Here is a list of all the postings GingerLathe has made in our forums. Click on a thread name to jump to the thread.
Thread: Murad cadet lathe |
27/04/2021 13:08:12 |
I've got a Murad Antarctica Beta and I couldn't find anything with the same spindle size of 1" 3/8 10TPI Whitworth. Like you I had to make one myself. |
Thread: Parting off 25mm copper |
26/04/2021 10:36:46 |
Posted by noel shelley on 26/04/2021 09:50:22:
WHY not use a tube cutter ? What wall thickness is being used ? Noel. It's a 25mm solid copper bar which I'm beginning to regret choosing... |
26/04/2021 08:01:19 |
Many thanks for everyone's reply. I'll try everyone's suggestions later today although I feel the hacksaw will be making an appearance... |
25/04/2021 19:42:50 |
To be fair, I'm not sure what grade of copper this is so it might be my own doing! Ebay special... |
25/04/2021 18:31:00 |
For the first time I have a need to do some work with 25mm copper. I've come to the parting off stage and I can't get my lathe to part off without the typical screaming and chatter you read so much about. The setup I use works will all other materials to a reasonable degree. From what I can google, copper can be a bitch to work with. I'm using a HSS Parting Off Blade 3/32"x1/2"x4.1/2" and even with the parting off point 1cm from the chuck with minimal blade overhang it refuses to part. My lathe cannot accommodate a rear tool post and I don't have a tool bit holder to mount a blade upside down from the front. From what I have read this may be about having the correct tool geometry. I've tried a number of options with my current failure having a 5° front clearance with a 20° back rake. Any suggestions would be most welcome. |
Thread: One place for all ??? |
11/02/2021 20:00:30 |
Posted by Me. on 11/02/2021 16:00:02:
or as it seems many places for the things I need...... What am I on about - well basically trying to get all the bits and pieces I need together to get myself set up. My machines came with some tooling, some of it quite nice and usable but a lot "tired and used". I put a small shopping list together to get the bits I needed but unfortunalty all the tool suppliers I have been using never have all the things I need. Ive tried 3 of what you might call "the big boys" (mostly initials and a Greek sounding time keeper). Unfortunately they don't have all the bits i need in one place and hunting around each site to pick up the things is costing me a fortune in postage. I have a budget to spend each month on picking up the items but every time I think i'm getting somewhere with the items I get knocked back by "not listed" or "not stocked here". Is there a one stop shop or is that too much to ask.
Not sure exactly what you are looking for. I've used arceurotrade a number of times with good results. RDG Tools have a wide selection with average quality for the most part, |
Thread: FreeCAD 3D design for a HSS tool bit |
09/02/2021 15:48:56 |
Posted by SillyOldDuffer on 09/02/2021 14:06:15:
Posted by GingerLathe on 09/02/2021 12:33:39:
Posted by SillyOldDuffer on 09/02/2021 12:04:08:..
Many thanks Dave. I'll have a go at this approach. Would you be able to send me the FreeCAD file if I PM you my email address? Thanks Spencer No problem at all. Here is it on Dropbox, otherwise PM me and I'll email it. Dave The willingness to help others never ceases to amaze me on this form. Many thanks Dave. This exactly what I need. Really appreciate your time.
Spencer |
09/02/2021 12:33:39 |
GingerLathe's object is trickier than most to 3D model because it has a number of faces that aren't at right angles to each other. As most models are developed at right angles, FreeCAD (and other software) defaults to this, and it's necessary for the modeller to adapt. Jason mentions Alibre's extrude tool can be told to cut at a draft angle, but FreeCAD's equivalent doesn't support that convenience. Instead it's necessary to define planes and cut from them. ... The button used to create planes in circled in red. Planes can be rotated (Yaw, Pitch, and Roll) and Moved in X,Y and Z. Modelling the tool needs 3 planes, none of which are at a right angle to the tool blank or to each other. Bit fiddly to set up, but gets easier with practice. Hope that helps. Dave
Edited By SillyOldDuffer on 09/02/2021 12:05:52 Many thanks Dave. I'll have a go at this approach. Would you be able to send me the FreeCAD file if I PM you my email address? Thanks Spencer |
09/02/2021 09:18:23 |
Posted by Bazyle on 09/02/2021 09:13:05:
What exactly did you envisage? A picture of a freecad drawn part? An stl or step file (which can't be posted on here)? a video of it being done? You video suggest would be the best so I can see how the design is created using FreeCAD. If not, a FreeCAD doc of a tool bit I can look at to see how the surfaces are created. |
09/02/2021 08:13:08 |
Posted by Thor on 09/02/2021 04:24:44:
Dave, one of the moderators, had a "Making a Start in FreeCAD" thread, I assume you have read that. The thread doesn't use a tool-bit as example but may give you some ideas. There are a few examples in Steves-Workshop. Thor I had previously read that thread and it get me a little further. I guess I need to plough on! |
08/02/2021 22:05:28 |
All, I'm trying to learn FreeCAD. After getting to grips with the basics, I wanted to create a HSS right hand turning bit. I can't find any good examples to learn from and I'm struggling to create the multi angle surfaces. Does anyone have an FreeCAD of an HSS tool bit I can learn from? Many thanks. |
Thread: HSS Tool Geometry |
27/01/2021 08:29:10 |
Howard - thanks for your comments. There is certainly no replacement for a life's time of experience. Thanks. |
26/01/2021 19:43:35 |
Everyone - many thanks for your feedback and help. Very much appreciated. Lots for me to go away and look at.
Thanks again. |
26/01/2021 16:47:02 |
Posted by Emgee on 26/01/2021 16:44:27:
That RH finishing tool looks like what I thought was my LH finishing tool, depends on how it's ground I suppose. Emgee would you say the finishing tool provides a superior finish over the roughing tool geometry as the name suggests? Do you know the angles? |
26/01/2021 16:24:13 |
These forums and a google will yield results on suggest tool geometry for HSS lathe tools. However I'm trying to determine the validity of a "Roughing" tool vs a "Finishing" tool. The names are self explanatory but can any one offer an opinion on the use of a finishing tool? Will such geometry make a big difference? Does anyone have angles for such geometry? I've attached an example diagram for reference.
Thread: Selecting an Engineer's level |
16/04/2020 17:55:21 |
Posted by JasonB on 16/04/2020 17:33:43:
The wear on an 80year old lathe could well throw the readings off anyway, 5microns of wear on one of the ways would be equal to 0.05/m if they are 10mm apart. Is the lathe not cutting true? if it's OK then save your money. It isn't cutting true although i haven't measured yet but I can see it isn't. |
16/04/2020 17:54:43 |
Thanks for all of your thoughts. Much appreciated! Looks like I need to reconsider my approach leveling given the cost and alternative approaches. |
16/04/2020 16:07:46 |
All, I've decided to level my lathe and although there are various methods to achieve this, I'm going to employ the use of an Engineer's level in this process. Now you can pay crazy money depending how accurate you want to go. A google offers up a number of options and I'd like to solicit people's thoughts on them: 1 - Moore and Wright ELS range (165mm - 0.3mm/m) ~£150 2 - Level developments 61R-0.05-140 (140mm - 0.05mm/m) £205 3 - RDG tools brand (150mm - 0.05mm/m) £58 Now what I find strange is the cost of #1 with an accuracy of only 0.3mm/m. Seems a high price for such an accuracy. Then we have the polar opposite for #3 which is very cheap for a reasonable high accuracy. Does anyone have any thoughts / advice? Do I need something more accurate than #1 for leveling my lathe (Murad Lathe) Thanks in advance |
Thread: Chuck back plate material |
24/02/2020 13:43:54 |
Thanks everyone for your help. Much appreciated! |
24/02/2020 13:43:27 |
Posted by SillyOldDuffer on 24/02/2020 12:06:48:
... Interesting machine - nothing to do with the question, but can you share some photos? Dave Hey Dave, One as the lathe is now (little cleaning and a replacement tool holder) and some others when I picked it up. At some point the power switch must have broke and was replaced. It also has the badge of the shop in London which originally sold it (Buck & Ryan) which I managed to google some pictures of. The best place for historical information I've found for any lathe is lathes.co.uk - Link to this lathe on that site: **LINK** Thanks for the interest! |
