Member postings for vic newey
Here is a list of all the postings vic newey has made in our forums. Click on a thread name to jump to the thread.
Thread: unknown taper on lathe centre
05/10/2022 11:40:36
Posted by Howard Lewis on 05/10/2022 10:38:41:
If the rest of the lathe uses Imperial fittings, threads, etc, using Metric units may be counterproductive and confusing.
measure major and minor diameters, a carefully measured distance apart..
Convert your dimensions to Imperial and use those, to calculate in various formats..
The taper can be expressed in a variety of ways, Angle, Half Angle, Inches per Foot, Inches per inch.
the "Tool-n-Gizmos" website lists many tapers and their dimensions.
You may find what you require there.
Nothing on Lathes UK that helps?
Edited By Howard Lewis on 05/10/2022 10:39:09
The lathe is of German manufacture but has an unusual mix of imperial and metric parts, so it has Whitworth fasteners, an 8 tpi mandrel thread but apertures for backplates, faceplates etc are 40mm metric. This was due to the Victorian era UK importers insisting on Whitworth threads.
Looking on tool-n-Gizmo I think the nearest similarity is a B-taper, a B18 has 32mm taper length as on mine
Vic
05/10/2022 10:19:24
Posted by Michael Gilligan on 05/10/2022 09:50:06:
I would be tempted to first convert your measurements into all known ‘systems’ and then browse through this lot:
**LINK** http://www.tools-n-gizmos.com/specs/Tapers.html
For example, the taper could be expressed as a half-angle slope of 1:32
Edited By Michael Gilligan on 05/10/2022 09:53:23
Thanks for replies, there's some types on that link I've not seen before, a B-taper might be the closest to mine, B18 has 32mm taper length
05/10/2022 09:35:44
This centre fits the tailstock of my vintage Pittler lathe c.1895, the shaft is just 32mm long and tapers from 14 to 12mm.
It's not any taper that I can recognise so has anyone got any suggestions as to what it might be and if so any other lathes that use this taper?
Thread: UK DRIVING LICENCE [ 2022 issue ]
29/09/2022 18:06:38
If you order your licence online and don't tick any health problem boxes then the new licence comes through fast. That would be done by computer or thousands of DVLA employees. However medical ones are done by Blodwyn Davies working from home in Blaenau Ffestiniog, she is currently is not feeling too well so claiming sick pay with a sicknote verified and accepted by the DVLA.
If you tick a health problem box then you open a can of worms which goes on for months and months. DVLA ignore your doctors or consultants letter saying you are perfectly fit to drive and likely as not will send you for their 'special' tests.
Not declaring any medical problems you have that appear on the form not only voids your motor insurance but also leads to prosecution by the DVLA and £1000 fine + big problems if you were involved in an accident with injuries
Thread: How can you check that DVLA field of vision machine is OK.
29/09/2022 17:00:05
I have Ocular Hypertension, sometimes as high as 35 but eye drops help keep it lower, rarely below 21. The clinic is amazed that it's not caused any damage to my optic nerve so far.
However, in early May I filled in my new over 70's licence application for my birth date 25th June and ticked I had an eye problem, weeks later a reply came asking for details and I ticked ocular hypertension giving name of my consultant etc who can confirm I do not have Glaucoma etc.
Weeks go by again and then a letter arrives telling me to select one of the few special Specsaver branches for the two tests. Clearly a medical consultants confirmation of my eyesight is not good enough for them.
The only option at Specsavers was 8-45AM for any of these appointments, the DVLA specify that their customer must be the first to use it each day to avoid contamination etc.
First was reading the eye test letters on a weird square monitor, alternate eyes without my glasses then repeated with them on, I can easily get to the bottom two letters on a normal opticians one but struggled on this as it made my vision feel weird with the glare.
Then the field of view test, so much better doing both eyes together as covering one eye up with an elastic pirate patch or more recently cotton wool held on with tape so you have to screw your eye up while looking through the other one and then swap for the eye you just screwed up closed for two minutes.
He showed me the printout of the test, he wasn't allowed to actually tell me but it looked 100% to me, no little crosses missing, then he checked for any I had missed and then said very good and got out a phone for me to sign with the end of my finger and he pressed send.
Today my licence arrived at last after 5 months, no mention of of anything to do with those tests etc
Edited By vic newey on 29/09/2022 17:10:27
Thread: Best reference book for a lathe novice
29/09/2022 09:24:57
It's nice to sit down and read a book but when many 'how to use a lathe' type books were first published we did not have the internet.
A single Youtube video can demonstrate something that might confusing in a book at first so read about it and then search for a video to see it in action
Thread: Unknown attachment for vintage lathe (1895)
28/09/2022 09:50:21
Posted by Michael Gilligan on 27/09/2022 20:51:52:
Posted by vic newey on 27/09/2022 09:16:08:
Posted by Michael Gilligan on 27/09/2022 08:29:01:
… or is it conceivable that they are used to adjust the bearing to a ‘no shake’ condition prior to commencing work ?
The spindle is a perfect fit, no play whatsoever, the end play can be adjusted via the gear casting bolt.
I will take that as an emphatic NO then, Vic … and wash my mouth out accordingly
Apologies Michael , I didn't realise my reply sounded harsh, I just realised that the split in the casting being underneath would drip out any oil from the spindle unless the whole thing is upside down of course
Edited By vic newey on 28/09/2022 09:50:37
Thread: 1 HP single Phase motor for mill
27/09/2022 14:26:46
Here is my old thread with a really noisy Clarke 3/4HP motor, part way down the thread is a Youtube video of it running which Clarke head office had access to and refunded me straight away
Noisy Clarke motor
27/09/2022 09:16:08
26/09/2022 22:20:20
Posted by Bazyle on 26/09/2022 20:01:36:
I'm a little horrified that you suggest surgery on what might be a factory prototype or extremely rare item. There has been little time for less frequent readers of the forum to respond, and have you enquired on other forums? You might consider making the missing parts, preferably in the same style as the original, and adding other options.
My suggestion of it being a prototype is based on the second boss being unbored as I fancy that was for a bar to hold a tailstock as per the Myford dividing head. I also venture that the extra-long spindle indicates possible use as a slotter with the robust vertical bar being thus to provide a suitable fixing for the lever.
Don't worry, regardless of what I wrote I have not the slightest intention of performing any surgery on it, it will remain on the accessory shelf with other items belonging to the lathe.
Likewise I see no point in attempting to make unknown missing parts without having any real clue as to what is actually missing.
26/09/2022 15:46:26
In the interests of science and technology and possibly saving the planet I have dismantled it.
you can now see that the spindle has a slot to push out the inserted item in the taper which is slightly bigger than MT1, The lathes tailstock has an unknown taper as well, luckily it came with a centre (which does not fit this thing properly as it jams halfway in) I think I'll ask about that unknown taper another time
Also the main casting is cut through underneath and has two bolts which can only be to lock the spindle tightly so that adds even more questionsfrown
The gear has 40 teeth and most parts have '2' stamped on except the insert disk with keyway which has two letter A's of different font types.
I guess this is rather useless as it is although the main casting and slide could be converted to a vertical T slot table with a bit of surgery. cool
26/09/2022 14:23:44
Posted by DC31k on 26/09/2022 13:02:09:
Posted by vic newey on 26/09/2022 12:20:23:
And it has the same type of dividing spindle as on my Pittlers
Please, in the photo, are the two worms interchangeable? That opens the possiblity of having a low count worm wheel and a high count wormwheel.
To my eyes, one of the advantages of a notched-disk dividing plate instead of the more modern one with hole circles is that it could be used with a ratchet mechanism (e.g. like the cross feed on a shaper) driven from another part of the machine in order to advance a set number of notches. Have you ever seen anything like that?
In relation to the machines by Holtzapffel is the Pittler earler, later or about the same time period?
Here is a catalogue page showing automatic indexing via a notched plate on the bottom right and another page with some milling attachments inc a chain driven one!
Edited By vic newey on 26/09/2022 14:25:06
26/09/2022 13:56:56
There is a one start and a five start worm with the dividing spindle which is easily exchanged.
My C3 lathes main drive has 7 worms instead of the normal three provided as standard so there are 1,5,6,7,8,9 and 10 start together with 20 wheels.
Some of my old Pittler catalogues show milling attachments with a ratchet mechanism using a notched disk, if you would like to see I can scan a page or two
Pittler lathes began with his first factory in 1889, I think that Holtzapeffel are earlier than that
Vic
Edited By vic newey on 26/09/2022 13:57:16
Edited By vic newey on 26/09/2022 14:26:51
26/09/2022 12:20:23
Posted by Michael Gilligan on 26/09/2022 10:54:59:
I think it’s easy to see the same mind at work:
26/09/2022 09:55:27
Posted by Michael Gilligan on 25/09/2022 23:19:44:
Vic,
Please excuse what is probably a digression, but
Inspired by this puzzle to browse all things Pittler, I have just stumbled across his rather beautiful patent for a universal milling machine:
https://patentimages.storage.googleapis.com/77/13/64/7b1e6c7a2372d4/US580195.pdf
Hello Michael,
von Pittler was an incredible inventor, over 200 patents were lodged by him. The worlds first vertical rotating capstan lathes that could hold as many as 30 tools changed production machines forever. Pittler still exist today with their 'revolver' lathes
26/09/2022 09:43:40
Posted by Nigel Graham 2 on 26/09/2022 08:57:32:
I see what you mean! It has a very gentle helix angle though, and is definitely not a regular worm-gear.
I looked at the drawing Michael's link opens, of Pittler's patent-application for a universal milling-machine. That is festooned with worm-drives, so it's feasible that Vic's lathe attachment gives the some similar functions. Although the patent drawing shows the worm-wheels are clearly that.
There is another detail about it. Outside of the gear is what looks like a locking detent that engages a hole faintly visible on the second photograph. There appears only one hole in the wheel, and the detent does not seem a quick-release type.
Vic - I reckon you'll have to carry out some careful experiments!
I will indeed!
The hole you mention is for oiling the spindle as it goes right through
however here is a rare type of drum type milling head I got with the machine, it has a stem that fits in the saddle casting in place of the cross-slide and is powered from an overhead drive.
It has a cross-slide and and rotation of the drum and it's cutter via top handle. It's cutter can be turned to any angle and runs via the worm and wheel mechanism. Not got the overhead pulley set up so not tried it yet.
Edited By vic newey on 26/09/2022 09:47:25
26/09/2022 09:28:21
Posted by Martin Kyte on 26/09/2022 09:15:23:
Posted by Nicholas Farr on 26/09/2022 09:04:00:
Hi, I have seen wing nuts with holes in the wings, which were manufactured that way, but they were normally quite large ones, so maybe for reducing their weight, which if you had a large number of them on a machine, could make quite a difference to the overall weight of the machine.
Regards Nick.
More likely a reduction in the material cost of the nut.
regards Martin
The holes in that wingnut were made by a previous owner, the other one at the rear that locks the cross-slide stem is as original with no holes in it
Edited By vic newey on 26/09/2022 09:28:39
26/09/2022 09:21:04
Posted by Nigel Graham 2 on 25/09/2022 22:17:19:
The power cross-feed would be part and parcel of such use; but presumably also for plain turning. Though the universal-joints look rather close to their angular limits for consistent rotation: can their first shaft be set further back?
The universal joint still works at acute angles and is intended to be used near the headstock end of the lathe, it's long shaft has a keyway slot that locates in the inline gear wheel so can slide along to it's limit. there is also a short further extension as in the photo below which shows a gear fitted on the end of the cross-slide stem for ball turning
25/09/2022 22:02:28
Posted by Bill Davies 2 on 25/09/2022 21:08:32:
Thanks, Vic. That's a lovely looking machine. I have a Britannia which must be a smilar vintage and shares some of the styling of the period and (before I painted it an inappropriate grey) a black finish. But a much less sophisticated machine, although it sounds similar when running.
Bill
Yes my Pittler C3 makes a nice clatter as it runs through the various gears to the final drive
I just love old machines, for me that is the enjoyment rather than what I could make on them. I have 2 Pittlers from 1895, a Holbrook from 1937 and a South Bend from 1939.
25/09/2022 20:40:40
Posted by Bill Davies 2 on 25/09/2022 19:47:30:
Vic, I didn't make clear that I was referring to the slide at the bottom of the attachment. The surprising feature for me is the small worm and wheel, is there a ratchet that operates it? I can't see a micrometer dial to indicate the amount of travel.
Bill
Hello Bill,
the worm and wheel are for power cross feed via the universal joint, because the leadscrew is inside the bed this is how von Pittler got around the problem. The machine also has a power circular feed using the same UV
here is a video of me testing it out Power cross-slide on the Pittler C3
