Member postings for Chris Thorn
Here is a list of all the postings Chris Thorn has made in our forums. Click on a thread name to jump to the thread.
Thread: How to machine a flat and a slot on each end of small bar that are in line with eachother
09/08/2022 18:19:36
Success using a spilt block , took longer to make up the split block than the part , always the way !
Rounded the flat end to suit the piston swing
Thanks for the advice !
09/08/2022 13:08:16
Thanks for the ideas guys
It has got me thinking out of the box
I will probably try Roberts or Bikepetes suggestions
I will let you know how I get on
09/08/2022 12:16:32
This may seem simple but I am a bit stumped how to do this
In the drawing below I and have to machine a slot on one end and a flat on the other , If I hold it in stevensons collet holder to use a slitting saw for the slot , i have to remove and turn it round to mill the flat on the other end, thereby losing the horizontal plain. It is too short to get a DTI on the other end to adjust for flatness as this will be inside the collet.
Can any of you season engineers give some pointers on the process for doing this
Cheers
Chris
Thread: Jumpy readout DRO scales on WM16 mill
08/07/2020 21:08:29
Rik
Dont use it until you have checked over the machine with a multi meter ,. Check all Exposed metal parts back to the earth pin of the 3 pin plug .
Better safe than sorry
As Robert says it should not rely on a grub screw for an earth path. I would connect an earth wire from the incoming earth block to the chassis of the machine to be sure
Chris
07/07/2020 22:12:17
Rik
I had an identical issue with my Wm16b
after head scratching and help on this forum I found out that the machine was not earthed correctly
step 1. Get a multi tester and check from the earth pin of the 3 pin plug of the mill to an exposed metal part of the machine it should be around 0.1 ohms if it’s more than this I would check the earth block in the control panel is bonded to the chassis correctly. Do not use the machine until you have done this.
step 2. If step 1 was ok check the earthing on the socket it’s plugged into.
unfortunately my thread was removed for reasons I still don’t understand?
hope that helps
regards
chris
Thread: Muncaster's Simple Entablature Engine
26/04/2020 10:06:28
I quite fancy having a go at this
Is there anywhere I can download your plans Jason?
I can access previous back issues but can’t easily print these of the magazine viewer
thanks
Chris
Thread: A good toolpost drill design
20/01/2020 13:12:56
Thanks for the suggestion Guys.
I guess it comes down to either a Flexible shaft design or go for a motor mounted above the spindle to provide power. I like your modification Mike .
Rod does the treadmill motor have plenty of torque at lower revs?
19/01/2020 22:00:50
Hi all
I find myself often having to cross drill or drill on a pcd on the lathe. I have been searching the forum and web for a good toolpost drill design.Up to now I have used a Dremmel type drill to fit on my Dickson tool post on my S7 but as everyone knows they run too fast and don’t have the torque required to do anything but a small hole. I have Steve Jordan’s ideas on YouTube but they seem unwieldy and top heavy. Has anyone pout there made a robust drill that can be speed adjustable and plenty of torque?
Chris
Thread: Raglan Miller manual & dial removal
01/09/2019 11:10:52
Thanks Phil
Email sent
31/08/2019 16:44:59
I did give quite a pull, no movement , I noticed the woodruff slot goes through the the black disk as well.
Maybe a little more brute force!
31/08/2019 15:53:47
Hi All
Just bough a Raglan Miller. Its in a reasonable condition for its age.
Does anyone have a manual showing the exploded assembly, I need to take off the dials to clean and adjust, I have taken off the handles and then presented with a black disk with no discerning way of removing it to get to the dial. See pics
Any help very much appreciated!
Chris
Thread: Conversion bracket
04/02/2019 18:54:33
Yup makes perfect sense 👍 thanks
I like the look of your tool post drill, did you make it
Can you show a better pic of it?
04/02/2019 15:52:27
Thanks John
Have you strengthened the base ?
Was that your own design jack?
03/02/2019 13:09:08
John,
How did you get on mounting the mill?
Looks like I am going to buy a super 7 and a Vma mill and will need to attach them as you needed to.
Any pics or help gratefully received !
Chris
Thread: New member with a question
20/01/2019 14:11:35
Thanks all for your comments ,
I have a few of the books mentioned and have been watching a lot of you tube videos as well. When i did my apprenticeship at Marconi's I spent a year in the machine shop---probably forgotten more than I learnt.
I am desperately trying to make room in my shed for the equipment I need, Which is proving a battle with all the other crap I have accumulated!
Edited By Chris Thorn on 20/01/2019 14:11:50
17/01/2019 14:26:14
Thanks everyone.
I am based in Rayleigh Essex.
anyone local to me?
16/01/2019 21:03:59
Hello all
I have been lurking reading the forums for a while.
I hope to be setting up a small workshop soon mainly for small static steam engines..
Does anyone have a link to a website that could give me a basic list of kit to get going. I intend to get a small sc4 type lathe and maybe a mill.
But it’s all the bits and pieces that I need. I need a basic list to get me going that I can build on over time
All help appreciated
Regards Chris
