Member postings for Chris Sangster
Here is a list of all the postings Chris Sangster has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford Vm-f
12/02/2019 09:11:01
Hi Waggoner - no problem - once I've scanned the leaflet, I'll add you to the mailing list....
Chris Sangster (Clockmaker)
12/02/2019 09:04:41
Nigel
Apologies for the delay - I will scan the leaflet and forward to your email a.s.a.p.
Chris Sangster
05/02/2019 16:00:53
I was not so much going to look at my VMC, which has visible bolts going through the base of the column into the base, but to look for a Myford original leaflet on the VM range. At the risk of upsetting Martin, he is wrong in that the bases of the VME & VMF are the same, cast, but different to the VMC, which is folded sheet steel. Similarly, the column of the VME & VMF are the same, but again different to the VMC. The weights according to the leaflet are: VMC 305kg, VME 387kg, and VMF 444kg. It is only an educated guess, but I would assume the column on a VMF must be removable from the top, as the weight would make tipping it over less than easy........
I can scan the leaflet if it is any help, but the deep tray on the VME & VMF base obscures any details of the fixing bolts.
CRS
