Here is a list of all the postings Tim Ellis has made in our forums. Click on a thread name to jump to the thread.
Thread: Electrics for a battery locomotive |
09/06/2019 21:31:49 |
Hello Everyone, I just wanted to say thank you for all the help unfortunately I've been in hospital and recovering from an operation so hadn't been able to reply sooner. I managed to wire up the locomotive today and fitted a 20amp fuse and circuit breaker. Everything ran perfectly on the rolling road. . Many thanks, Tim |
19/05/2019 21:04:05 |
Many thanks Dave, Emgee and John. The motors do not have any information on them, I've looked at every part of the body but nothing. The chassis I am using is the remains of a sadcastings dock shunter which uses two of these http://www.sadcastings.org.uk/accessories/standard-part-detail/electric-motor# I can only assume these are the same type as I have. very best, Tim Edited By Tim Ellis on 19/05/2019 21:05:07 |
19/05/2019 18:14:45 |
Hi Dave, Many thanks for the reply, I'll look into this tonight. Can I ask how you calculated the right fuse? Its just I'll probably build a second in time and would like to understand every little aspect. Many thanks, Tim |
19/05/2019 16:12:23 |
Hello, This is probably going to be a very simple question but I am not familiar with electrics and need some help. I am building a 5 icing gauge battery locomotive. I have 2 12volt motors fitted which will be powered by a 12volt 24ah battery. The control unit is a 1x Motor Speed Controller Forward Reverse Switch PWM Governor 12V 24V 36V TE952. I think I should add a fuse and a circuit breaker but I do not know which one or how to go about calculating the right ones. Many thanks, Tim |
Thread: 5 inch 0-4-0 Shunter |
19/05/2019 16:08:26 |
Fantastic work. I am also building a 5 inch gauge locomotive. Can I ask, I have sued the same controller, have you fitted a fuse box and circuit breaker? and if so which ones have you used? Many thanks in advance. Tim |
