Member postings for Chris Suddell
Here is a list of all the postings Chris Suddell has made in our forums. Click on a thread name to jump to the thread.
Thread: Rust Protection
26/01/2022 08:54:38
Hi,
An update on this one, I have been trying some different ways to keep the rust at bay. I also have the go ahead for another shed in the garden which will be insulated. The Lathe and Mill have been coated with ACF50, I had some in the garage from a few years ago so lets see how that goes.
Thanks for all the comments and suggestions.
25/10/2021 05:41:55
I think I'm done for because my Lathe and Mill are in a concrete garage with no insulation.
I'm going to clean them up again and apply some rust preventative and I'm going to have to keep on top of them every week. Unfortunately I only use them about every month. Most of my parts are 3d printed.
It looks like the long term solution is to get them out of the garage and into an insulated wooden shed.
Thanks for all the replies.
07/10/2021 13:40:54
Hi,
I'm having a bit of a nightmare keeping rust from forming on my Lathe and Mill both Warco.
I only use them once a month and every time I go back to them rust has formed.
I have used anti corrosion oil over winter and during this summer with a duvet covering them at night.
Apart from two vices all other steel items in my garage are rust free.
I'm a little miffed. Any help would be nice, I don't want them getting really rusty bad.
Thread: Some help needed with threads
20/05/2021 06:29:13
Thanks everyone!
smiley
19/05/2021 09:32:48
Posted by Andrew Johnston on 19/05/2021 09:18:35:
The threads need to be better specified as does the material being used. I'd guess that the 3/8" thread is UNF and the 5/8" thread is UNEF and the material is brass?
For 3/8" UNF I'd be drilling 8.70mm giving a thread depth of about 70%. For 5/8" UNEF the minor diameter is 0.5799", giving a thread depth of 0.0226". For 70% thread engagement I'd drill 15.1mm.
For external threads I prefer to screwcut in the lathe, but you are correct that the nominal OD of the threads is 3/8" and 5/8" respectively. Barstock is normally a thou or two undersize which helps the die to cut.
Andrew (G8IUV)`
Hi,
Thanks for this makes sense.
Chris
19/05/2021 09:31:47
Posted by Ady1 on 19/05/2021 09:28:34:
I would stick to metric if you don't have the original bits
Starting from scratch with imperial, not recommended
And stick to cheap stock parts
6mm 8mm 10mm 12mm
Unfortunately the American antenna people have not yet caught up with Metric!!!
19/05/2021 09:31:01
Hi All,
Ok the material is stainless steel and the threads I believe are
5/8-24 UNEF for the SO239 connectors
3/8-24 UNF (thats all I can find.) for the end of the antenna whips
Chris
19/05/2021 08:54:48
Morning,
I'm making some antenna parts (I'm a radio ham) and need the create some threads.
The issue I have is what size to drill the holes to tap for the following sizes;
3/8 - 24
5/8 - 24
Had a google and the best I come come up with is;
3/8 - hole 9mm
5/8 - hole 15mm
The threading on the outside of the parts I'm assuming I use 3/8 (9.52) and 5/8 (15.875mm) barstock respectively and run a die around it.
I hope this makes sense.
Thanks
Thread: Threading plastics
24/05/2019 15:04:06
Hi All,
Ah ha, seems like there may be a few hams here!
Anyway, it is a screwdriver antenna, not just a loading coil. So it needs to go on the ourside of a tube. Unfortunately the Q will only be 300-400 max, but it will do. I've 3d printed 3" and 4" inductors and wound them they work fine. This one needs some strength. I have done the microwave test on a few materials, not all went well.
Joe, I like your variable inductor, very nice.
Chris
M0VUE
24/05/2019 08:54:25
Hope this helps.Antenna
24/05/2019 08:49:18
Hi All,
The tube needs to be 2 foot long with a thread around 18 inches, 4 inches or 3 inches diameter. My lathe will do 3.75mm max thread. It's to build and inductor coil for an antenna. So there is RF going through the device, it would only get hot if the material reacts to RF.
Hope this helps?
Chris
24/05/2019 06:35:02
Hi,
I need to make a thread to set a copper wire around a plastic or GRP tube. My preferance is GRP.
Just wondered if anyone had any tips fo doing this? I have read GRP is nasty and my other option white drainage pipe will heat up.
Any advice will be appreciated.
Thread: Good morning
26/10/2018 06:55:23
Hi,
Just bought a lathe and milling machine, WARCO. I'm now looking forward to building some antennas using them. So I no doubt will have lots of questions.
Last time I used these types of tolls was before 1982!!!! So its going to be fun.
I wondered if anyone here mills or lathes with plastics. I'm trying to decide what to make my antenna coils out of (plastic tube with thread in it).
Also, are there any recommendation on aluminium and plastic suppliers? I'm in sussex.
Thanks
