Here is a list of all the postings Simon Ravenscroft has made in our forums. Click on a thread name to jump to the thread.
Thread: Clarke CL500M |
10/11/2020 18:09:49 |
Posted by john halfpenny on 10/11/2020 13:24:39:
Don't apologise; the lathe can produce good work. The three jaw should have an external jaw set, which can be seen in the MM catalogue. These will hold 100mm with all of the jaws within the chuck circumference, so plenty of capacity for you ( and much more if the jaws protrude) I have to say a big thank you, your right it does come with a spare outside set, I should have looked in the box That's my problem solved Thanks John |
10/11/2020 13:44:55 |
I have to admit I bought the late second hand and it came with some other items though I have not checked, there may well be some but I doubt it I'm sure I would have noticed/remembered |
10/11/2020 11:26:47 |
I Have now, they said they have some outside jaws for £77.72 but he could not tell me what size they were or any other information, a lot of money to spend on something that may be the right one Thanks for the suggestions |
10/11/2020 09:04:31 |
Hi I am looking for a little help please, I have a Clarke CL500M and I know its a "toy" compared to the real machines out there I can only dream of owning but as I only use it to make small hobby Nixie clock parts it works for me. |
Thread: Help with Clarke CL500M Milling Aluminium |
07/11/2018 12:56:40 |
This was my last Nixie build it looks much better in real life, the nixie tubes are just timeless and getting hard to get now, the new old stocks are running out and apart from one guy in the Czech republic Dalibor Farny who makes the huge R|Z568M tubes that I will be using in my new clock though they aren't cheap at $145 per tube and I need 6 plus the colons |
07/11/2018 10:00:47 |
Posted by Ron Laden on 07/11/2018 09:08:38:
Simon, all of my current build to date has been machining aluminium, I,m a beginner and I started out with the (gold colour) TiN coated 4 flute HSS cutters. That was a mistake on my part as they are not best suited to aluminium, they will cut ok but I found only if they were lubricated and only light cuts. Jason suggested I consider one of the ARC Premium 2 flute uncoated Carbide end mills which are intended for aluminium. Well I got myself a 10mm one and have found it to be excellent, a superb cutting tool, not that cheap but I think worth every penny. Arc also do pretty much the same in 2 flute uncoated HSS but for some reason only in long series. I dont know what you are considering if buying any cutters but just thought I would mention it. Ron
Thanks for the advice, I have a couple of carbide 2 flute cutters for aluminium, there not branded or expensive so don't yet know if there any good but will give it a go this weekend with some WD40 and report back |
06/11/2018 14:00:05 |
Posted by Neil Wyatt on 06/11/2018 11:49:14:
Whatever you do, Simon, post a picture of the finished clock! (I have a soft spot for nixie clocks!) Will do though I expect it will take me any many months to complete |
06/11/2018 10:40:50 |
Thank you all for your advice I have listened to you all and will take a little from you all Keep it coming |
05/11/2018 21:30:25 |
Hi, I am 47 and started my working life in engineering working on capstones and lathes and then went on to sheet metal fabrication and welding till I was about 22 then ended up in sales which is what I do now. Edited By JasonB on 06/11/2018 07:54:33 |
