Member postings for Shaun Belcher
Here is a list of all the postings Shaun Belcher has made in our forums. Click on a thread name to jump to the thread.
Thread: Tooling size for myford ml7?
12/05/2020 12:21:58
Posted by SillyOldDuffer on 12/05/2020 11:01:49:
Hi Shaun,
Part of the fun is learning the ropes!
An ML7 in good condition is a decent machine, but - like all machines - has to be used within it's limitations. Not serious in practice but the lathe was designed 80 years ago towards the end of an era when HSS tools dominated.
Lathes made before about 1900 were designed to cut with Carbon Steel tools. As Carbon Steels soften at about 200°C, early lathes are spindly affairs that cut rather slowly. No point in putting fast powerful motors on them because their bearings can't take the speed, and their frames bend. But, used slowly they produce accurate work.
Circa 1900, HSS hit the streets. HSS cuts without softening up to about 500°C, and can be worked 5 times faster than Carbon Steel, so 20th Century Lathes designed for HSS are much stiffer, heavier and powerful. During the 1930's it was found that carbides outperform HSS, and today's industrial machines are monsters, removing metal up to 30 times faster than HSS, and able to cut very hard materials. An ML7 isn't in this class, nor does it need to be! It's a precision machine, think scalpel rather than axe, used to make accurate parts rather than hack metal at maximum speed. Power - ¼HP is a bit low, ⅓HP reasonable, ½HP plenty and ¾HP over the top. Substitute patience and skill for brute force!
HSS can be sharpened on an ordinary bench-grinder. Mostly these are sold with grey wheels, coarse on one side, fine on the other, which is fine. Being a clumsy oaf, I'm not good at it, but grinding HSS just needs practice. Carbide inserts are an alternative; you can get HSS inserts, but the sharp carbide intended for non-ferrous metals works well on steel at ML7 speeds. They're available in bewildering variety, but the types sold by hobby suppliers are a good place to start. Inserts remove the need to sharpen, and I value their easy convenience. (About 80%)
Generally easier to get good finish with HSS because it can be sharpened. Carbide likes to cut blunt, and it produces an excellent finish when used to specification. But this is too much for most hobby machines, making it necessary to experiment sometimes.
Experts prefer to buy blanks and particular tools rather than sets, but I found a set to be a good way to start. With hindsight, a tangential toolholder is attractive, and Eccentric's Diamond Type comes with a jig to simplify sharpening even more.
Perhaps the best book on lathes available is Sparey's The Amateur's Lathe. Written in the 1950s, when the ML7 was new, the only disadvantage is it doesn't cover developments like carbide inserts. Highly recommended!
As you suggest, not all QTCP are well-made. My main objection though is value for money. First there's the tool-post itself, then the holders. I'd need 8 or 9 at about £20 each. Say £200, which is a lot of money compared with a handful of shims, especially as I don't change tools much. I've got better things to spend the money on, but others find them indispensable. Not necessary for a beginner, maybe later.
Thanks for that info.
I may well just use the lathe without a fancy QCTP for now anyway.
I have just finished machining a new feedscrew for my lathe today, using the cheap chinese carbide tools off ebay, they didnt do the greatest job and I had to improvise with shims(see photos!) but considering this, im still quite impressed with the finish.
I had to change tooling about 3 times, the parting tool i bought was supposed to have had the correct holder for an ML7, but it still needed heaps of shimming. This is the parting tool ive got, it seems to have a nice sharp carbide blade that has not gone blunt, but it takes ages to cut a part off!
I still really dont know alot about the different types of tooling, im really still learning at this stage.
I did have trouble making too deep cuts, probably taking off about 1-2mm max in one pass is about the most it can handle. Also it would also seem to slip rather than cut at times leaving uneven surface (see photo) I wasnt making a very deep cut when this happened, so not sure what was going on here.
All in all the finished part seems OK considering. Will be great to get some decent tooling anyway.
Edited By Shaun Belcher on 12/05/2020 12:29:00
12/05/2020 01:33:08
sorry double post by mistake
Edited By Shaun Belcher on 12/05/2020 01:35:24
12/05/2020 01:32:37
Posted by Shaun Belcher on 12/05/2020 01:32:37:
Posted by Steviegtr on 12/05/2020 01:09:19:
Not sure of which model ML7 you have , but assume it is the same as the super 7. This is the rating plate of my Super 7 B.
Steve.
If im reading this correctly, is that saying 2105 RPM is the top speed on a 50hz power?
From memory my ML7 was made round 1956 going by the serial number.
IDK what the story is with the white metal bearings, but they appear OK, certainly dont want to wear them out, but my neighbour tells me that his place of work is one of the few places still making white metal bearings/bushings.
Edited By Shaun Belcher on 12/05/2020 01:37:30
11/05/2020 23:48:50
Posted by Michael Gilligan on 11/05/2020 12:29:27:
Posted by Shaun Belcher on 11/05/2020 12:17:40:
Either way, I will probably add a VFD driven motor as an upgrade in future and get more RPM out of this when I get round to refurbishing the lathe.
Don’t over-do that speed increase ... The ML7 bearings may not last long
OK, well I think my one is underpowered, i have an old 1/3 HP motor running on it currently, wouldnt say its the fastest. Seems a few youtubers have a fancy setup with a VFD, but not sure what speed they are running.
11/05/2020 12:17:40
Posted by SillyOldDuffer on 11/05/2020 09:51:28:
I remember being confused by lathe tool-sizes too! I assumed that lathes took a particular 'correct' size, but it's rarely so.
All that matters is that the tool can be gripped by the holder with the cutting point at centre height. Oversized tool-shanks are a difficult problem because they have to be reduced to fit. Not worth the bother in my opinion!
Some tool-posts are adjustable. The American's once favoured a sort of tilting boat affair; never used one myself but they're criticised for being fiddly to adjust and not very rigid.
These days, the 4-way tool-post is common. It's a simple flat platform, pretty solid, and tool height is adjusted by shimming under the the tool, as shown in Shaun's photo:
Same idea except I have a collection of shims up to 4mm thick made in a milling machine, short lengths of 1mm steel strip (as used on big packages), and various thicknesses of aluminium strip. For thin shims, cut-up Aluminium Drink cans. I mostly use carbide inserts, and keep a set of pre-sized shims ready to go with each tool; this makes a 4-way tool post almost as fast as a QC type. As always much depends on how you work; frequent fast tool-changing in an HSS shop shouts 'QCTP'. But many HSS users do almost everything with one tool - a tangential tool-holder - see Eccentric's ad on this site. I've not bothered with a QTCP because ready to go shimmed tools are fast enough for me and because the tool does not need to be removed from the lathe for sharpening - changing inserts doesn't mess with the height setting.
The photo shows a second beginner booby trap. Those painted carbide tools! I had nothing but trouble with mine, and it turned out to be because they're not necessarily sharp out of the box. Being carbide, they can't be sharpened on an ordinary grinding wheel, and sharpening skills are needed. Another problem is carbide performs best on fast powerful machines, which the ML7 isn't! So, quite easy for a beginner to get poor results and assume his lathe is at fault, when it's just the cutter. Problem multiplied if a beginner also starts by cutting random scrap metal from his junk box because a metal-lathe will cut metal, right? No! Many metals don't machine well, and quite few are vile. DIY store metal is generally poor. Best to start with metals bought because their specification mentions free-cutting or machinability. EN1A-Pb steel, most Brasses, or an appropriate Aluminium Alloy.
Interesting read thanks Dave, I was not aware of such drawbacks with the QCTP, but I think some of it comes down to the quality of some brands I guess?
What seemed attractive to me was it made it hassle free to change the height and centre the tools etc without shimming up to suit. I probably could get away with a 4 way tool post, and perhaps I might just settle on that for now. One thing I can say for sure is I get tired of unclamping the tools and then bolting a new one back on!
Im still unsure why my height is so different on this lathe, if it should be closer to 9.5mm(3/8"?
I have measured a little over 14mm currently.
I was aware that these cheap carbide tools are nothing spectacular, I just grabbed them to test the lathe until I know what type of tooling is best.
I didnt know at the time that carbide required so much RPM to operate on either, and there seems to be a debate over HSS vs carbide for the quality of your finishing cuts. I had been reading a fair bit on this subject recently and seems it works best at a higher RPM as you say.
What I can say is I have tested these cheap tools on aluminium and i got a super smooth finish, my neighbour who is an engineer gets me scraps from his work and told me that aluminium needs to be turned at really high speeds for the best results which is interesting to hear.
Regarding HSS tooling, it seems everybody is grinding their own tools, I dont have any experience in doing this and find it hard to see how an ordinary bench grinder can do this? Im assuming you need a real fine grindstone?
As far as tooling goes, most that i can find seems to be carbide, particularly when it comes to thread cutting tools and boring bars that use the inserts.
I quite like the idea of inserts, can you get HSS inserts instead of carbide?
11/05/2020 08:58:43
Posted by Hopper on 11/05/2020 08:23:35:
Yes looks like it needs to be dropped a bit. You can use any strips of steel for packing. Bit of 6mm flat bar and bits of thinner sheet metal for fine adjustment might do it.
I don't mind the four way toolpost myself but it seems the QC ones are popular these days but you have to make sure you get the right one. Not all are great quality and not all fit the Myford well.
I was looking at the ones RGDtools sell, they seem to be reasonably priced and good quality, seem lots f myford users buy theirs.
Posted by Clive Brown 1 on 11/05/2020 08:50:51:
1/4" HSS is plenty for a Myford, cheaper and easier to grind than 3/8". Picture shows an arrangement that I copied from a Myford owner and used for years on my Boxford. Cheap as chips. With a selection of home-made holders, tool changing takes seconds. The packer for the Boxford is a piece of 1/4" plate, about 2.5" sq. with a hole drilled for the tool-clamp stud, but might not be needed for the Myford. I later replaced the clamping nut with a permamently mounted handle.
Tool-holder
Edited By Clive Brown 1 on 11/05/2020 08:55:18
That angled holder looks a brilliant idea, would make it super easy to get a perfect centre.
Is there anywhere you can buy these? Im assuming you milled yours out to suit?
11/05/2020 07:30:27
Posted by Hopper on 11/05/2020 07:19:22:
They used 3/8" tooling on them. Solid HSS on packing. It was crude.
If you get a QC toolpost it will be to take 8 or 10mm tooling. Others on here can share their QC experiences. I only use the old 4 way.
I was looking at 4 way too. IDK what is best, but QC seemed a good idea.
Here is a photo from the back of the lathe.
Its 16mm high in this photo (essentially using another 8mm tool as a shim)
Looks like it needs to be dropped about 1-2mm to make it on centre.
11/05/2020 06:47:28
Posted by Hopper on 11/05/2020 06:06:02:
Standard Myford 4 way toolpost takes 3/8" square tooling. That's about 9.5mm. You can use 8mm quite successfully by packing it up with suitable flat steel packing strips cut from sheet or flat bar etc. If you use modern 10mm carbide insert tooling you will need to machine a bit off either the bases of the tooling (very tough) or off the bottoms of the toolpost slots.
8mm boring bar is held the same way, clamped in the toolpost sitting up on packing strips to get tip to centre height.
If you have the earlier single tool saddle clamp arrangment, 3/8" tooling would have been standard, sat on suitable packing strips.
Edited By Hopper on 11/05/2020 06:08:00
My lathe basically has the early saddle clamp that you tighten the nut down to hold the tooling in place as you say.
3/8" seems like it would be too small on my lathe.
How i have it set up as if I was using a 16mm tool currently and its about 2mm too high after a closer inspection.
My guess would it needs to be about 14mm high.
I will grab a photo so I can show things in more detail.
11/05/2020 05:27:58
Ive just got a myford ML7 that needs a bit of TLC.
Im wanting to machine some new feedscrew nuts and replace the threaded feedscrews for a start.
I have bought a bunch of 8mm tooling on ebay, but its not high enough to centre the tip of the tooling, I have clamped down the tooling on top of a second 8mm tool and it brings it fairly close to centre, but even then, I could do with a fair bit of shimming.
Im assuming Myford originally used imperial tooling? I get the feeling 16mm tooling is not the correct size either.
I intend on getting a quick change toolpost soon, and I think they are designed for 8mm tooling to bolt straight in?
I also am not sure about the correct way to mount a boring bar. I have an 8mm boring bar I want to use on some projects.
I see these holders here on aliexpress.
https://www.aliexpress.com/item/32851566841.html?spm=a2g0o.cart.0.0.52e93c00ab3jsJ&mp=1
What would be the correct size for a myford? 20x20mm or 16x16mm?
Im hoping I can get these feedscrews sorted soon, biggest problem is that they are so sloppy that i cant even face off cleanly without the topslide moving on me while cutting, I end up with a dome shaped face instead of something nice and flush.
Thread: Acme thread
28/11/2019 05:57:51
Posted by Hopper on 28/11/2019 00:59:16:
I wouldnt use stainless. Can be a right PITA to machine and no great advantage in this application. Mild steel works just fine, especially with brass nuts. Most of the commercially available threaded bar will have a rolled thread which is left in a work-hardened condition.
If you do use bronze for the nut, make it leaded bronze and not phosphor bronze as the latter will wear non-hardened steel faster. The idea of brass nuts is the same as Myford's orginal Zamak, the nut is sacrificial and wears faster than the leadscrew. So you replace the inexpensive nut, not the expensive leadscrew. Plus its easier to machine.
Don't suppliers of trapezoidal threaded rod also usually supply brass nuts to match? Would be easier, and probably cheaper, to buy the nuts even if you have to machine them down to a sleeve then bore out the original nut and Loctite and pin the sleeve in place.
Edited By Hopper on 28/11/2019 01:04:09
Edited By Hopper on 28/11/2019 01:22:27
The supplier sells the nuts but they dont have the correct flange, I would have to machine them down as you say, plus they are expensive, although I can find the same ones overseas for a fraction of the price.
Yes ive seen a youtube video of someone engraving dials in a similar fashion. I just dont have any of the correct gears for my lathe at the moment.
Im still in the process of getting my lathe up to scratch and getting tooling etc.
28/11/2019 00:02:04
Posted by Andrew Johnston on 27/11/2019 22:21:29:
I made these square thread serial taps:
to make the nuts for the brake shafts on my traction engines:
After I'd made them I cut a trial thread in brass which was easy. In contrast the bronze I used for the actual nuts was a total PITA.
Edited By Andrew Johnston on 27/11/2019 22:22:12
Wow, thats impressive! I dont think that grinding HSS to make taps would be an overly easy job.
Anyway, ive been looking at different taps on the market and they appear to be fairly tapered and long so should in theory make it very simple to cut the thread without a sequential series of taps.
27/11/2019 21:41:46
Posted by ega on 27/11/2019 14:29:18:
Posted by IanT on 27/11/2019 10:20:08:
I'm not going to jump into any Square/Acme/Size of Material discussion here Shaun - just wanted to support Hoppers statement (warning) that 'tapping' an Acme tread is not as simple as just buying a single Acme tap and drilling a suitable hole. I think you will find it is very hard (if not impossible) to turn it.
I was surprised by this as I recently had no difficulty in tapping a length of cast iron 1/2" x 10TPI acme. I should add that this was done under power and the tapping hole was slightly oversize. Other materials may well be problematic, of course.
Its interesting to know anyway. Im not sure if its as difficult with brass or bronze?
27/11/2019 10:39:37
Also regarding material of choice, i see I can choose the option of stainless or just (mild?) steel.
What is the best option to go for regarding wear?
Stainless has the added benefit that it wont rust.
I think its pretty clear to me now that the metric feedscrews myford solutions sell are simply made from standard 10mm  2mm pitch trapezoidal prethreaded rod.
Edited By Shaun Belcher on 27/11/2019 11:03:04
27/11/2019 10:38:26
Posted by Shaun Belcher on 27/11/2019 09:05:21:
"making the nut is a piece of cake too."
It's either a staged tap (e.g. more than one tap = quite expensive) or an interior thread cutting operation, perhaps using a tap as a finishing touch, if you already have a suitable tap. I've seen YouTubes of folk going straight in with a single Acme tap but I don't know how they do it - because I certainly couldn't when I tried it, albeit on a slightly larger (1/2" x 10tpi) nut.
Of course, if you can purchase a screw & matching nut and modify them to suit your application, then this need not worry you.
IanT
Edited By IanT on 27/11/2019 10:22:46
OK, ill take note of this. I never realised it was that difficult. I see Geffoery Crockers restoration video on youtube he is simply tapping the holes after drilling and looked fairly straightforward to me.
Either way, i have a friend who can probably do this easily enough on his machine at work.
27/11/2019 10:36:41
Posted by mark smith 20 on 27/11/2019 09:37:14:
Shaun , a slightly larger diameter screw would still work the same in regard to the dials if the pitch TPI is the same .(as long as everything else is machined to fit (the nut, dials ,handles etc...)
Edited By mark smith 20 on 27/11/2019 09:37:59
Thanks, thats all I need to know.
I would hate to find the dials were not accurate if i used this feedscrew.
Im actually considering making my own resettable dials anyway, but would need to CNC engrave the markings on the outside accurate enough
27/11/2019 09:16:41
Posted by Michael Gilligan on 27/11/2019 09:09:04:
Posted by Shaun Belcher on 27/11/2019 08:45:24:
Anyway, from what i understand, acme was the term used for trapezoidal thread in the days of imperial?
Shaun
This is important ... although sellers all over the world seem to ignore the facts these days:
The ACME thread form is very specific, and has 29° flanks
The Metric equivalent is Trapezoidal, and has 30° flanks
Details of both are readily available.
[sorry for preaching from my soapbox]
Either way, I dont think its critical for operation but may affect how smooth the handles turn?
May also affect the rate of wear? Seems trapezoidal is easier to find than square thread anyway.
The supplier in the link i posted also stocks rolled ballscrew, ground ballscrew and satellite roller screw.
I have no idea what the difference is between them.
27/11/2019 09:05:21
Here is what I can source at a fraction of the price and make my own replacements.
Exact same 2mm pitch as specified, only difference is the diameter is 0.5mm larger than myford's.
https://www.mooreinternational.co.uk/ProductGrp/10x2-quality-rh
What complicates things is if you need to machine it to the exact 3/8" (9.5mm) diameter that myford use.
If the feedscrew diameter is not an issue, then this is a simple and cost effective replacement.
27/11/2019 08:52:31
Posted by Michael Gilligan on 27/11/2019 08:47:55:
For the sake of clarity [hopefully not for further confusion] regarding the metric screw threads
The aftermarket versions supplied by MyfordSolutions are very clearly stated to be 2mm pitch.
https://myfordsolutions.com/collections/ml7-carriage-assembly
Click the thumbnails for individual descriptions:
” Each rotation of the spindle gives 2 mm displacement. “
Myford also state 2mm pitch for their metric feedscrews.
What im saying is I can buy the prethreaded rod 10mm in diameter with a 2mm pitch.
Myford say theirs is 3/8" diameter which is about 9.5mm diameter.
Is there any issues with accuracy if i use a slightly larger diameter feedscrew? e.g, change the TPI rate?
Please note, that I also would be machining my own nut to match.
Edited By Shaun Belcher on 27/11/2019 08:52:51
Edited By Shaun Belcher on 27/11/2019 08:53:10
Edited By Shaun Belcher on 27/11/2019 08:54:25
27/11/2019 08:45:24
Posted by Hopper on 27/11/2019 07:01:25:
I think you will find Myford uses Acme thread (or maybe trapezoidal for metric?) and not square. But square will certainly work for you if that is what you can buy in threaded rod.
Tracy Tools and others can supply square and Acme thread taps. Many on eBay too. Can be a bit hard to tap large chunky threads like that from scratch so it is common to rough it out by screwcutting in the lathe, even with a steep-sided V tool and finish with the tap. Or buy a set of progressive taps.
I make all my leadscrew nuts from brass, not bronze. Less wear on the leadscrew that way. And easier to machine.
Im quite lost to what thread Myford uses, but most sources ive seen say that myford used square thread on all their lathes.
As far as bronze goes, I think alot of people call brass bronze and vice versa. Bronze is supposed to look more copper in colour isint it?
The nuts in the photo certainly look brass in colour than the coppery bronze colour.
Anyway, would a 0.5mm increase in diameter over the original myford imperial feedscrew change the TPI and affect the dial readings? Or does it stay constant irrespective of the diameter if the thread pitch is the same?
26/11/2019 21:19:25
Posted by not done it yet on 24/11/2019 06:30:09:
8 tpi would be close to 3mm pitch (actually 3.18). Please do not assume anything - you may well be wrong, so always check it out properly. 2mm pitch is just that - there is no need to try to convert to imperial (it would actually be 12.7 tpi!).
While not standard myford, I would make them in square thread, not acme, although at only 3/8” diameter that may be a little more awkward. Cutters are easily ground in the home workshop for both inside and outside threads.
Myford’s competitor (‘just down the road&rsquo used square threads for feed screws - but 1/2” in diameter. Nothing at all wrong with their feed screws (their lathes were of much higher quality than those of myford). I am currently cutting a new nut in square format for one of those. One only really needs ACME thread for lead screws, that need to be engaged and disengaged with half nuts.
One could always cut the screw easily enough and then make the feed screw nut in acetal. Probably better to cut a piece of extra screw for that, including clearance, as acetal will leave no thread clearance when moulded by the ‘heat and squeeze’ method.
I got the 8tpi figure somwhere else on another myford thread in a forum (excuse the pun lol)
I didnt think it sounded right.
Anyway, ive done a bit more research and yes, its supposed to be a square thread, and I believe this is what Myford use.
I also found a blog where someone machined their own feedscrews and nuts. You need a moving steady and the right screwcutting gears and ground cutting tooling etc.
Quite a lot of work and hard to do a nice job, he had to do many slow passes on the lathe.
He made his shaft 9mm but 3.8" is closer to 9.5mm
Does shaft diameter affect TPI?
If not, I think ive found the answer.
I can find many retailers who stock square threaded shaft in 10mm diameter, 2mm pitch.
Should be able to find the correct tap to make my own nuts also.
If you look at the aftermarket feedscrews that myford solutions sell, they look simply like they are made from cut down prethreaded rod, with the end machined down and threaded to accept the handle.
They differ in that they dont have the unthreaded "lip" at the end of the shaft, I thought this may have been required, so not sure why they machined them like this, unless they had to do away with it by using prethreaded metric rod.
See photos:
Myford feedscrew
Myford Solutions aftermarket feedscrew
Their feedscrews also are bronze, not the crappy zamac alloy that myford uses, but I will machine my own if this will work with 10mm rod if it does not affect the dial calibration.
