Member postings for Chris Cartwright 1
Here is a list of all the postings Chris Cartwright 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Servo drill press help - Motor Fault
28/10/2017 10:07:46
Thank you all for your suggestions.
I've found out that Bridgeport (who distribute them in the UK) will take a look for me, so I'm going that route.
Cheers, Chris.
27/10/2017 09:13:53
Good spot Michael - thanks.
Will try going in through the speed control and see if that helps.
Cheers, Chris.
26/10/2017 22:59:14
Hi Michael,
Seen that
That got me as far as I've got in dismantling, but doesn't show the wiring harness that stops the stator coming out!
Thanks anyway
26/10/2017 22:10:16
Hi
I think it's a wiring short. It blows the circuit breaker (and internal trip on the top) every time I turn it on. Accompanied by a crack and ozone smell from somewhere around the motor.
I've tried to dismantle it to check the wiring, but can't get the stator out since the wires attached to it are too short to clear the housing. Can't access the wiring from below. No obvious burnout on rotor or stator. Brushes fine.
Thanks, Chris.
26/10/2017 16:56:29
Hi
Does anyone know of someone in the UK who can repair a servo precision collet drill press?
Thanks, Chris.
