Here is a list of all the postings NIGEL WOOD 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Meddings scroll saw |
24/07/2019 16:28:48 |
Hi, I have purchased a meddings scroll saw / frett saw for my son. Has anyone got a manual or pdf, or as well as any information you can share as to the blades etc it will require. It doesn't have any with it. Also without having a good look know how they fit. Kind regards Nigel |
Thread: Myford Vm-f |
09/02/2019 12:39:01 |
Hi Chris Sangstar, many thanks for your reply, I would really appreciate a scan copy of the leaflet you have on the vm series. That would be very useful. My direct email is. [email protected] kind regards Nigel |
06/02/2019 13:39:15 |
Thank you all for your help. Sounds like the vme and vmf models have a solid column and base all in one. I did wonder at pictures of them as there is a fillet radius at rge bottom of the column which looks part of the base/stand. I will try to find a pallet truck, pallet and a tail lift Luton van should make it easy without stripping it at all. Kind regards Nigel |
05/02/2019 12:47:26 |
Thank you Martin for that information, very helpful. They must be seperate parts as they are referred as separate piece is the info. Are your mates bolts viable where it connects to its base /stand. As they don't seem to be in pictures between the vmc and vme or f versions. The vmc are quite easy to see. Many thanks Nigel |
05/02/2019 12:25:45 |
Many thanks for your quick response to my question. The vmc does look straight forward to detach the column and knee from it base. But the Vmf if much larger and you cannot see the bolts at the lower part of its column or knee. I need to know someone who has one to check and verify if it is bolted to the base and tray. I've located one from an old lady but cannot give me the correct info that I'm asking for. She's also to far away for me to visit to check this. So I need to know before I attempt to collect it. Kind regards Nigel |
03/02/2019 22:28:11 |
Could anyone tell me if its easy to dismantle a myford vmf milling machine. Is it possible to transport in a transit van or is the machine to heavy. I don't know how much one weight as there isn't much info on the Web about this machine. I'm hoping someone out there has one to let me know if it's possible, and if it's easy to detach the column and tray from the base, etc. Can anyone help please. |
