Member postings for David K
Here is a list of all the postings David K has made in our forums. Click on a thread name to jump to the thread.
Thread: 3 cyl Pip engine
28/12/2018 20:59:20
I moved the table up to the little end bearing and drilled, reamed 7mm ready to accept a 7mm bush.
Using an m6 mill I then started to form the shape of the rod p1030938 (medium).jpg
28/12/2018 20:57:57
The slave rod holes were then opened out to 6mm for half the depth of the rod. The big end bearing is screwed
into the rod by hand, I machined a slot and tightened with a screw driver then using an m6 end mill I relived the
28/12/2018 20:56:51
So I mounted a piece of alloy on the mill centred over the big end , I used a scrap piece of alloy underneath
to save damaging my rotary table.
I centre drilled ,drilled and tapped m10 fine through for the big end bearing then moved the table and
drilled , tapped m4 the holes for the slave rod pins.
28/12/2018 20:56:01
Then I started the con rod, this is made from 6061t alloy which has a greater mechanical strength than
the 6080 I have used for the crankcase.
28/12/2018 20:54:55
I made the big end bearing from phosphor bronze, the bearing is threaded into
28/12/2018 20:53:53
28/12/2018 20:53:21
28/12/2018 20:51:19
28/12/2018 20:50:05
The piece is then heat treated to harden the silver steel p1030832 (medium).jpg
28/12/2018 20:49:13
Next job was to mill the sides away to form the inlet lobes , only milling down to the grove used to
separate the lobes. Then the piece was flipped over and the exhaust lobes were milled in the same way. p1030822 (medium).jpg
28/12/2018 20:43:58
With the piece mounted on the mill I drilled and reamed the two holes which the planet gears
will run in. These holes were drilled through into the mounting block so I could fit two
pegs in to help locate the piece.
28/12/2018 20:43:22
The centre is then drilled and reamed ready to accept a bronze bush. Using a
parting blade I made a thin groove which is used to separate the inlet lobe
28/12/2018 20:42:31
Camshaft, the camshaft is made from 1.25'' silver steel round bar.
First I turned a piece down to size and then turned a small shoulder on the front.
28/12/2018 20:39:34
28/12/2018 20:38:23
28/12/2018 20:37:35
The crank needs extra weight to balance the engine so I turned and milled a counterweight
22/12/2018 14:53:45
With the gear cut I used a milling cutter to form the crank web p1030696 (medium).jpg
22/12/2018 14:52:44
Back on the mill table I need to cut a 20t 48dp gear on the crank to drive the planet gears
I made earlier. I could not use the gear cutter I used on the planet gears as the gear is cut
close to the crank web and needed to be a smaller diameter cutter. So I made cutter from
silver steel , there is plenty of info about making gear cutters on the internet so I won't describe
22/12/2018 14:51:28
Then more material is removed to form the basic shape
As I get down to the final sizes lighter and lighter cuts are used to try and get a nice finish.p1030689 (medium).jpg
22/12/2018 14:48:13
Now I have the centres I mounted the bar first between the mains and then the crankpin to remove
