Member postings for mtrehy mtrehy
Here is a list of all the postings mtrehy mtrehy has made in our forums. Click on a thread name to jump to the thread.
Thread: Colchester Bantam MK1 - Old, but New to me.
21/01/2018 16:52:00
Thanks all.
i spent more time with today and made some progress.
Feeds are now working thanks to wd40 and some wiggling.
I removed the lower gearbox cover - there is damage to teeth on some of the gears. This will account for some noise. I don't know how worried to be about this - I've not looked inside the screwcutting gearbox on a lathe before but assume that some damage is not uncommon, particularly on hobby / training type machines. I put it back together and it's certainly quieter with fresh oil in.
One stupid question - do the micrometer scales on the handwheels move independently of the wheel on this model machine - mine don't but could well be rusted together presently???
The lathe has had the suds pump removed - there is nothing at all in terms of coolant system. I would like to reinstate this.
I ran the lathe and it seems ok at the 2nd highest speed setting - I assume this corresponds to 510 or 1020 but this would have been with the original 2 speed motor - seems quite slow to me so more like 510 or less. If I run it on the highest setting it runs for a while and then cuts out for a minute or so until the click and then it will run again.
Also the lathe only appears to run in the standard ccw direction - is this due to the single phase motor? can a single phase motor be configured to go both ways?
I also noticed that a significant part is missing! The lower changewheel has nothing holding it on! I have a copy of the manual and parts manual and it should have a knurled nut - 30579-1, collar 30566, washer 30606. the nut is an odd thread (3/4 OD, 20tpi). Does anyone know where I can buy these items?
I looked at the motor - the plate was pretty worn but looks like:
Frigidaire p/n 5496279
Crompton Parkinson
1/2kw, 230/250V, 50 hz, 8 cos theta
I couldn't read the rest.
Murray - bearing in mind that I am starting from scratch with the coolant system, would you still recommend 3-phase/VFD or stick with what I have an look for an aftermarket 240v coolant system?
Cheers!
Edited By mtrehy mtrehy on 21/01/2018 17:03:35
Edited By mtrehy mtrehy on 21/01/2018 17:05:22
20/01/2018 20:02:10
Hi All,
I'm hoping to find some info about a Colchester Bantam I picked up today. I paid the grand sum of £300 for the Bantam - it's been sat in someone's shed for years and gathered a significant layer of surface rust.
I got it home and managed with plenty of bed cleaning and WD40 to free off the x & y axes. I removed the cover at the top of the machine and the gearbox looks like new.
The machine has a 240v single phase motor so I connected it up and gave it a go and it runs but does a few strange things. I understand that this would have originally been 3-phase but I don't know what compromises are now in place due to the single phase conversion. To start the spindle I turned a lever which is on the center or the cabinet. It runs for a bit and then stops - it then won't restart until something electric clicks - this takes a minute or so. Does anyone know what this night be?
The lathe sounds ok but when the power feed is selected and the "bar" is rotating it is quote noisy - is there any reason for this? I also can't get the power feed lever to select on the apron - seems like it is stuck in the off position.
I definitely need to buy a couple of bits - the plaque with the screwcutting information is not readable - are these available anywhere? I also need the tailstock handwheel. Any ideas where to get these?
Any help with this machine is greatly appreciated.
Thanks,
Matt
