Here is a list of all the postings Finnian Dawson has made in our forums. Click on a thread name to jump to the thread.
Thread: Mini Lathe - turning 6" long, 1.5" dia AL |
30/06/2019 21:33:34 |
Can't turn between centres in an SC2, just Chuck and centre. Have a dead centre already, but no fixed steady, nor centre drill for that matter. Must get the bit and fixed steady and see how I get on.
Edited By Finnian Dawson on 30/06/2019 21:35:11 |
30/06/2019 20:16:28 |
Hello All Having a little trouble turning AL stock, piece needs to be 6" long, and I am starting with 1.5" diameter stock in the 4 jaw. I know that this exceeds the ideal length:diameter ratio, so I clearly need some support to counteract the cutting forces. My lathe is a Sieg SC2, so as far as i can tell, turning between centres isn't possible as I cannot get a centre in the headstock. Is a fixed steady the best solution for my case?
Thanks Edited By Finnian Dawson on 30/06/2019 20:17:29 |
Thread: Help with mini lathe/required tooling to turn a 20mm Cylinder from AL |
05/03/2019 10:37:57 |
Thanks to all, appreciate the helpfulness in offering to sort out this job for me. What Dave outlines above aligns well with my thinking. Would like to perhaps add a milling feature later on, but all work will be on a small scale and low volume of pieces. Looking at importing from Sherline in the USA. |
04/03/2019 21:20:37 |
Dublin, Ireland |
04/03/2019 19:31:07 |
Hi All I have very little experience with metal-working, did some at college some years ago. I wish to buy a mini lathe solely for the purposes of turning a 20mm dia cylinder, stepped to 35mm, total length approximately 12cm. Aluminium or brass would be the material I am just wondering which mini lathe might be recommended that comes with all required kit to accomplish. Trying to keep purchase price as low as possible.
thanks |
