Member postings for Nick Ogden
Here is a list of all the postings Nick Ogden has made in our forums. Click on a thread name to jump to the thread.
Thread: It no worky !!
16/11/2017 17:00:01
Yes I have connected straight through bypassing the board and all is working fine. Yes I noticed the earth connection as you state. Thanks again I will order one This site has been a great help Nick
16/11/2017 16:14:37
Thanks for all your help. It would seem that there is no continuity across the board. Can I simply buy an in-line emi filter module as a replacement £4.96 from our favourite online auction site 112201070823 Thanks again Nick
15/11/2017 14:38:23
Thanks for all your help. I will double check everything tonight...at least I know I'm searching for AC now.
Every day is a learning daylaugh
15/11/2017 13:58:25
Thanks for the replies. I am getting no voltage whether AC or DC on the output of the board on connector J1.
Am I expecting to see AC as an output then on J1. ?
As you can probably gather, electronics are not my strong point.
Nick
15/11/2017 11:10:02
Hi all Numpty here. The lathe was working fine but now fails to power up. I’m assuming that with a 240volt ac input on J2 should there be 180 volt dc at J1 ? There is no out out at J1. If so I assume that the circuit board is dead. Are they available?
Thanks in advance
Numpty of Essex
2017-11-12 12.10.21.jpg2017-11-11 13.31.50.jpg2017-11-11 13.31.43.jpg2017-05-07 12.50.13.jpg
