Member postings for Derek Leggott
Here is a list of all the postings Derek Leggott has made in our forums. Click on a thread name to jump to the thread.
Thread: Speed Controller - Mini Lathe
07/09/2018 15:28:15
Thanks for all your input everyone. It's been very helpful.
07/09/2018 08:55:35
Hi Jason
There's a screw in the main body bottom left that it should be attached to via a nut. It hadn't been fixed and was just left floating around.
As a newbie to this is a Potentiometer the knob that adjusts the speed?
07/09/2018 07:08:57
img_0241.jpgHere are the photo's of the board.
06/09/2018 18:19:53
Thanks XD. I took the back of the lathe off to look at the board and there was an item that had blown. It could be a transistor. It has the words MIN below it and the one next to it has the words MAX below it. This one is sound. I also noticed that the earth strap that should have been connected to the lathe was just hanging loose!!
I've got in touch with supplier to get it sorted anyway. Thanks again.
06/09/2018 07:26:23
Hi all, I wonder if anybody has any ideas on this problem. I've just bought and received a new mini lather: MosaicAL 600w 7x12 2500rpm with variable speed.
Everything is absolutely fine apart from the issue i'm about to explain.
I switched the lathe on and it worked perfectly. I adjusted the variable speed control to speed it up and then reduce speed and it was great for about 20 seconds. The there was a pop like a fuse blowing and the lathe went to full speed. No matter what i did with the speed control knob it stayed at full power.
I have contacted the supplier but any ideas would be great.
Many thanks
