Here is a list of all the postings c wastell has made in our forums. Click on a thread name to jump to the thread.
Thread: stainless steel valves in cast iron guide |
18/02/2023 09:18:50 |
Thats very interesting, thanks. I didn't know I could make them myself, I have a little bit of EN24T in stock. I don't mind buying them but I do object to the Euro22 postage plus the delay at customs. |
18/02/2023 08:08:29 |
Communicating with the Italian suppliers is a process best described as slightly wearing. They are friendly and helpful but oh, so Italian; I might get an email out of the blue in 10 days time, with the answer. |
18/02/2023 07:41:11 |
Posted by Hopper on 18/02/2023 07:27:37:
At the price (not the postage!!) and at the news of the stellite pad coming off the end of the stem, even under severe hammering, I would have to wonder about the quality of the valve. Good quality Harley valves run about $50 each and Norton valves can be as much as almost $200 each for the super magic ones. But I suppose you don't get much choice with ancient Guzzi parts. I have seen a few hung up valves on Harleys and Brit bikes but have never seen a pad come off the tip of the stem. But not sure they even have such a thing. I don't suppose you have an alternative supplier ? Yes surprising your machine shop would make it so tight on such an old machine. If they opened it up to 3 thou after the first seizure it must have been 2 or 2 somehting to start with. Did you find what the original Guzzi clearance specs were? It is a sacrificial 'pad', a separate item that literally just sits on the valve stem. The only thing preventing it falling off is the rocker
Edited By Hopper on 18/02/2023 07:30:34
18/02/2023 05:59:22 |
Hopper, What surprises me is that this company work mainly on "old" stuff back to the dawn of motoring so I'm disappointed to say the least, that they didn't take the attitude of "looser the better." The valve has a little pad on the end to take hanmmering from the rocker. Each time it sticks open, that pad is lost somewhere on the road. They have to come from Italy at euro5.73 but plus euro22 for post. Its like rubbing salt in the wound🥴 |
17/02/2023 21:09:20 |
I'll see if some extra clearance solves it first. If it doesn't then yes, I'll have to shell out for a one off valve. Thing is, other people are buying these valves presumably and I've never heard of anyone having problems with them. |
17/02/2023 20:20:53 |
Thank you so much for all the replies, some good information there which is much appreciated. The Company concerned is South Cerney Engineering near `Swindon. They have an excellent reputation, working on the highest quality and rare vehicles so I took them at their word. I'm sure the chap doing the job said he'd opened the guide up to give .003". I've since found a Moto Guzzi chart from the period which recommends nearly .008" at max tolerance! So that's the first thing. Is there a way to tell if a valve stem is chrome plated? or is it obvious? Incidentally, the inlet guide has an oil drilling for valve lubricant but the exhaust has to just get on with it. Thanks again for the knowledgeable and informative replies. |
16/02/2023 20:13:37 |
I'm not sure if this is the best thread to ask but my problem is actually on a 1930s Moto Guzzi engine with exposed valves. I had new guides and valves professionally fitted in a cast iron cylinder head. Expert advice is that a stainless valve will 'pick up' in an iron guide so they fitted phosphor bronze guides. The exhaust valve stuck after 2 miles. The guide was reamed out to give more slack. this time it lasted 20 miles then stuck. Originally this engine had iron guides as they are self lubricating which the bronze ones are not. Any advice please? Thanks. |
Thread: fixing loose valve guide |
30/05/2022 21:17:53 |
I had to order a new valve for Italy so at the same time ordered a replacement o/s valve guide. The supplier is a specialist only in these old Guzzis so I will be interested to see if the new guide is bronze or iron. |
28/05/2022 20:11:50 |
Thanks for all your knowledgeable replies, gents. You have convinced me to forget about a quick fix and go for the over-size guide. Unfortunately, all the spares have to come from Italy which complicates and slows down things down somewhat. I have a good engineering company, Cerney Engineering near Swindon, I would not attempt this myself. |
27/05/2022 05:36:02 |
I'm a pretty amateurish engineer (O level B) but a lot of what Triumph produced was way below standard. On the other hand, I reckon pre-war Guzzi engineering was very high quality and if Carlo thought bronze was best, that's good enough for me🙂 |
27/05/2022 05:06:54 |
Sorry, I should have been more specific. Its a 500cc single cylinder motorbike. (1935 Moto Guzzi). |
26/05/2022 21:20:55 |
Unfortunately it is the exhaust. Do you mean knurl it then shrink fit?
26/05/2022 21:05:04 |
Thanks for that, Michael. A few different opinions there. I appreciate the help👍 |
26/05/2022 20:36:02 |
I have a cast iron head with a loose (sliding fit) bronze valve guide. Is the a way that it can be held in place? Is there a loctite product for instance? I don't want to go down the oversize guide route as I fear that will be opening up a whole can of worms |
Thread: Classified For Sale |
23/09/2020 14:18:39 |
Not sure if this is the right place to ask but I have a wanted ad in the classifieds. I am now sorted but cannot see how to remove the ad. Any help please? Thanks |
Thread: Myford super7 motor U/S |
16/09/2020 07:12:48 |
Thats all good gen. Many thanks. None of the motors shown is exactly like mine (which is matching grey! and looks original) but the diagrams make some sense to me. However I suddenly have a more pressing problem in that the resilient mounts have given up the ghost completely. I found a thread on here from 2013 but wonder if, since then, there is a supplier of these? How important is it that the motor has this flex? |
13/09/2020 06:28:00 |
Thanks for that further information, chaps. I wonder if I have got all the connections right, in that case. I don't have wiring diagram.
Steve, Screw cutting is the reason for wanting reverse but its not the end of the world. |
12/09/2020 20:30:33 |
I removed all the wires and a couple of posts were a little bit corroded. There is a sort of sprung pressed metal affair with a contact which locked quite dirty. I cleaned up everything I could find and lubed the armature (?) spindle at each end. Its all back together now and runs forwards but not in reverse. I have looked at the Dewhurst switch and it looks clean. At least It is useable. Thanks again for the advice. |
10/09/2020 21:08:29 |
Ah. I just put a meter point on each wire with the meter set to ohms.
10/09/2020 18:45:22 |
having trouble uploading image but I have con tested the capacitor and it is open circuit. |
