Here is a list of all the postings Tom Read has made in our forums. Click on a thread name to jump to the thread.
Thread: Lathe upgrade HELP - M300 |
17/11/2021 08:56:54 |
Posted by Chris Evans 6 on 17/11/2021 08:44:07:
I run my 3HP 14"x40" lathe from a Transwave static box. The motor does not have star/delta windings and I do not know how to find the star point to enable use of a VFD. The only downside I find with the Transwave box is lack of soft start and starting the lathe is a bit fierce at times, if ever it sounds unhappy turning off and restarting usually works. If the motor ever fails I would look at a motor and VFD package and sell the static inverter (converter ?) but until then I am happy to use the Transwave. Does your run at every rpm setting this one doesn’t it works fine at 540rpm and below but above that it cuts in and out as if there isn’t enough power |
17/11/2021 07:44:54 |
you may be able to view the advert for the lathe I think the transwave box is a box of capacitors
17/11/2021 07:14:48 |
Hi thank you for your help ! Could some please link me to a suitable VFD? many thanks again Tom |
16/11/2021 20:10:28 |
Looking to upgrade my myford ml7 for a Harrison M300 three phase that comes with a trans wave converter to single phase the only thing that concerns me is that it won’t run any speed above 540 rpm ? It does spin but cuts in and out? Is this because of the single phase converter and it possibly not being man enough? many thanks tom |
Thread: Myford ml7 tools size |
12/11/2018 18:17:10 |
Hi, thanks for all the replys its just a manual four way tool post i assume its the one that original comes on them ? Im a mechanic by trade so have grinders and all sorts. I think i will order a 8mm carbide bit on to try for the just for the cost of 20? and will try to sharpen the ones i have and take them down to meet the center height |
10/11/2018 17:27:12 |
Hi i have recently brought my first lathe a myford ml7, i have a brought a set of hss 10mm bits but they sit to high, so i guess i need 8mm and shim them up ? Also what is better hss or carbide insert bids |
