Member postings for James Cliff
Here is a list of all the postings James Cliff has made in our forums. Click on a thread name to jump to the thread.
Thread: Colchester Triumph 7.5" (Round Head) Lathe
08/04/2019 07:44:38
Thanks for the replies all.
There is practically no room either side of the gear to get a pin though, so I think your right. The shaft will need to come out.
Phil do you have a copy of the manual? Or a link to download?
Thanks
06/04/2019 13:17:21
Hi,
I have a Colchester Triumph 7.5" Mk1 (Round Head) which is used every day in our machine shop. It's an old girl, but it is priceless to our business and is still used just as much as the other lathes.
Today however it's given up. We can still select all gears on top (two levers) but the main high / low gear lever on the front is the issue. In low box all is fine. In high box when running the spindle slowly moves in its correct direction. But it doesn't pick speed up and I can stop it by hand.
I've removed the head off the gearbox and noticed that the high speed driving gear (drives spindle tube through selector) is spinning freely on the shaft. See attached pictures and video.
Video
I can’t find any tech drawings for this lathe. There is no grub screw, roll pin or bolt to hold the gear onto the shaft so I can only assume its fixed to the shaft through splines. And subsequently the splines have worn off? However, it went from working fine to not in the space of 5 minutes with no grinding or typical gearbox failure sounds.
Does anyone have any experience with these lathes, and would be kind enough to advise?
Thanks
