, i saw one go for more than I paid that looked much worse condition and had a broken back gear also.
I was able to go and look at the one i bought prior to purchase which was an advantage as I could get a better idea on the condition. Most myfords of this age are needing some attention anyway, and if i go and buy a restored one, i still have to trust that whoever rebuilt it did a good job and pay a premium price.
Im not far from you, im in Tauranga.
