Here is a list of all the postings Tim Watkiss has made in our forums. Click on a thread name to jump to the thread.
Thread: Colchester bantam gearbox |
02/11/2018 21:55:30 |
we have a lathe and mill at work so I might have a go at making the part there on sunday if we are quiet, for me the tough bit would be milling the notches on each side exactly 90 degrees apart. |
01/11/2018 23:15:31 |
These are the pictures of the broken coupling and the gearbox, the broken coupling joins the two gears together on the right hand side of the middle shaft which will in turn drive the gear on the right hand side of the top shaft which will turn the leadscrew. I also need to get a part for the ABC change lever - there is a cam shaped part which you can see in the photo but it needs another part to actually mesh the gears on the left side of the top shaft. Thanks everyone for the manual and parts list info I have part numbers for the parts I need - just need to find them now!. |
31/10/2018 16:34:42 |
Hi this is my first post on the website so hello to everyone, I am looking for advice about my colchester bantam lathe it is a mk1 two speed machine and had an issue with the leadscrew not working when I bought it. Does anybody have a manual and parts list for this machine? I am in need of a small part for the screcutting gearbox but I don't know what it is called but it is a link which connects two gears together, its a bit like a washer with two teeth either side which are 180 degrees apart on each side and offset by 90 degrees with the ones on the other side - apart from this the gearbox is fine and I can fit it up if I get the part. Cheers Tim |
