Member postings for matt_ml7
Here is a list of all the postings matt_ml7 has made in our forums. Click on a thread name to jump to the thread.
Thread: Polisher - under-bench motor - any plans?
10/02/2018 20:37:00
I have rediscovered in a box what I assume was a car boot purchase some years back. I've found one image online of the same - a grinding and polishing head by J. F. Turner. Spindle is 1/2", 6" from base.
https://www.gracesguide.co.uk/J._F._Turner
I've given it an initial clean up, removed rust from the pigtail and filed its threads smooth again.
I have a few old single phase motors available - a 1/2 and a couple at 3/4 HP, though yet to find any of the pulley wheels that came off them. I'm considering 6" or 4.5" wheels.
I wonder if anyone reading this has mounted similar or knows where I might find any examples or plans. Appreciate a simple motor mount is not particularly difficult to construct, but nice to see others. Any suggestions re: motor, wheel diameter and spindle speed would also be appreciated.
Edit: rather than necessarily being bench-mounted, I'm also considering a wall-mounted unit to keep the floor clear.
Edited By matt_ml7 on 10/02/2018 20:42:28
Thread: ML7 motor - Tyco Crompton - wiring/burnt out?
07/02/2018 14:11:37
Posted by Emgee on 07/02/2018 13:51:31:
Matt, it would be a good idea to make sure the new sounding rub is not any part rubbing on a wire, just in case.
Emgee
Edited By Emgee on 07/02/2018 14:02:02
Thanks for the nudge, good point.
No, wires are all held clear of moving parts, I can poke a finger in to depress and release the plate and then twiddle the spindle a few degrees back and forward. I think I'm comfortable with it.
07/02/2018 13:06:40
Posted by Emgee on 07/02/2018 11:40:05:
Matt, squeaky sound is common with the switch arrangement.
Emgee
Thanks, Emgee.
Reassembled, motor starts and runs fine. Confirm there is a dry-sounding rub when the centrifugal switch closes again before stopping, but sounds like a clean running motor.
Thanks for the comments, all.
Matt.
07/02/2018 11:05:19
Start winding measures 9.2 ohm's, switch checks out ok too. Bearings feel very smooth.
I can only really clean the contacts, tidy it up and reassemble.
If it was a break and I've shorted it by moving something, I doubt the resistance would read so well...? Also, it sounded dry/squeaky - I don't believe it's the bearings given how they feel, perhaps the centrifugal plate against the pad of the switch? I could put a drop of silicone spray on it or something.
06/02/2018 22:13:54
Posted by John Olsen on 06/02/2018 21:51:18:
If I had to replace one of those I would look at putting on a 3 phase motor and a VFD. I'm not sure how the prices would compare...a 3phase motor should be cheaper for the same power, but then you have to pay for the VFD. But overall you end up with a better job. I have the Newton Tesla setup on my ML7, but you can do it cheaper than that if you try.
Thanks, John.
Yeah, that would be nice. I did look into it for my wood lathe a few years ago but never got round to it. Money's tight and I was gifted the lathe, so short term I'm hoping to use one of the single phase motors I've got.
Edited By matt_ml7 on 06/02/2018 22:17:30
06/02/2018 21:27:14
Posted by Speedy Builder5 on 06/02/2018 21:21:33:
I think a lot of ML7 users have the 1/2 Hp motor in preference to the smaller 1/3Hp. This may be the time to upgrade ?
It's a half that was on it. Is there a disadvantage to 3/4 - too much motor? I'm not sure exactly what I've got to replace it - have to have a look...
06/02/2018 20:37:42
Posted by Pete Rimmer on 06/02/2018 20:34:36:
Could be that old favourite - swarf in the gubbins. Worth pulling the end bell off just to check for that. My first lathe gave a little lightning show because I didn't at the time realise the importance of keeping the swarf out of the vents.
As I have to remove the motor to install another, I will certainly open it up and take a look.
Thanks, as I expected to be fair but wouldn't it be nice to find something yet...
06/02/2018 20:26:56
Posted by Emgee on 06/02/2018 20:16:47:
Mat, you have confirmed either the start winding is burnt out or the centrifugal switch is not closing.
Remove the end plate to check the connections on the centrifugal switch, you may need to remove the connection plate or other cables first.
Emgee
Thanks, Emgee/Neil.
I am told the motor may have been a replacement at some point. Without further disassembly, there is a spring switch along the inner edge of the connection board, in very good condition - the fixed end tests ok to S (yellow). Testing conductivity between there and the spring arm using pressure on the probe to open and close, it looks like it tests ok. It's closed at rest, and very clean looking.
So unless there is more than one electrically significant moving part, it must be the winding that's gone.
06/02/2018 20:05:29
Hi,
I have a lathe with an electrical issue that I'm trying to diagnose. It's a Crompton 370W single phase motor. The owner's son in law told me there was water ingress at the sockets on the wall and last time the lathe was used there had been a pop/flash - I don't know where it was.
Initial checks:
  • spindle turns freely - sounds a bit dry.
  • plug fuse (5A) - ok.
  • connectivity from plug to switch housing - ok
  • switch housing - some damp internally, dried out
  • overload cutout was tripped, now reset - ok
  • locking mushroom Isolator, one terminal badly corroded, return spring fallen out - now repaired - ok
I tried powering it up, the motor hummed for a second or two then blew the 5A fuse. I replaced the fuse, tried again spinning the motor shaft by hand just before powering - same, hummed for a second or two then blew the 5A fuse. In hindsight, I might have performed the checks below before powering it up.
I unplugged and removed the cover plate on the back and noted the wiring:
  • motor BLUE --- Z2 --- supply NEUTRAL
  • motor YELLOW --- S
  • motor BLACK --- U2
  • motor RED --- U1 --- supply LIVE
Additionally:
  • link wire U1 --- S
  • link wire U2 --- Z2
The label on the inside of the cover plate:
  • BLUE --- Z2 --- START
  • YELLOW --- S --- START
  • BLACK --- U2 --- RUN
  • RED --- U1 --- RUN
So I assume U1/U2 is the primary winding, S/Z2 the start winding. There are no capacitors.
I removed the supply LIVE and NEUTRAL wires and both link wires.
  • U1/U2 measures approximately 5 Ohms.
  • S/Z2 measures as an open circuit.
My limited knowledge suggests the wiring is correct and either the start winding has burned out, or the centrifugal switch is in a failure state.
Can anyone help? Do I disassemble to inspect the switch and measure start winding resistance beyond it?
(I overhauled a similar motor a number of years ago and have a couple more sitting, so subject to shaft diameter for the pulley wheel, I may have a spare.)
Thread: ML7 restoration project
05/02/2018 21:13:55
Posted by Pete Rimmer on 05/02/2018 19:12:24:
Well done Matt, you got that for a great price
Since you are a raw novice to machines and machine work it might be worth mentioning your location. You never know, you might have a seasoned machinist/forum member right on your doorstep who would be willing to cast their eye over your machine and offer up some sage advice in person.
Thanks, Pete.
Thread: ML7 part query - what is this?
05/02/2018 20:45:00
Posted by Andrew Tinsley on 05/02/2018 18:47:54:
It is the mounting bracket for a Dewhurst Forward / OFF / Reverse switch.
Andrew.
Ah, thanks Andrew.
05/02/2018 18:00:06
The item below was attached to the lathe bed casting, just to the right of the left-hand lead screw mount - it carried the switch box, I assume installed by the previous owner.
The part itself cannot be seen in the next picture, but here's the install location:
I don't know if he drilled and tapped the holes in the base himself, or if this is simply how the gearbox usually mounts. I've been unable to find any images online that answer this.
Can anyone help?
05/02/2018 13:53:51
Posted by Richard S2 on 05/02/2018 13:21:20:
Welcome Matt. To be given it is surely a major advantage. to be gifted a machine that is worth cleaning up and in reasonable condition under the dirt 'n' surface rust with all those accessories is a real bonus.
I had to pay for mine (1949 ML7) years ago and it had been heavily abused (Saw cuts in the Ways). Took a lot of work to get back into a reasonably useable condition, but enjoyed the challenge and learning curve with no prior experience.
Clean it and use it before seeing what else it needs. But most of all enjoy it!.
Well said - they said it was well looked after. Unknown how long he had - it may have been obtained when his employer closed, or not. I am very fortunate to have received this.
There are no broken teeth - the topslide micrometer dial is bent so it will need to be flattened - I'll clean up the bed and cross/topslide ways. The counter shaft is dry, main spindle is not awful, leadscrew is beautifully smooth.
Nevertheless a good list of things to do before powering. Electrics known to be faulty due to water ingress at the sockets.
05/02/2018 13:47:08
Posted by Hopper on 05/02/2018 12:11:16:
It appears to not have been badly abused, just showing signs of aging paintwork and a bit of surface rust from sitting unused. Given your lack of experience, you might be best to do a minimal tidy up -- basically clean it and lubricate it with minimal dismantling -- rather than a full restoration. Get to know the machine and use it a bit while its in its natural state, and develop your skills as you go.
A fair point. It was used a lot to turn wood, so there's a lot of oily sawdust both on the surface and in the cavities. Most of that should clean off readily.
Earlier, I realised I could do with it running to make a tool to press the Jacob's chucks apart.
05/02/2018 13:23:31
Posted by Neil Wyatt on 05/02/2018 12:10:56:
Things worth looking up (use the google search box half way down the home page) are:
  • How to get a stuck chuck off without breaking anything.
  • How to clean out the lubricators and what oil to use.
  • How to adjust the spindle bearings.
  • How to 'level' the lathe for maximum accuracy.
Plenty to get stuck into and a machine worthy of the attention.
Cheers, Neil.
4-jaw came off with hand-pressure on the belts and a spanner to a large hex nut in the jaws.
05/02/2018 11:57:40
Posted by roy entwistle on 05/02/2018 11:36:55:
Matt Just a word of warning Don't leave the chuck key in the chuck ( As per first photo )
Roy smiley
It stands out like a sore thumb, doesn't it - embarrassed I even took the photo like that.
05/02/2018 10:43:11
Thanks, Don. Great stuff!
Useful lubrication and inspection charts in the Yahoo group, as well as the scan of the manual.
I've contacted the previous owner in case we have missed any small parts. It would be a shame for anything to be separated at this stage.
05/02/2018 09:15:11
Thanks, Neil/David!
Thanks, John. I've got two books to hand - The "M.E." Lathe Manual by Westbury (1951) and How to run a lathe by O'Brian (1942/2013), neither specific to the ML7 though.
Posted by J Hancock on 05/02/2018 08:55:37:
Most of all remember, "if it ain't broke, don't fix it'.
Yes. It's hard to imagine anything but a full tear-down at which point everything gets cleaned and re-protected. I'll put your comment up on the wall.
04/02/2018 23:20:04
Hi, all.
I collected a Myford ML7 today along with a number of accessories. Serial number suggests 1952-53. I've been recommended this forum as somewhere I might seek help if needed.
I've never used a metal lathe before, though I've spent many (many) hours watching videos of both casting and machining. I made a conscious decision a few years ago not to go looking for one, but this week one came to me. The gentleman owner passed away last year and on a mutual friend's recommendation, his daughter has very generously gifted it to me.
I own a few older machines already - a Pacera drill press I use regularly, a Milford wood lathe a Wilkinson cabinet saw both currently in storage. It's mainly wood I've worked with - just a hobby but relatively well equipped. The unexpected additional of the metalworking lathe to the workshop is wonderful.
Due to its current condition, it'll be a while before it's ready to run, but restoration is half the fun!
Any pointers towards particularly helpful resources would be appreciated.
Best wishes,
Matt.
