Here is a list of all the postings Michael Kilpatrick 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Emcomat 7 Hight of topslide to lathe centre line |
01/09/2023 09:13:20 |
Hi Guys several years ago i purchsed a quick change toolpost and had to lower the hight of the topslide to make it fit. I have now purchased a Multifix toolpost and would like to return the topslide back to its original hight and fit the original 4 tool body. I will only be using this setup for screw cutting and the odd taper, the multifix will be used for any other turning operation and will have a purpose made base to suit. If there is anyone out there that owns an Emcomat 7 could you be so kind as to measure the hight from the top face of the topslide(ie toolpost removed) to the lathe centre line so i can make an appropriate spacer. Thanks in anticipation Mike |
