Member postings for Gary Barnes 2
Here is a list of all the postings Gary Barnes 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Inverter Tripping RCD
07/03/2019 11:31:07
I know this is an old post, but the obvious and safe solution would be to put a 230V isolation transformer between the mains supply and the inverter. The type that are used on building sites are available from RS for under £100 depending on size, which is cheaper than getting an electrician in and swapping circuit breakers. The RCD will not 'see' any leakage to earth through the inverter.
