Member postings for Brian Davies 6
Here is a list of all the postings Brian Davies 6 has made in our forums. Click on a thread name to jump to the thread.
Thread: Clarke CL430 Metal Lathe
22/07/2018 08:49:42
Hello there , many thanks for all suggestions you really are a friendly helpful gang , I have tried every thing and everything is fine so there is no reason why the auto feed should not work but it doesn’t ,so I will either have to find a service engineer which is proving difficult or just feed manually but as we all know this method leaves a untidy finish ,just a thought tho while I am here ,if I remove the guard that protects the drive travel bar from swathe there is a block that seems to go to the tool head is there any thing inside that block that could have sheared if not I’m stumped of what it could be
Thanks again guys
Thread: New member
21/07/2018 19:57:21
Hi ,no not to far away at all , I have have a large garage that kitted out for basic joinery that’s where my metal lathe is which I’m have problems with at the moment and general pottering about in there ,my recluse as the wife calls it ,then in workshop 2 that’s where my wood turning lathe is with all the stuff I need like band saw sanders planners thicknesser and of course dust extraction most important
21/07/2018 18:25:44
Hi Jason , yes I have done as you say , I forgot to say in post that I have had this lathe quite a long time and it’s been working perfectly it’s just stopped working as it should today
Brian
21/07/2018 16:56:18
Hi , my lathe which is a
Clarke CL430 Metal Lathe has a problem ,when I turn on the auto feed the thread bar turns fast and slow so I know the the switches are working ok all the belts and cogs turn all is working behind the cog/belt door but the cutting head will not auto run ,if I turn the auto off I am able to move the cutting head manually ,I can not find any one to repair it has any one got any info that will help me ,thank you Brian from West Yorkshire
Thread: New member
21/07/2018 16:47:25
hi ,the name is Brian , my interest are metal and wood turning photography and archery ,I have 2 hobby workshops which are decently kitted out , I live in West Yorkshire ,and I have a problem with one of my lathes which I will post later
Thanks Brian
